chubbs596
Re: IGMP Snooping
Tue Nov 04, 2014 9:15 am
+1 for IGMP snooping!
chubbs596
Re: IGMP Snooping
Tue Nov 04, 2014 9:16 am
+1 for DHCP snooping!
ofca
Re: IGMP Snooping
Tue Nov 04, 2014 11:18 pm
Huh, this still isn't done? FFS... $50 TP-LINKs have this implemented...
alexburke
Re: IGMP Snooping
Wed Nov 05, 2014 4:00 pm
+1 for IGMP snooping. Its absence is ridiculous.
anakyn
Re: IGMP Snooping
Mon Nov 10, 2014 10:06 pm
THe IGMP snooping is basic functionality of L2 switches. This is the reason why Mikrotik/RouterOS should be support it.
By the way, I think if the guys from Mikrotik team will work on IGMP snooping then it would be fine to also implement SSM mapping. I think this is much better feature then rendezvous point.If you have more providers for IPTV solution then SSM mapping is totally necessary. At the moment we are using L2/L3 devices for Multicast from other vendor because IGMP snooping and SSM mapping.
If the RouterOS will support these 2 features then we will try to use it.
BR.
Radovan
dg1kwa
Re: IGMP Snooping
Tue Nov 11, 2014 11:21 am
+1 for igmp snooping. In LAN today important function.
kyob
Re: IGMP Snooping
Wed Nov 12, 2014 3:55 pm
+1 for IGMP snooping! :)
k5nic
Re: IGMP Snooping
Wed Nov 12, 2014 7:05 pm
I currently have over 30 Cisco 48 port PoE switches in place, and have been working out details on how I can upgrade to MikroTik for speed, however, this is the only hurdle I have to get over in order to make this fly! Between this and the 6.21.1 fiasco regarding introduction of bugs rather than bug fixes, I have all but abandoned the notion of eliminating the expense of Cisco gear.
Normis and company need to start taking a good hard look at what us the customer is requesting. I would be purchasing at least 2 24 port CRS devices for every one of the 30 Cisco switches, in order to get the necessary 48 ports, BUT I need a stable OS, IGMP snooping and I will end up running more fiber switch RB does not have a fiber switch that I can place at each closet and no way to stack switches.
I just hope I don't have to say "Goodbye MikroTik, Hello Juniper"!
Regards,
Jay
nordex
Re: IGMP Snooping
Fri Nov 14, 2014 9:20 pm
+1 !
usx
Re: IGMP Snooping
Thu Dec 04, 2014 10:30 am
+1
was about to buy a CRS125-24G-1S-IN, but the lack of IGMP snooping told me not to.
poofeg
Re: IGMP Snooping
Wed Dec 10, 2014 11:05 am
Switch chip AR8327 have builtin hardware igmp snooping support. How to enable this feature?
cma1kep
Re: IGMP Snooping
Tue Dec 23, 2014 11:37 pm
+1 for IGMP snooping, its need in deed!
nmc79
Re: IGMP Snooping
Thu Dec 25, 2014 6:15 pm
+1!
Masyanich
Re: IGMP Snooping
Sat Dec 27, 2014 3:25 pm
+1 :(
D1M0N
Re: IGMP Snooping
Fri Jan 09, 2015 9:58 am
HeadCraft
Re: IGMP Snooping
Sun Jan 11, 2015 2:40 am
+11010001 for IGMP Snooping. Realy need it! I have a bridge of 4 ethernet ports and 7 vpn tunnels with encryption 256 aes. When you start multicast, the router burns out with a blue flame sending frames in each other port. I even would be glad if this functionality will be realized, but hard to get and disabled by default
AntonivkA
Re: IGMP Snooping
Mon Jan 12, 2015 6:31 pm
+100500 for IGMP snooping!!!!!!!!!!!!!!!!!!!!!!
zichovsky
Re: IGMP Snooping
Wed Jan 14, 2015 4:29 pm
Yes, IGMP snooping is realy needed. Mikrotik has some nice hardware with switch chips, usable as prefect CPE or in "last mile" access layer, but without support for IGMP snooping it can't be used, for example, in scenarios, where multicast IPTV is used.
And if IGMP snooping... then continue with IGMP group filtering (per port/pofile basis) and MVR.
