Suggested fix this problem (bug)
Your carrier's speed reaching very low with the LCD enabled function.
If you enable the LCD function for 2011UIAS RM model, the overall speed of your service slumps. For example. If I have contracted with my carrier 120MB, my speed actual is 30MB with this feature enabled. If you disable the function (LCD), its speed back to normal working. I suggest that developers launch a fix for this problem.
In another topic I found the solution to my problem:
http://forum.mikrotik.com/viewtopic.php?t=93553
My topic I created earlier with the same problem is below:
http://forum.mikrotik.com/viewtopic.php?f=2&t=112828
