Dear All
the nth=1,1,0 for adding odd address to the address list is not work in 3.o
but the even works
any help
Add those rules and watch counters, you will see that connections are marked even. As I wrote in previous post passthrough must be set. You need it because next nth rule must see connection passed through previous rule in order to match correctly.... and is not proportional the traffic between odd and even packets...
i tryed with 2,1 and 2,2 and the trafic not pass to the NAT rules, and is not proporcional the trafic betwen odd and even packets.
As a result, there is no trafic at the even interface.
See the "bold", is it possible for gateway using name instad of IP Address?? I Think I miss your mean for IP Address configuration, can you explain it to me?/ip route
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=arnet1 \
routing-mark=adsl1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=arnet2 \
routing-mark=adsl2
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=arnet3 \
routing-mark=adsl3
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=arnet4 \
routing-mark=adsl4
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=arnet5 \
routing-mark=adsl5