Quasar
Re: IGMP Snooping
Wed Feb 11, 2015 9:25 pm
Sigh. +1
Please?
MikroTikFan
Re: IGMP Snooping
Sat Feb 14, 2015 6:08 pm
+1 IGMP Snooping, so for Mikrotik developers wheeeeeen ?
D1M0N
Re: IGMP Snooping
Thu Feb 19, 2015 9:51 am
Are there any plans of developers support IGMP snooping?
rain or look for another solution?
how difficult it is to implement?
10robinho
Re: IGMP Snooping
Mon Feb 23, 2015 7:22 pm
Per my understanding, IGMP snooping still doesn't work with CRS switches, right?
What about IGMP querier functionality that is also on most switches that are used for multicast video, is that planned too?
vortex
Re: IGMP Snooping
Mon Feb 23, 2015 7:38 pm
+1
This is one of the reasons why I threw away a brand new Netgear "business" security router and went Mikrotik, which was also a disappointment in this regard.
jberen
Trainer
Trainer
Re: IGMP Snooping
Wed Feb 25, 2015 7:24 pm
So +1 for IGMP snooping. 8)
lukoramu
Re: IGMP Snooping
Wed Mar 04, 2015 11:11 am
If there's no plans for conventional IGMP snooping on CRS1xx/CRS2xx series, I'm READY to implement an "external IGMP snooping" for our access switch solution, where every user has his separate VLAN, which consists of three ports: tagged uplink port, tagged switch1-cpu port (for DHCP relaying and IGMP), and untagged access port. And there's one multicast vlan, consisting of tagged uplink and tagged switch1-cpu (access ports are not included in this vlan; 'Bypass VLAN filter' setting on every MFDB entry will be mandatory).
Bear with me :) All the elements are here:
  • Multicast FDB on switch chip (tested, works beautifully)
  • IGMP proxy, running on CPU
  • IGMP proxy syslog events to remote syslog server
  • IGMP proxy MFC list
  • RouterOS API
It will be more like synchronizer between two lists:
  • Atheros swich Multicast FDB
IGMP proxy syslog events will be used to quickly add MFDB entries, and there will be periodic MFC->MFDB synchronization for missed IGMP joins (if IGMP group exists in MFC list, then it means that IGMP proxy is forwarding multicast traffic to user VLAN using scarce CPU resources). MFDB entries will be removed when there's no membership reports for 3*query_interval.
Considering the price of CRS125, I'm sure it's worth it (all that scripting effort) :) It's a solid plan B! :)
rogerowl
Re: IGMP Snooping
Wed Mar 04, 2015 3:54 pm
  • RouterOS API
This will be excelent.
Do you have any ideia if/when you'll start this project?
nordex
Re: IGMP Snooping
Fri Mar 27, 2015 12:24 pm
++ for igmp snooping
ZeroByte
Re: IGMP Snooping
Fri Mar 27, 2015 3:22 pm
lukoromu - why not just buy one of these?
http://www.ebay.com/bhp/cisco-3550
used old Cisco switches for under $100.
They'll do IGMP snooping.
(Doing it just because you want to accomplish something technically challenging is a good reason to be sure)
Although - Mikrotik should support IGMP snooping.
+1
ECCOsea
Re: IGMP Snooping
Thu Apr 09, 2015 5:32 pm
+1 to IGMP Snooping!
hzdrus
Re: IGMP Snooping
Fri May 08, 2015 11:52 am
Would love to use those CRS212-1G-10S switches, probably buy a hundred or so, but it is impossible to offer IPTV without snooping :-(
dilnix
Re: IGMP Snooping
Sat May 30, 2015 10:15 am
I have plans to build new large network in some Ukrainian city with IPTV and PortToCustomer configuration. But without IGMP and DHCP snooping it's imposible to do using Mikrotik routers and switches. So i forced to use another brand.
Sorry Mikrotik, but you slowing your own success...
haakon
Re: IGMP Snooping
Mon Jun 22, 2015 11:14 pm
+1, this is a must!
andersonlich
Re: IGMP Snooping
Tue Jun 23, 2015 2:04 am
Don't forget to put IGMP suppress. :D
MasterXP
Re: IGMP Snooping
Tue Jun 23, 2015 7:59 am
+1 for IGMP Snooping
krzysztof
Re: IGMP Snooping
Wed Jul 22, 2015 10:41 pm
Hello
How can I ask for?
