normis
Re: Winbox 3 RC
Tue Feb 17, 2015 11:22 am
i want eg A.VIW to copy to B.VIW so i dont have to open again the same windows for another host.
does copying a .viw file from one session to another session makes problem?
tried it and working but i dont know the if there are any side effects.
Please clarify what you want to achieve. You can already use the same window layout when connecting to any other device. The profiles are not tied to devices, they are generic. If you mean "another PC", then sure, just copy the VIW to the other PC and use it there. You can even try putting the files in Dropbox, so that the latest view is always on both computers, but I am not sure how this will work if many computers use one file at the same time.
freemannnn
Forum Veteran
Forum Veteran
Winbox 3 RC
Tue Feb 17, 2015 11:48 am
I dont mean one .viw file. I meant copied and paste to many files.
Ok i got the answer that is not tied to a host. Thanx
spippan
Re: Winbox 3 RC
Tue Feb 17, 2015 12:02 pm
Winbox RC1 is available. There are lots of changes since beta 3*
http://download2.mikrotik.com/routeros/ ... winbox.exe
* - (10 versions were not made public)
awesome thanks .... works great under wine on mac ("WinBox4Mac") ;-D --> even did the upgrade directly out of the Beta3 running under wine ;)
WirelessRudy
Re: Winbox 3 RC
Tue Feb 17, 2015 8:54 pm
I don't know if this is a winbox feature or ROS, but when can we finally select and copy parts of the log output in winbox?
Sometimes you are just trying to figure out what happened by digging through the log. But there is so much info and specially when you want a quick look into when and how many times something happened it would be nice if you can just temporarily 'select' parts of the text. Would be even better if we than also could copy and paste it somewhere else for further study.
Top of the bill would be if you could even select some specific info out of the log to be highlighted (of made visible).
Like logs of AP contain a lot of info but for instance I would like to know one specific mac's history. Now its sometimes like searching the needle in the haystack
Many have been asking for better log features in the past but since ROSv2.x its never changed......
freemannnn
Forum Veteran
Forum Veteran
Winbox 3 RC
Tue Feb 17, 2015 9:13 pm
I would like copy paste of rules between different sessions!
Eg i mark one firewall rule right click it and copy. I go to another session and i paste it.
chojrak11
Re: Winbox 3 RC
Wed Feb 18, 2015 12:29 am
You can do it easily today. Just open a terminal, enter
/ip firewall filter export
(or nat or mangle), select required rules, copy them to clipboard, and paste them to terminal in another session.
chojrak11
Re: Winbox 3 RC
Wed Feb 18, 2015 12:32 am
I just log to disk instead of memory (it's good idea anyway because log data is persistent across reboots), and then drag and drop log files to my desktop, then further analyze them (using Notepad++ or grep/awk/sed or any other tool).
freemannnn
Forum Veteran
Forum Veteran
Winbox 3 RC
Wed Feb 18, 2015 12:38 am
I know that way........ but it will be a lot easier if you right click selected rules, copy, and those rules would be in clipboard so you can paste them in another session terminal or notepad for editing!
WirelessRudy
Re: Winbox 3 RC
Wed Feb 18, 2015 1:50 am
Well, don't know. If I do that I get a notepad document without line enters so one big soup of characters. Now I have to start text editing just to get things readable. You also need export it to your desktop first and then open. Just 2 extra steps apart from the soup you get. Why can't this not be made possible just within winbox?
bajodel
Long time Member
Long time Member
Re: Winbox 3 RC
Wed Feb 18, 2015 7:53 am
First thing - I'm positively amazed by the progress done for Winbox.
I've got a small, simple suggestion. Please make an option to disable/enable drag and drop of RouterOS configuration entries in Winbox. I'm a cautious user, but from time to time I move some firewall rules and I already locked myself out a few times, or disturbed traffic for multi-thousand-user network because of that. Just an option in "Settings" menu would be sufficient.
Surely I'm not the only one :-)
+1 for drag and drop sticky switch (good idea!! better reliable behavior)
+1 for full row comment rule (I'm already using a 'dummy' chain to create floating comment but now, with the new inline comment globally on/off, I cannot keep some window not inline. ..and comments go out of screen)
olco
Re: Winbox 3 RC
Wed Feb 18, 2015 7:31 pm
Just à little cosmetic request. Beside the "inline comments" option, can you add this view option : Auto Size Columns + Headers
Very practicle for every body want to view all information without endless click & move with the mouse....
