I saw MT trying to make beginner can use MT easily by adding Factory Pre-Config, Quick Set, DHCP Server Wizard, Hotspot Wizard.
Why there is no WAN Load Balancing Wizard for masqueraded network?
Try search for questions about Load Balancing Setup n you'll know how many peoples (mostly beginner) need it so bad but can't do it because it needed intermediate MT knowledge to do that.
If MT can do Wizard for WAN Load Balancing or even better if can make new tab for it, I think that will be great.
If you do search, you can see many peoples need WAN Load Balancing together with Hotspot Authentication.
I hope this idea can be consideration for MT crew. Not every MT user are Geeks. Most of them are ordinary human lol. Thanks.