How long do I ask?
Very many people have written about it.
I am a regional provider of IPTV in Poland.
Very quickly it needs IGMP Snooping in RouterOS (Switches).
IGMP Proxy authentication does not work with TV tuners.
I need a couple of thousands of such devices.
When IGMP Snooping is available in RouterOS?
Please I need IGMP Snoping compatible with CISCO.
Please, Please, Please
Regards.
Krzysztof Pawluk
PastuhMedvedey
Re: IGMP Snooping
Thu Jul 23, 2015 10:31 am
kometchtech
Re: IGMP Snooping
Thu Jul 23, 2015 10:55 am
+1 :D
shifto
Re: IGMP Snooping
Sun Jul 26, 2015 7:22 pm
When I found out this was missing (lol) I had to dust off an old AT-9924 to do the switching which is kind of ridiculous. (Also it's very noisy! :P)
netmaster
Re: IGMP Snooping
Wed Jul 29, 2015 10:23 am
CRS112-8G-4S-IN
What a hell we supposed to do with 8 port switch with 4 SFP and without IGMP?
It would be a ideal for FTTH installations, but without multicast capable wirespeed switch it is another pointless product in long line of SFP switches...
lenart
Re: IGMP Snooping
Wed Jul 29, 2015 4:24 pm
jondavy
Re: IGMP Snooping
Sat Aug 29, 2015 3:25 pm
zolorkin
Re: IGMP Snooping
Tue Sep 01, 2015 3:40 pm
hello cool stuff
Escalader
Re: IGMP Snooping
Mon Sep 07, 2015 6:27 pm
I vote for IGMP snooping in RouterOS v7.
korniza
Re: IGMP Snooping
Sat Oct 03, 2015 11:03 am
ebreyit
Re: IGMP Snooping
Sun Oct 04, 2015 11:34 pm
Neovr
Re: IGMP Snooping
Sun Oct 18, 2015 8:38 pm
+11111111
KitMikro
Re: IGMP Snooping
Mon Oct 19, 2015 11:20 pm
still nothing???
+1
jozevolf
Re: IGMP Snooping
Fri Nov 06, 2015 12:02 pm
+1
Because of lack of this feature I need to use TP-LINK TL-SG3210. Not a bad switch though. I don't think you can find better for the price. 2 separate (not shared) SFP ports + 8 gigabit copper ports + console management + fanless. I use both SFPs, one for incoming connection from ISP and the second to connect over dark fiber to my other location where there is another SG3210. But I need separate router-wifi-ap device on my first location and wi-fi ap on second. But I guess there is no integrated solution from RB for my primary location anyway. :)
kemerovo
Re: IGMP Snooping
Mon Nov 09, 2015 5:25 am
Прошу прощения за мой английский, буду высказываться максимально просто. К сожалению не владею английским. Всё валю на google переводчик если что. Не знаю, как в Европе и Америке,но в России довольно не плохо развито iptv multicast. Те средства обработки multicast трафика,что имеются в продукции MikroTik явно не достаточны для элементарного применения дома. Крайне необходимы пакеты udpxy и igmp snooping. Без обид,Латыши Вы тормозите,распространение собственной продукции. Без условно MikroTik,как it компания,облапошит всех конкурентов в виде гигантов: ASUS,CISCO и "наступающий на пятки" руко-кривых китайцев,но дешёвых d-link и tp-link. Ваша продукция не может не вызывать восхищения,она почти безупречна. Но будьте толерантны к простым пользователям,и к Вам потянутся. Udpxy и Igmp-snooping уже обыденность для современных реалий ip,включите пожалуйста их в свою новую прошивку! Либо устройте голосование за включение этих функций в routerOS, если сами сомневаетесь,пусть пользователи решат! В любом случае,если эти пакеты не нужны,то их можно и не включать!!!
Нет у меня уверенности,что гугл переводчик переведёт нормально....