For an example look at the Freeware from Nirsoft, WakeMeOnLan (the idea is based on) :
http://www.nirsoft.net/utils/wake_on_lan.html
chojrak11
Re: Winbox 3 RC
Thu Feb 19, 2015 9:58 am
My other problem is with log window. I don't know whether it's caused by my 125% DPI setting (otherwise fonts are too small) or something else, but the time is not fully visible, and that column is not resizeable. Thus it's hard to correlate events from log (especially when troubleshooting new customer, where logging is not set to disk, so I can't download the log and read in a Windows tool).
WirelessRudy
Re: Winbox 3 RC
Thu Feb 19, 2015 12:17 pm
Another feature that definitely could use a modernisation:
In any window with columns some are preset. It would be nice if the preset columns could be set according wish (a shobloon that counts for every winbox version opened from that moment on.
But, more important, if you'd select a column to be shown or disappear every time you'd click on a column name its set and you'd have to open the same again to go to the next. (In menu window of choice; right-click -> click on "Show Columns" in the pull down menu and select/deselect the column of choice.....
If you, like me several times a day, want to re-arrange the columns at your wish this means many, many unnecessary mouse clicks a day!
Why not have the option to tick on or of each column of choice and than one click to accept and all columns set at once....
To arrange this in a sjabloon type of setting (with column width and order) for each window type that counts for all winbox sessions, independent of the routerboard opened, it would save sooo much time on a day to day basis.
Ok, you can set the windows and column order etc. to you choice per router and save it. But if you have 1000's of routers this means at least even so many times you have to set it the first time. And then many times these settings get lost everytime again:
- firmware upgrade with reboot usually set your windows back to default
- every new router needs to be given the settings of your choice
- when working with many PC's settings made on one PC are overwritten when another PC closes window of same board later.
- when settings made and router disconnect for whatever reason before settings were save you can start all over again...
Just a sjabloon setting for the default winbox session would save us operators sooo much time and irritation. I've been asking this for years, hopefully this time it might be taken in consideration! :D
normis
Re: Winbox 3 RC
Thu Feb 19, 2015 12:20 pm
But the columns are saved, and their order, and their selection! This is why new Winbox has the sessions
WirelessRudy
Re: Winbox 3 RC
Thu Feb 19, 2015 2:21 pm
Well, maybe you give me a nice explanation then how it works because I have to redo them every time again. And with some 700 routerboards I still have 650 or so to go if this would have been a one time job anyway! (Each rb its own saved session?)
Explain to me how these sessions actually work? I work on at least 4 different PC's and swap around these all the time. I also have 4 employees with their terminals that at times need access. Or I jump behind their terminals. It irritates me the lot every time again I first have to set the info I need to my wish. If this could be made easy by just having a general winbox outlay like the default, but to my wish, I could have save myself half my life and be on the beach at least a month per year.....
If I save a 'session' at certain location, another PC can't reach that file and has to open it on his own. How to solve that? Save it to a cloud folder? But then I have to make sure all accounts on all PC's have access rights to that cloud folder. Which per default I don't want so I have to make exemptions.... pfff. It would have been so much more easy if we could just alter the default way winbox loader opens the routerboard. There is a default setting, why are we as user not allowed to change that to our own wish?
Who made the decision what information is shown per default?
[For instance, in almost every window that shows traffic it shows the Tx and Rx Packets. Info that in general is never needed. Most of us probably only want to see how much data goes over an interface, in General. Or the MTU setting? This kind of info usually is only needed with in depth troubleshooting, not day to day monitoring.]
normis
Re: Winbox 3 RC
Thu Feb 19, 2015 2:24 pm
I even made a video in the previous page: http://forum.mikrotik.com/viewtopic.php ... 35#p468535
WirelessRudy
Re: Winbox 3 RC
Thu Feb 19, 2015 2:52 pm
Well sorry, have you even been reading my post? This video shows 10% on what I am asking for. It just shows to 'auto save' some setting. It leave a lot of questions unanswered.
Where? Where is the default folder that winbox uses to save? How can I set that into something different and then what next time? Do I point winbox to that specific file to open again? Or did it remember where it is, even if this now on another PC? Is this easy? I don't think so. This is nice if you have time to setup cloud file and put the folder for each routerboard again and again in this folder with its file.
