midenok
IPSec server can't find static policy on client connection
Fri Nov 21, 2014 11:36 am
/ip ipsec peer> print
0    address=0.0.0.0/0 local-address=0.0.0.0 passive=yes port=500 auth-method=rsa-signature
      certificate=limbo-ipsec remote-certificate=sip-ipsec generate-policy=no exchange-mode=main
      send-initial-contact=no nat-traversal=yes proposal-check=obey hash-algorithm=sha1
      enc-algorithm=aes-128 dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=2m
      dpd-maximum-failures=5
/ip ipsec policy> print
 0 T * group=default src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
 1     src-address=0.0.0.0/0 src-port=any dst-address=192.168.35.0/24 dst-port=any protocol=all
       action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=195.90.80.70
       sa-dst-address=37.107.11.12 proposal=default priority=2
ipsec,debug no policy found: 0.0.0.0/0[0] 192.168.35.0/24[0] proto=any dir=in
Though, generated policy works pretty well:
      certificate=limbo-ipsec remote-certificate=sip-ipsec generate-policy=port-strict
      exchange-mode=main send-initial-contact=no nat-traversal=yes proposal-check=obey
      hash-algorithm=sha1 enc-algorithm=aes-128 dh-group=modp1024 lifetime=1d lifebytes=0
      dpd-interval=2m dpd-maximum-failures=5
 2  D  src-address=0.0.0.0/0 src-port=any dst-address=192.168.35.0/24 dst-port=any protocol=all
       sa-dst-address=37.107.11.12 priority=2
Why it can't find policy 1 in case of 'generate-policy=no' though it generates exactly same policy?
midenok
Re: IPSec can't find static policy
Mon Dec 01, 2014 12:28 pm
bump
Though enabling static policy turns off access from home network (192.168.35.0/24). This means, that policy actually works. Only it can't be matched by connected IPSec client.
It is not chicken and egg problem, because dynamic policy works perfectly well when static policy is ON.
Users browsing this forum: gkhun, GmbH, Google [Bot], HeinoHomm, raiser and 116 guests