Sorry for my English, I speak as simple as possible. Unfortunately do not know English. All exchange on google translator if that. I do not know, as in Europe and America,but in Russia rather poorly developed iptv multicast. The means of processing multicast traffic that are in production MikroTik clearly not sufficient for basic home use. It is extremely necessary packages udpxy and igmp snooping. No offense,Latvians You slow down,the distribution of its products. Without conditionally MikroTik,as it company,will allapotat all competitors in the form of giants: ASUS,CISCO and "coming on the heels of" lead-curves Chinese,but cheap d-link tp-link. Your products can not but arouse admiration,she's almost perfect. But be tolerant to simple users,and will listen to You. Udpxy and Igmp snooping is already the ordinary for modern realities ip,please include them in your new firmware! Or arrange a vote for the inclusion of these functions in routerOS, if in doubt,let the users decide! In any case,if these packages are not needed,they can not be enabled!!!
+1
in Russia IPTV is very popular
I hope that soon you'll add this feature
nordex
Re: IGMP Snooping
Sat Nov 14, 2015 8:57 pm
+1
Mikrotik, do you like to see us suffer ?
MikroTikFan
Re: IGMP Snooping
Mon Nov 23, 2015 11:40 pm
Why Mikrotik stuff is not hearing customers voice ???
How long this should take since 2012-1015, Mikrotik wasted 3 years !
In the same time most of other companies have implemented this feature even in low-end routers/switches !
Skyder
Re: IGMP Snooping
Sun Nov 29, 2015 2:13 pm
+1 Igmp snooping: in Russia is very popular IPTV. The routers from other manufacturers are all well. Please add it.
In firmware 5.26 IPTV is not saturated with other ports in the bridge - everything is working properly, including Wi-Fi clients. On the firmware 6.xx while watching the IPTV on any client, once clogged channel Wi-Fi.
jmginer
Re: IGMP Snooping
Wed Dec 16, 2015 1:41 am
+1 IGMP Snooping to manage my IPTV stations.
Neovr
Re: IGMP Snooping
Wed Dec 16, 2015 9:33 am
When?!
it's very inportant!
selmir
Re: IGMP Snooping
Sun Jan 03, 2016 12:43 pm
+1 IGMP Snooping
b0m8er
Re: IGMP Snooping
Sun Jan 17, 2016 12:11 pm
+1
Much needed and long awaited feature. It's freaking stupid that in 2016 consumer grade zyxel router works with iptv better then pro-oriented mikrotik.
Please add this feature.
kemerovo
Re: IGMP Snooping
Tue Jan 26, 2016 5:53 pm
Dear admins when you give an answer on this subject ?
ZeroByte
Re: IGMP Snooping
Tue Jan 26, 2016 8:10 pm
Mikrotik forum admins have chimed in on this subject many times - and if you want to know what it is, then go to a mirror and give the finger. That's pretty much the response. What they actually say is that igmp snooping is a switch feature, and a router is a router, so it already filters multicast properly for IP networks. This is true, but of course the mcast packet stream hits all switch ports / bridge ports of the LAN if you're using any layer 2 functions of the router....
Has anyone ever tried plugging a simple Linksys/Netgear/Belkin/etc cheap unmanaged switch to see if it supports IGMP snooping? (these probably don't either)
andriys
Re: IGMP Snooping
Tue Jan 26, 2016 10:10 pm
I would have understood that point if CRS series didn't exist.
I tried with a couple of cheap stupid 8-port D-Link toys- they don't.
ZeroByte
Re: IGMP Snooping
Tue Jan 26, 2016 10:48 pm
I agree - a product marketed as a switch should definitely have such a feature. I think this is more depending on the switch chips they're using as the foundation of their products - I'm not sure whether Atheros chips (the ones in things like the 2011 series) are capable of IGMP snooping or if it's a matter of programming them to do so. Whatever the case, I'm not a fan of Mikrotik's switches as anything more than basic frame forwarders with some VLAN capabilites. I want to like them - but they haven't won me over yet.
I didn't think they would do it - they are basic little dumb devices, after all.