When I walk to my next PC I just want to open same router with the same settings. Do I now have to dig for the just created file on my previous PC? Nice, if you have some thousands of rb's....
If you call that "easy"? Well, what can I say.
Just a 'default ' winbox loader that can be adjusted by the user would make life so much easier.
My employees already decided not to use the new winbox loader anymore. In stead of making your life easier it just became much more complicated with it. Even the latests rc has so many changes that still not work, or new features that nobody asked for but replaced old regularly used ones. The more I myself work with it the more I develop the 'lingering back to the old'. And I am the one complaining about changes for winbox loader for a long time! :(
Not scoring any point from me so far.
chojrak11
Re: Winbox 3 RC
Thu Feb 19, 2015 3:02 pm
I think you desperately need some sleep and a doze of magnesium and/or antidepressant. The situation is reverse to what you're trying to imply here, Winbox is becoming useful after all those dark years, and honestly, to me your problems seem invented. If you were able to handle those 700 devices with winbox 2, I see no reason to not be able do it even better with winbox 3.
And for the features, I consider them valuable. All of them.
As you're saying, you're the only one who complain.
Easy, man.
(now I'm disabling reply notifications on this thread)
normis
Re: Winbox 3 RC
Thu Feb 19, 2015 3:07 pm
It doesn't matter, since you can move them with "Save As"
In Winbox loader you can load sessions from a dropdown, or show winbox where to look for session files:
Other PC has different session files. To have same layout on other PC too, you must send the VIW file to the other PC. You can use Dropbox to share the file. Winbox loader has "MOVE SESSION FOLDER" option in menu bar.
Have you tried dropbox? it is easy
how does this solve the sharing with other PCs? the sessions and other winbox settings are in the PC, not in the router.
please simply try to use Winbox 3 and see for your self. From your questions it seems you have not even seen the new options and menus
freemannnn
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Thu Feb 19, 2015 3:27 pm
i like the new winbox3 functions.
1.inline comments for me is the best so far. one click and everything is inline! so you have more data fit in screen.
2.i am saving my sessions to a dropbox folder. work in the morning, home at night...syncronizing session windows where i left them. nice!
3.and another thing, when i build a session windows the way i like it i save it with a name "example.viw" and after i load it to every sessions i want to look like this!
normis
Re: Winbox 3 RC
Thu Feb 19, 2015 3:50 pm
you can now "move session folder" to dropbox, from loader window menu
WirelessRudy
Re: Winbox 3 RC
Thu Feb 19, 2015 3:52 pm
I'm just going to reply on some of your stuff, to show you how wrong you are...;
You call that easy? Well, every winbox loader has a default setting that is always there, even if I go to the shop to buy a new PC and I upload a winbox loader the default settings are there. Not to my like but always the same. So somewhere in winbox program file it is set. Why can I not change that default setting in the program so all I need is one usb stick for instance and can use it on any PC in the world to open each of my routers with my preferred settings?
It could even be made easier if winbox would save settings for each user in the routerboard itself. Than even the usb stick is not needed. Just download anywhere in the world a winbox loader, login with the IP you know you have access and put your name and password and your preferred settings would be there. That's what I would call "easy".
If you have thousands of routerboards and 10ths of different users with the proposed setting you now have to create many thousands of files. That's easy yeah....
I have dropbox for about 3 years now. But that doesn't mean its always "easy". If you use many PC's and have some other that need access to only some of the files you need to do a lot of config to make it all happen smoothly. And to have it always working fast, even if you are off line, you need to have all the files syncd at your HD. Try that on a slim system if you have GB's to sync. And now I have to start putting winbox files in it too....? Nice if you have topnotch laptops and PC's with big and fast HDD's everywhere connected to the fastest network and you'r ok. Don't even think of doing it on a old device, it takes minutes to get what you want and it slows your PC down a lot. A major complaint about winbox anyway. Ever reading forums different than your own?
Dropbox is also not very friendly if you have to share same files with different users. Unless you buy the 'business' version every time a file is opened twice you'd create a copyfile. After a while you have several copies of same, but each possible slightly different. ....
