• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Reset default IP address to a RB-450G Mini router  Page 1 of 1
 [ 2 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
User1234
 Post subject: Reset default IP address to a RB-450G Mini router
PostPosted: Fri Mar 25, 2011 9:54 pm
Offline
I was told my 3 routers were cleared and set to a default IP address. Can someone help me identify:
A: What is the default IP address
B: If it ISN'T at default, what are the procedures to default it
C: If I cannot default it to a predetermined IP address, how can I find out what IP address is assigned in the router
Thanks all for your support
Top
 Profile
fewi
 Post subject: Re: Reset default IP address to a RB-450G Mini router
PostPosted: Fri Mar 25, 2011 10:00 pm
Offline
a: on that router, I believe it is DHCP on the WAN interface (ether1), and 192.168.88.1/24 on the LAN interface (ether2). You can look it up on the box it shipped in, or reset in hardware as described in b) and then access via serial console and look at IP configuration.
b: "/system reset-configuration" if you can access it (IP, MAC, or serial console), or follow the instructions for a software reset by shorting the reset hole as described in the device's hardware manual (http://routerboard.com/pricelist/download_file.php?file_id=143).
c: if you're unsure it's always best to use the serial console.
_________________
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 2 posts ]
Board index » RouterOS » RouterOS BETA
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
