Mikrotik forum admins have chimed in on this subject many times - and if you want to know what it is, then go to a mirror and give the finger. That's pretty much the response. What they actually say is that igmp snooping is a switch feature, and a router is a router, so it already filters multicast properly for IP networks. This is true, but of course the mcast packet stream hits all switch ports / bridge ports of the LAN if you're using any layer 2 functions of the router....Dear admins when you give an answer on this subject ?
I would have understood that point if CRS series didn't exist.What they actually say is that igmp snooping is a switch feature, and a router is a router, so it already filters multicast properly for IP networks.
I tried with a couple of cheap stupid 8-port D-Link toys- they don't.Has anyone ever tried plugging a simple Linksys/Netgear/Belkin/etc cheap unmanaged switch to see if it supports IGMP snooping? (these probably don't either)
I agree - a product marketed as a switch should definitely have such a feature. I think this is more depending on the switch chips they're using as the foundation of their products - I'm not sure whether Atheros chips (the ones in things like the 2011 series) are capable of IGMP snooping or if it's a matter of programming them to do so. Whatever the case, I'm not a fan of Mikrotik's switches as anything more than basic frame forwarders with some VLAN capabilites. I want to like them - but they haven't won me over yet.I would have understood that point if CRS series didn't exist.
I didn't think they would do it - they are basic little dumb devices, after all.I tried with a couple of cheap stupid 8-port D-Link toys- they don't.
As I understand IGMP frames must be intercepted (mirrored to the cpu port) and then processed in software by CPU, which in turn should install the appropriate (dynamic) multicast-fdb entries and then time them out after a while.I'm not sure whether Atheros chips (the ones in things like the 2011 series) are capable of IGMP snooping or if it's a matter of programming them to do so.
Another place where IGMP snooping is welcome is wireless interfaces with multicast helper on- as I understand the helper will currently convert each multicast stream into a number of unicast streams unconditionally, one stream per each registered client.Of course the bridge feature is one place this could be implemented regardless of 3rd party chip capabilities.
Another way people deal with Multicast over WiFi is to ramp up the basic rate to a higher speed and disallow slow links.... I would think that unicasting the stream X number of times could get expensive on air time if lots of clients are subscribed to the stream. Although, I guess 10x 300Mbps transmissions is going to be better than 1x 6Mbps transmission.....Another place where IGMP snooping is welcome is wireless interfaces with multicast helper on- as I understand the helper will currently convert each multicast stream into a number of unicast streams unconditionally, one stream per each registered client.
You don't. Wireless multicast helper is perfectly fine for home use where you don't usually have big number of wireless clients registered at the same time. Just please note that the multicast-helper=default (which is the default) currently means disabled.Why do I need multiple routers ?
Indeed. I need some switches and I've immediately discarded Mikrotik's CRS because it's little more than a glorified bridge of the 1980's featuring multiple ports and Gigabit Ethernet. But it's a really incomplete product, I'm afraid.I would have understood that point if CRS series didn't exist.
ordinary users need a 1 router , rather than 2-3 . Why do you not understand? Most uses quick setup for the Internet and TV . but the TV does not work, it is very upsetting . I repeat the question that was asked several times whether it will work in 7 version ???????????????????????????
You said yourself, that a different device works with your TV. That other device does not have IGMP snooping. So why do you ask for this feature?ordinary users need a 1 router , rather than 2-3 . Why do you not understand? Most uses quick setup for the Internet and TV . but the TV does not work, it is very upsetting . I repeat the question that was asked several times whether it will work in 7 version ???????????????????????????
I got a ZyXEL GS1900-16 for $60 and it does support IGMP snooping. After years of user requests IGMP/MLD snooping is still not available, even on CRS....
