hytanium
Beta 5 killed my Board??
Thu Jan 18, 2007 9:17 pm
I ftp'd the 3 b5 to my rb112 and rebooted. Beta 5 loaded but CPU was showing 100%
My RB112 got really hot / and I have not been able to logon using winbox on IP or Mac address.
Any suggestions.. I had an SR9 card in the m-pci slot. Previous version of OS worked great, just wanted to get into the BETA so that the SR9 Frequncies showed up in OS.
Can anyone point me to a topic on how to get to the console using a null modem cable??
PLEASE HELP!
REDTDI
Thu Jan 18, 2007 11:36 pm
The same thing happened to me while testing. I had to remove the wireless cards and use a serial cable to get into the router, I was then able to reset it. The information for using a serial cable is in the routerboard user manual.
Even though I have reset the board, the response from the router using Winbox seems a little slow...might this be because I used ftp to upgrade rather than NetInstall?
Thanks,
Ken
hytanium
Reinstall
Fri Jan 19, 2007 1:22 am
I managed to get back up and running on .39. Tried the Beta 5 load, and once again 100% CPU .... will not run...
R1CH
Sat Jan 20, 2007 12:09 am
Thanks for your post, I was planning on testing b5 on one of my RB 112s when they got here. Guess I'll save my time and wait for b6 :).
hytanium
Wed Jan 24, 2007 6:42 am
Ended up that my storage was corrupt. Formatted the nand and reloaded RB100 bios fw... reloaded router OS.... then
Ftp'd appropriate Beta 5 packages reboot...
Voila! back in business.
Very nice to have the 900Mhz fq settings now.
csickles
Wed Jan 24, 2007 6:45 am
There have been others with same symptoms...
This thread may be worth a "Sticky".....
Things that make you go Hmmmmm......
Craig
Users browsing this forum: benbgg, johnson73, Majestic-12 [Bot] and 120 guests
