bda
[request] CoA for PPPoE/PPTP
Sun Mar 13, 2011 8:58 pm
Dear developers, CoA function for PPPoE/PPTP is very great for B-RAS applications. Then we can have it im ROS?
oeyre
Re: [request] CoA for PPPoE/PPTP
Fri Mar 18, 2011 7:56 am
I just checked the changelogs for v4 and 5 and it looks like this was introduced/changed in December last year.
Or am I missing something?
bda
Fri Mar 18, 2011 4:30 pm
Is it true for PPoE/PPtP? I know it works only for wireless...
bda
Wed Mar 23, 2011 5:00 pm
Sorry for bumping... But do we have any news on this topic?
snark
Mon Jun 06, 2011 9:30 am
I need CoA for PPPoE/PPTP too.
otgooneo
Trainer
Trainer
Mon Jun 06, 2011 5:11 pm
I need too. I believe it will be available soon. I`m waiting.
dimabar
Tue Sep 06, 2011 5:58 pm
Dear developers... Any news about CoA for PPP connections?
normis
Wed Sep 07, 2011 11:28 am
COA messages are not supported by PPPoE at MikroTik RouterOS.
Only DM messages are supported for PPPoE.
We have no plans to make COA in near future.
romanse
Thu Sep 08, 2011 1:33 pm
I need it very much too
have about 50 routerOS BRASes
nz_monkey
Fri Sep 09, 2011 12:05 pm
That is quite disappointing :(
dimabar
Mon Jan 16, 2012 2:35 pm
wow! how many sessions on them?
conchalnet
Tue Mar 20, 2012 3:58 am
Why not if you have it on hotspot??? I think that is not a very difficult job and a very usefull ressource for us.
I need of CoA on PPPoE too!
saaremaa
Sun Oct 14, 2012 11:58 pm
I need of CoA on PPPoE too! This is the right solution to manage PPPoE users than SSH.
conchalnet
Mon Oct 15, 2012 1:03 am
Do you have prevision to add PoE COA on 6.0 release???
it will be welcome!
regardtv
Mon Oct 15, 2012 9:51 am
Hi Everyone.
For the most part the DM/PoD works just as well in reality. In our scenario most/all customers use CPE/desktops that are configured to redial automatically. So, you send the PoD/DM message. User disconnects. When they reconnect they get new package details via Radius.
YES - I agree it would be nicer to have CoA is current user sessions won't have to drop - but it works fine as a workaround at this stage.
Normis, you can +1 me - I would like the CoA but agreed that we can work around it for the most part.
saaremaa
Wed Nov 14, 2012 4:31 pm
...bump...
Is there any news about the possible implementation of CoA?
conchalnet
Wed Nov 14, 2012 4:40 pm
...bump...
I'm waiting some news about this ressource too!
normis
Thu Nov 15, 2012 1:16 pm
Currently we have no plans
saaremaa
Tue Aug 20, 2013 9:59 am
Petition: The implementation of CoA for Mikrotik PPPoE servers https://www.change.org/petitions/mikrot ... e_petition
snark
Tue Aug 20, 2013 2:01 pm
I think we NEED accel-ppp in MT.
saaremaa
Wed Aug 21, 2013 2:49 pm
accel-ppp or a coa to the current pppoe server. Difference I think not.
snark
Wed Aug 21, 2013 3:06 pm
accel-ppp can do much more than current ppp package :)
saaremaa
Wed Oct 02, 2013 9:18 pm
bump
HaQs
Wed Oct 02, 2013 10:14 pm
+1 for pppoe rate change via radius without ppp disconnection
saaremaa
Wed Oct 02, 2013 10:45 pm
please sign up here → Mikrotik Users.: The implementation of CoA for Mikrotik PPPoE servers.
otgooneo
Trainer
Trainer
Tue Oct 08, 2013 8:39 am
+1 and signed for petition
shade
Wed Dec 04, 2013 2:53 pm
+1 for CoA in PPPoE
saaremaa
Fri Feb 21, 2014 6:39 am
sten
Forum Veteran
Forum Veteran
Fri Feb 21, 2014 11:58 am
Could someone please describe exactly how such a feature is used?
What are you trying to achieve or replace with built-in feature?
Buster2
Fri Feb 21, 2014 12:57 pm
On connect ppp daemon can apply radius authorization extension values (e.g. bandwith limits) to users. Change-of-Authorization messages are sent by radius to ppp daemon (I'd like to see it for l2tp too) without the ppp daemon asking. Using CoA RADIUS can tell PPP daemon to apply new authorization extension values without disconnecting the user as needed. With the current situation ISP have to disconnect its customers to lift bandwidth limits.
HaQs
Mon Sep 14, 2015 3:30 pm
in 6.33rc7 (2015-Sep-11 17:13):
*) ppp - added CoA support to PPPoE, PPTP & L2TP (Mikrotik-Recv-Limit, Mikrotik-Xmit-Limit,
Mikrotik-Rate-Limit, Ascend-Data-Rate, Ascend-XMit-Rate, Session-Timeout);
*) pptp - improved encryption;
*) ppp - added new option under "ppp aaa" - "use-circuit-id-in-nas-port-id";
*) userman - added 'history clear' to allow flushing undo history, which may
take up significant amount of memory for huge databases whith hundreds of users;
*) CAPsMAN - fix 100% CPU usage when trying to upgrade RouterOS on CAP;
*) ethernet - added support for new ASIX USB Ethernet dongles;
*) ppp - fixed ppp interface stuck in not running state;
*) ipsec - fixed kernel failure when packets were not ordered on first call;
*) upnp - randomize action urls to fix "filet-o-firewall" vulnerability;
*) RB532/RB564 - fixed no link after ethernet disable/enable;
*) tile - fixed occasional deadlock on module unload;
*) ipsec - fix sockaddres buffer size on id generation for ipv6 address;
*) userman - refresh active sessions/users view dynamically;
*) package - added version tag and show everywhere alongside of version number;
*) wlan - improve single connection TCP performance for ac chipset with cm2 package;
*) mesh - fix router lock-up when interface is added/removed.
MT very thanks for this.
saaremaa
Mon Sep 14, 2015 6:49 pm
Very thanks for this. We are waiting for this function.For a long time we are waiting.:D
nz_monkey
Tue Sep 15, 2015 1:11 am
Now we just need CoA for DHCP+RADIUS :)
Buster2
Tue Sep 15, 2015 1:16 am
+1
Thank you MikroTik.
otgooneo
Trainer
Trainer
Wed Sep 23, 2015 7:40 pm
+99 So cool :D
Users browsing this forum: bertus, kiloon, rarriazu and 87 guests
