littlecake
Problematic BFD on 6.0
Fri May 31, 2013 11:36 am
Have someone also problems with BFD in combination with OSPF on version 6?
When I enable this combination , the OSPF starts breaking every cca 10 minutes.
In version 5.20 I never had problems
spoiler
Re: Problematic BFD on 6.0
Wed Jun 26, 2013 12:24 pm
Same here with 6.1
Before upgrade, everything was fine with BFD.
All BFD neighbors stop responding after some period of time (minutes). It happens when BFD is enabled on the remote side, not if only enabled in local. Remote nodes are mixed versions: 5.21, 6.0, 6.1 with no significant differences.
Log shows:
discarding BFD packet: neighbor not found
hengst
Sat Jan 03, 2015 1:20 pm
Hello, now in 6.24 is this BFD problem problematic for anyone ?
at the moment iam busy experimenting with it in combination with OSPF in Lab, but cant get it stable ?
BFD doesnt see neighbours randomly.
anyone confirming this ?
hengst
Tue Jan 06, 2015 8:41 pm
from Support : to be fixed in V7.X
nz_monkey
Wed Jan 07, 2015 7:53 am
Strangely we are using BFD+OSPF on RouterOS 6.5 and 6.19 with no issues.
AlexS
Thu Feb 05, 2015 10:21 pm
was there any solution to this.
I am trying to enable BFD + OSPF and its failing.
I am using a lacp underneath if thats an issues.
lrl
Sat May 02, 2015 9:33 pm
I've ran into this on various hardware. Usually a reboot of the router solves the problem. If I have one peer having problems I reboot the peer, if it's all peers I reboot the core and problem goes away.
I've seen this on:
CCR-1036
RB100AHx2
RB750UP
RB2011
But strangely I don't recall it happening on our CCR1009's
All routers are running a 6.2X version.
Cha0s
Sun Aug 02, 2015 3:31 pm
Generally I don't have any issues with BFD either. At least not the ones mentioned on this thread.
But occasionally if one peer goes down, BFD may drop all the other peers as well without any reason (no packet loss or anything on other peers).
Thankfully this occurs rarely, but it does occur (and I have seen this behavior on multiple installations) and it kind of defeats the purpose of a quick failover in routing when problems occur :(
Users browsing this forum: adwlodaro, anav, Exabot [Bot], jamesperks, MrDeepFreeze, SpirosR and 104 guests