Of course the bridge feature is one place this could be implemented regardless of 3rd party chip capabilities. I don't personally have to deal with IGMP snooping issues (I live in the USA where the cable companies fight tooth and nail against streaming video services) but if I did need IGMP snooping, I'd just go get a used Cisco 2600-series switch for pennies.
andriys
Re: IGMP Snooping
Tue Jan 26, 2016 11:37 pm
As I understand IGMP frames must be intercepted (mirrored to the cpu port) and then processed in software by CPU, which in turn should install the appropriate (dynamic) multicast-fdb entries and then time them out after a while.
Another place where IGMP snooping is welcome is wireless interfaces with multicast helper on- as I understand the helper will currently convert each multicast stream into a number of unicast streams unconditionally, one stream per each registered client.
ZeroByte
Re: IGMP Snooping
Tue Jan 26, 2016 11:46 pm
Another way people deal with Multicast over WiFi is to ramp up the basic rate to a higher speed and disallow slow links.... I would think that unicasting the stream X number of times could get expensive on air time if lots of clients are subscribed to the stream. Although, I guess 10x 300Mbps transmissions is going to be better than 1x 6Mbps transmission.....
kemerovo
Re: IGMP Snooping
Wed Jan 27, 2016 3:07 am
Why do I need multiple routers ? I want to have one that will carry out my tasks , cheap devices D-Link, TP-Link to cope with it without any adjustments, why is this not a simple function organized at mikrotik? :(
in Russia is very popular service IPTV (multicast) and 90% of ISP provide it for free, it is very convenient to move around the house looking at the TV , the and then finger the mirror , I did not understand
andriys
Re: IGMP Snooping
Wed Jan 27, 2016 8:49 am
You don't. Wireless multicast helper is perfectly fine for home use where you don't usually have big number of wireless clients registered at the same time. Just please note that the multicast-helper=default (which is the default) currently means disabled.
kemerovo
Re: IGMP Snooping
Wed Jan 27, 2016 9:07 am
I know how to set up the equipment , but it does not work as it should work .
multicast helper - full Does not help, Activity increases network , packets are all the ports , this leads to instability of the network
matmor
Re: IGMP Snooping
Tue Mar 15, 2016 8:17 pm
Still no news for IGMP Snooping ?
I know RouterOS is for Routing, but with product like CRS and especially the new HAP that look like the perfect Residential Gateway, IGMP Snooping is a must have.
IGMP Proxy work well to transfert Multicast receive from the ISP side to the client LAN side, but I don't want all the PC of the clients to receive the STB multicast as soon as a STB join one. But I don't want to block multicast on PC ports, causse we work on whole one PVR and Desktop App to receive the Multicast Stream.
On regular RG ( Residential Gateway ) like Comtrend WR-6895 or Smart-RG SR510N if a STB joint a Multicast Stream, only the LAN port of the RG where the STB is will receive the stream ( IGMP Proxy for L3 + IGMP Snooping for L2 switch of the RG ).
I will have 500 to 1000 RG to buy in the next year for our first managed home Wi-Fi solution.
It could be HAP and HAP lite, but without IGMP Snooping I will have to go with Comtrend or Smart-RG !
Bergante
Re: IGMP Snooping
Thu Mar 17, 2016 11:34 am
Indeed. I need some switches and I've immediately discarded Mikrotik's CRS because it's little more than a glorified bridge of the 1980's featuring multiple ports and Gigabit Ethernet. But it's a really incomplete product, I'm afraid.
I'm sticking to HP Procurves for that.
norepto
Re: IGMP Snooping
Wed Mar 23, 2016 6:04 pm
+1 IGMP Snooping
hzdrus
Re: IGMP Snooping
Tue Mar 29, 2016 1:02 pm
Regarding the point raised earlier about possible limitations on the switch chip itself: this doesn't stop Mikrotik from implementing snooping on "/interface bridge" level.
For example, RB2011 gives adequate performance in bridge mode as a small consumer aggregation device. Linux already supports snooping in its bridge code, so it is a matter of Mikrotik giving some priority to porting the functionality.
tubituba
Re: IGMP Snooping
Sun Apr 17, 2016 8:03 pm
+1 for IGMP Snooping with RB2011 routerboard.
