I'm new here. I'm having some issues with RouterOS on a Hyper-V VM on a Dell 2950. Clean install, no interfaces are showing. NICs on the server are factory. I would assume they'd be supported. Am I missing something here?
Thanks in advance.
for Hyper-V you have to assign interfaces to the guest manually. Guests do not see interfaces from the host system.
You mean like this?
I've attached the picture of my settings.
that would hurt to try, but as stated above - NetExtreme II already supported by ROS, so perhaps not source of issues(unless they use different implementation of). try more "generic" NIC from list for start, yepThis was already the configuration before I posted. I have a linux VM(Ubuntu) and another linux VM(CentOS) running without issues on here as well.
So I guess I'm not sure what you are saying... Change ethernet driver?
Yes I know this, as I have three other linux VM's running now. Two Ubuntu 16.04 and one Ubuntu 14.04. I have assigned a NIC to it in the Hyper-V settings. Once the NIC has been added to the VM in Hyper-V, I would think RouterOS would be able to see it, right?for Hyper-V you have to assign interfaces to the guest manually. Guests do not see interfaces from the host system.
No BCM device, here's a screenshot.what you see in /system resource pci print detail?
do you see BCM device there?
