+10000000+1 for UDP + LZO and tls-auth
No. The only code that must be open-sourced is the code modified as is stated by GPL. MikroTik uses the GPL'ed code of Linus' kernel…@tierpath
From what I can see in the comparison table, both the OpenVPN and SoftEther VPN projects use GPL, meaning that any projects that use them must also be open sourced.
Since RouterOS is not an open source piece of software, I doubt MikroTik will ever integrate SoftEther VPN, just as they haven't integrated OpenVPN, but have instead made their own implementation of the OpenVPN protocol.
@Sob
If MikroTik could integrate an external package that has all of these features, then it means the same thing as every other dependency they have: They have less things to worry about afterwards, just like how they integrate OpenSSL, and thus only have to worry about keeping it updated.
Integration should be relatively easy from a technical standpoint (easier than implementing new features from scratch), but like I said, from a legal standpoint... No.
You're right. In my defense, at the time of that post, I did not know those details, and in fact, until this more recent thread I just found out MikroTik includes GPL software.No. The only code that must be open-sourced is the code modified as is stated by GPL. MikroTik uses the GPL'ed code of Linus' kernel…
Thank you for the suggestion. We are already working on UDP OpenVPN in RouterOS v7
Mikrotik support answer (just now):Thank you for the suggestion. We are already working on UDP OpenVPN in RouterOS v7
Hi.THere will be UDP support in ROS v7.
Thank you!THere will be UDP support in ROS v7.
Finally. Thanks a lot!THere will be UDP support in ROS v7.
up to Christmas will be done !Hi.THere will be UDP support in ROS v7.
In what month in 2016 year is planned to release ROS v7?
When it's ready ?Hi.
+100500Please add to openvpn this one!!!!->
UDP mode
LZO compression
TLS authentication
authentication without username/password
You wrote - Fri Mar 18, 2016 3:44 amTHere will be UDP support in ROS v7.
3 years already...You wrote - Fri Mar 18, 2016 3:44 amTHere will be UDP support in ROS v7.
4 months later ....
When fantasy_ROSv7 appear (with UDP mode, LZO compression, TLS authentication, authentication without username/password) ?
I'll die of old age, and not waiting ROSv7?
Can i continue to buy Mikrotik RouterBOARD, in the hope that will fantasy_ROSv7?
Best regard for MikrotikTeam!
When???????Then why we decided to add UDP support?
is there any rOS7 RC or beta version available? i'd like to test OVPN with a RB2011 over LTE and another over a FTTH connection....Then why we decided to add UDP support?
AFAIK it is in alfa stage - not even beta. So, no public access.is there any rOS7 RC or beta version available? i'd like to test OVPN with a RB2011 over LTE and another over a FTTH connection....
too bad ... i'm doing a lot on ovpn testing and site-to-site infrastructures....AFAIK it is in alfa stage - not even beta. So, no public access.is there any rOS7 RC or beta version available? i'd like to test OVPN with a RB2011 over LTE and another over a FTTH connection....
"next week" + 1Could be next week, next month, next year, or 2020.
it possible or something similar, this explains the introduction of functions only in V7...
That is certainly the quickest and probably the best way to get fully functional OpenVPN service.I go buy a mini-ITX and install Ubuntu Server