I 'play' with it from the first day rc1 came out and have all updated to rc5 (Also because the 'old' winbox isn't available on the website anymore to download.) Some of the new options are not used by me simply because I need to 'work' on my network, not trying and find out what every function does do and can do. And as usual no manual provided!
Oh, last remark
from your previous post. You are saying all 219 posts made in this specific tread is only sheering the good work. Common man, this is an above average lively tread and most of the post made by others are either requests to do things different as they are now or further features that are asked for now winbox is really on the move after so many years. Don't tell me I am the only one complaining. We are at rc5 where rc1 was proclaimed by you the 23rd of January. So in 27 days we have seen 5 release now and 219 post only because nobody complains.... I think I rest my case. Can't tell an elephant to move if he thinks he is in the right position.
normis
Re: Winbox 3 RC
Thu Feb 19, 2015 3:58 pm
You write so long sentences for so simple questions. Did you really try what I suggested? It seems you did not, because your questions are the same.
yes, just connect to winbox, edit layout, use SAVE AS to your USB
What else did you expect? If the slim system has no internet, no HDD and no dropbox, we don't have telepathy sync yet, sorry. If you have good suggestion how to sync files without network and drive, let me know
you are saying all 219 posts made in this specific tread
this thread is about all RC versions, every one has new features and fixes, suggested by users. the new RC5 works great finally. I use it too.
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Thu Feb 19, 2015 4:14 pm
Normis,
Columns are not saved in "Torch".
This would be extremely desirable from one session to another !! :)
raffav
Re: Winbox 3 RC
Thu Feb 19, 2015 4:26 pm
hi
is any possible to add a "override" inline comments on windows like was in the version 2 too ?
so i can decide if i want inline comments in firewall, nat , address list. etc ....
normis
Re: Winbox 3 RC
Thu Feb 19, 2015 4:45 pm
Normis,
Yes, this is a known issue, somebody already reported in one of the previous pages, thanks!
davidnvega
Re: Winbox 3 RC
Sat Feb 21, 2015 12:00 am
I didn't read all replies above. But i think i can give some suggestions. First of all it is awesome how you improved Winbox in a few months. Congratulations!
* When i open Winbox it's great to have to input a master password, but it's available the last sesion saved with the password i had set. Anyone that open winbox can access to my last sesion.
* It would be nice to have a keyword shortcut like alt + tab for change between windows inside Winbox. It could be ctrl + tab.
* If we have a full screen option and the ability to modify windows size as we want i think that we could have a better use of the available space. May be if you include a hide option for the left menu could be useful.
* Lot of people prefers a dark background at least in console. It would be great to have an invert-color button in terminal, or a command. I prefer to use Putty for a terminal configuration instead of Winbox's terminal just because of this reason.
* Winbox still having suddenly closures.
* For wireless links we don't have a safe way to configure our devices. When we make some changes in our devices's settings we lose the link for some seconds and the Safe button it isn't useful. I think we need a button for test changes for a configurable interval before to apply them definitely.
I don't remember a few suggestions more in this moment. You are doing great! Thanks for listen your OS users!
yacsap
Re: Winbox 3 RC
Sat Feb 21, 2015 1:18 am
Where does it save the session layout? To the router or winbox's configuration file in windows?
sindudas
Re: Winbox 3 RC
Mon Feb 23, 2015 11:06 am
I've been using version 3 of Winbox from Beta versions until the last RC 5. Since the RC versions I appreciated the lack of some options in RouterOS v5.x -> v2.9.x , such as :
Main menu -> Wireless, PPP, IPv6, MPLS, Routing,...
Sub menu -> IP/DHCP Client, IP/DHCP Relay, IP/DHCP Server, IP/HotSpot, IP/IPsec,...
Regards,
Roberto.
normis
Re: Winbox 3 RC
Mon Feb 23, 2015 11:21 am
into the VIW file, on your PC. you can put the VIW file in anothe PC to have the same window layout when you connect somewhere (not just this router, any router)
yacsap
Re: Winbox 3 RC
Mon Feb 23, 2015 11:40 am
Thank you for your information, I really appreciate it!
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Mon Feb 23, 2015 3:05 pm
+1
fposavec
Re: Winbox 3 RC
Mon Feb 23, 2015 4:37 pm
One request :)
add auto port knocking for access core routers.
raffav
Re: Winbox 3 RC
Mon Feb 23, 2015 8:37 pm
Hello
Any possibility to create a mobile version of winbox, the api that is available is very limited to work with
coolex
Re: Winbox 3 RC
Mon Feb 23, 2015 11:39 pm
One more bug:
Winbox version: 3.0rc5
RouterOS version: 6.20-6.27
System => Schedule:
When add or first time open some task, I see only policy ,,FTP".
