Hey all,
http://www.supermicro.com/products/moth ... cfm?typ=C2
The SuperMicro PDSBM-LN2 board is working with both 2.9.51 and 3.16. I have a Core 2 Duo E2220 (2.4ghz 800mhz) in there. I was unsuccessful at using a CF card for some reason (IDE Removable bit?) but an IDE drive works fine. The SanDIsk Extreme III will not work - it just hangs before the kernel even loads. Does anyone have the removable bit flag utility ?
A dual core x64 box for less than the RouterBoard 1000... and not much bigger.
Note: I have not put this to any tests, just loaded and confirmed it starts up and routes a little traffic. 2.9.51 seemed to have lots of unknown devices in PCI resources, but it worked. I would be more comfortable running 3.x on it since it knows the system resources better.
