In an increasingly IPv6 world, it would be useful if Mikrotik fully supported ipv6 subnet masks longer than /64. This generally requires the ability to disable subnet-router anycast, which does not seem to be the case in RouterOS (at least not in v5.x; I haven't seen v6 yet, and I doubt it is there either).
I have encountered problems trying to do this.
The relevant RFC is 6164 (Using 127-Bit IPv6 Prefixes on Inter-Router Links - April 2011), which applies to inter-router PtP links, which I suspect many RouterOS customers need to do/implement (particularly for upstream/backbone links).
Given the vulnerabilities of using /64 for inter-router PtP links, this seems like it should receive some attention. I'm not convinced that using link-local addresses for PtP links is the way forward (it does seem to work if you need a [temporary?] work-around).
Thanks for your consideration!