Second time open of task I see all.
Regards,
Kuba
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Tue Feb 24, 2015 12:00 am
One more bug:
System => Schedule:
Regards,
Kuba
Confirmed... :)
Hotz1
Re: Winbox 3 RC
Tue Feb 24, 2015 2:43 am
I have yet to characterize the steps leading to this behavior, but when I leave the original Winbox window open (using the "Open in New Window" option), after a while the device scan stops working and the "Refresh" button yields only an empty list. Quitting Winbox and restarting restores normal operation... for a while.
Also, it would be -nice- if the new window wouldn't automatically show up right on top of the list of devices.
And it would be -nice- if you could highlight multiple devices from the list, and open Winbox on all of them with one click on "Connect".
macsrwe
Re: Winbox 3 RC
Tue Feb 24, 2015 2:57 am
+1. Exact description of the behavior I've been seeing for weeks.
This is supposed to work. But what I see happen instead is that N useless copies of the address/"reconnect" window open quite reliably, interleaved in with 1-to-N copies of the desired Winbox windows, and the latter number is highly variable.
wrobli
Re: Winbox 3 RC
Tue Feb 24, 2015 6:53 am
Hi.
Is it possible to open more than one address at a time?
When We select 5 address with "shift" and open all 5 address in new window?
Manfred
Re: Winbox 3 RC
Tue Feb 24, 2015 6:29 pm
Hello
Seems that Winbox3 RC1 has a Bug in the Neighbors - Function, if there is more than 1 LAN - Adapter installed.
The Neighbor - List is incomplete !
Manfred
dada
Re: Winbox 3 RC
Tue Feb 24, 2015 6:56 pm
I would like to see a possibility to configure what interface(s) will be used to send neighbor discovery packets (and mac-telnet packets). I already saw that winbox sent discovery requests only through improper interface (Virtualbox virtual interface, etc). MT support said that I have to disable all the other interfaces but it is not the solution (why I should close the virtualbox to use the Winbox).
On my desktop Pc I have 2 ethernet cards - one attached to office network and the other I am using to connect to routerboards and other devices. I would be happy if I can say thaet the second ethernet should be used for neighbor discovery.
I hope it would solve many mysterious cases when the RB device is not showing in list of discovered devices (espacially important when the device has no RS232 port).
normis
Re: Winbox 3 RC
Wed Feb 25, 2015 10:21 am
Hello
Manfred
please make sure you run the latest version before reporting issues. RC5 is out for a while already, you are four versions behind
grisina
Re: Winbox 3 RC
Wed Feb 25, 2015 10:43 am
One feature request...
Is it possible when you have a session open you right click for example a firewall rule and you copy it. If you paste it in notepad or in terminal in same or another session it should appear the rule. So you dont have to export.
In simple copy paste rules from one winbox session to another!
this would be useful when testing rules and various configs in your home router you just copy-paste them to your customers!
miro263
Re: Winbox 3 RC
Wed Feb 25, 2015 11:10 am
chinese tea :D
3.13.0-45-generic #74-Ubuntu SMP Tue Jan 13 19:36:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
wine-1.7.34
Locale:
LANG=en_US.UTF-8
LANGUAGE=en_US
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC=sk_SK.UTF-8
LC_TIME=sk_SK.UTF-8
LC_COLLATE="en_US.UTF-8"
LC_MONETARY=sk_SK.UTF-8
LC_MESSAGES="en_US.UTF-8"
LC_PAPER=sk_SK.UTF-8
LC_NAME=sk_SK.UTF-8
LC_ADDRESS=sk_SK.UTF-8
LC_TELEPHONE=sk_SK.UTF-8
LC_MEASUREMENT=sk_SK.UTF-8
LC_IDENTIFICATION=sk_SK.UTF-8
LC_ALL=
dada
Re: Winbox 3 RC
Wed Feb 25, 2015 5:44 pm
Winbox 3.0rc5 sometimes doesn't offer Wireless in left side menu (the device has wlan device). I saw it in two cases yet. Each was older ROS (5.21 last time) and in the first case Wireless menu appeared when I started Winbox again. In the second case I was not able to see the Wireless menu even after Winbox restart...
noyo
Re: Winbox 3 RC
Wed Feb 25, 2015 6:20 pm
@dada You're using Linux + Wine 1.4.1?