Please, MikroTik. Please Please Please
kemerovo
Re: IGMP Snooping
Mon Apr 18, 2016 7:36 am
Administrators why you ignore the wishes of customers ? :(
otgooneo
Trainer
Trainer
Re: IGMP Snooping
Sat May 21, 2016 6:18 pm
kemerovo
Re: IGMP Snooping
Tue Jun 07, 2016 2:00 pm
vanderlaag
Re: IGMP Snooping
Fri Jun 24, 2016 8:24 am
ilyav3
Re: IGMP Snooping
Fri Jun 24, 2016 6:50 pm
+2 for IGMP snooping
klukoks
Re: IGMP Snooping
Mon Jun 27, 2016 1:29 pm
Hello, i have simple question. Will Mikrotik have IGMP snooping in v7? I won't stop using it, but like many people I would like to know.
greetings from Poland
PS I don't want to use it on RB4xx, 7xx, 9xx Wifi stuff but on 2011, 750 and newer better switches.
normis
Re: IGMP Snooping
Mon Jun 27, 2016 1:51 pm
vanderlaag
Re: IGMP Snooping
Mon Jun 27, 2016 9:48 pm
There is nothing to see over there that's looks like a answer for the question in the post.
kemerovo
Re: IGMP Snooping
Tue Jun 28, 2016 6:20 am
ordinary users need a 1 router , rather than 2-3 . Why do you not understand? Most uses quick setup for the Internet and TV . but the TV does not work, it is very upsetting . I repeat the question that was asked several times whether it will work in 7 version ???????????????????????????
normis
Re: IGMP Snooping
Tue Jun 28, 2016 7:39 am
You said yourself, that a different device works with your TV. That other device does not have IGMP snooping. So why do you ask for this feature?
ZeroByte
Re: IGMP Snooping
Tue Jun 28, 2016 7:40 pm
Kemerovo:
Is your problem that the IPTV clients will not work at all, or is your problem that it works, but whenever using it, all ethernet interfaces are flooded with unnecessary traffic? It's my impression that your problem is the second one. It is true that the device you linked earlier does not support IGMP snooping, so I can see why Normis is confused about what your problem is.
If your problem is that the devices won't work at all, then it's true that your problem is not the lack of IGMP snooping (whether or not such a feature is good). I recommend starting a new thread requesting help in getting your IPTV clients working if that's your issue.
Normis:
Kemerovo's specific issue notwithstanding, it does appear that IGMP snooping is a very-much-requested feature, and I do think that it would be a very normal thing for layer2 devices to support. Without IGMP snooping, a switch just converts multicast into broadcast which can overload a network if there are many streams going on in parallel. This is quite a waste of resources, especially when only a few clients are subscribed to each stream (obviously you already know this very well - I point it out for the sake of those reading the thread who may not know the difference) ... Is there any reason why Mikrotik seems to be so opposed to implementing this feature?
If the reason is that the HW switches of various platforms may or may not be strong enough to implement it at the hardware switch layer, or that the implementation is different for each chipset in use, then I can see how this could get ugly - but certainly implementing it on the bridge shouldn't be constrained by this limitation. Yes, it would be better to do this in silicon, but if the feature is at least POSSIBLE in CPU, then it's a viable solution for those whose networks have significant amounts of multicast traffic.
Me, if I needed it so badly, I would just bite the bullet and add a switch with IGMP snooping, or if religiously opposed to multiple network devices, I would buy some other vendor's gear and not stubbornly live with bad network performance until Mikrotik meets my demands.
SDFadfasdfadsf
Re: IGMP Snooping
Wed Jun 29, 2016 1:47 pm
I got a ZyXEL GS1900-16 for $60 and it does support IGMP snooping. After years of user requests IGMP/MLD snooping is still not available, even on CRS....
normis
Re: IGMP Snooping
Wed Jun 29, 2016 1:51 pm
IGMP snooping development will not be sped up if one person will register many forum accounts and post the same request over and over again.
dcavni
Re: IGMP Snooping
Wed Jun 29, 2016 2:18 pm
At least we know you are working on it :)
I used cheapest 8 port TPLink smart switch for that purpose, since it has IGMP snooping. It worked as aspected, no IPTV traffic flood on Mikrotik.
normis
Re: IGMP Snooping
Fri Jul 14, 2017 11:19 am
IGMP snooping support added in RouterOS 6.40, please test and report.
Users browsing this forum: airbytes, Amazon [Bot], Majestic-12 [Bot] and 130 guests