When winbox for Linux? or linbox? :)
dada
Re: Winbox 3 RC
Thu Feb 26, 2015 7:52 am
no I am using Winbox on Windows 7
WirelessRudy
Re: Winbox 3 RC
Thu Feb 26, 2015 11:55 pm
Sometimes rc5, even on ros 6.27, doesn't show 'comment' field in wireless registration tables too.
Need to close the wireless window to open it again and its there......
Abdock
Re: Winbox 3 RC
Sat Feb 28, 2015 6:54 am
I upgraded from rc3 to 5, and all my saved sessions were gone, had to create again for every router, except the ones one ver 5x. Is this normal behaviour ? it had happened earlier but I did not bother and created all again, and now again.
BartoszP
Re: Winbox 3 RC
Sat Feb 28, 2015 1:29 pm
Fresh Windows 7 install. No AV programs, no VMWare....anything non-Windows.
Winbox RC5...MAC connection directly to RB433 @ 6.27 with Ethernet, no switches etc.
Several seconds after start...bang...disconnected.
athlonxp78
Re: Winbox 3 RC
Sun Mar 01, 2015 1:45 am
Exactly same issue here...
Normis!!!!!!!!!!!!!!!!!
noyo
Re: Winbox 3 RC
Sun Mar 01, 2015 11:34 am
Run winbox 2 or 3 beta, export to file and import in winbox3 rc
Manfred
Re: Winbox 3 RC
Mon Mar 02, 2015 1:16 pm
Hello
Manfred
Problem still exists with Winbox3 RC5 !
Probably there should be a possibility to select the Interface ( like in Router OS ) which to be used for Neighbor - Scan !
Manfred
Abdock
Re: Winbox 3 RC
Mon Mar 02, 2015 6:59 pm
I have also noticed this, if for some reason connection is lost, when i try again the windows are messed up, they are kind of minimized, from the normal size, anybody experienced this ?
athlonxp78
Re: Winbox 3 RC
Tue Mar 03, 2015 2:45 pm
Yep, i can confirm that :D
dada
Re: Winbox 3 RC
Thu Mar 05, 2015 3:31 pm
3.0rc5 - I have problems with BTest - when I measure speed I often see that the graph is showing bad value (the one in the box inside the graph area) and the graph itself is ether not updated or overwrites graph from the older test.
Anybody else with the same problem?
leoservices
Trainer
Trainer
Re: Winbox 3 RC
Fri Mar 06, 2015 1:47 am
Hello, would like to make a suggestion to the developers of Winbox; a box for the port field; easy to read / use for some users.
mdenadal
Re: Winbox 3 RC
Fri Mar 06, 2015 12:12 pm
Same problem here.
Basdno
Re: Winbox 3 RC
Sat Mar 07, 2015 2:20 pm
What really needs to come back is the winbox session to stay on the desktop, even if the routerboard in itself is disconnected.
There are several occasions an update or change in config makes a board to disconnect. Under 'old' winbox I still had the session on my desktop. I just moved away the window telling me its disconnected and could still browse the 'historic' config of an disconnected router to see where did I go wrong. In wireless it helps me to 'fish' back a CPE that became disconnected from AP because I incorrectly changed the 'connect-to' parameters for instance. Or the scan frequency.
Or; when you download a automated upgrade script that ends with a reboot or just makes a unit disconnect (wireless) because some settings are written again, or written wrong, I really would like to see in the terminal window where the script went wrong (the 'red' blocked commands).
But in new winbox this opportunity to save you from a disaster (or help you to remember what you'd actually did) is gone.
Immediately when the board disconnects the window is closed and replace by the winbox loader with the 're-connect' option.
Even if I can re connect, I can't see anymore where the script actually went wrong. I have to load it again but make sure this time the router doesn't disconnect. If the disconnection is a result of a wrong parameter in the script (he ho, every new ROS comes with script language changes. So it happens again and again...) you end in an endless loop of loading the script > disconnect > try to find the error and load the script again > disconnect > try to find .... etc. etc. etc.
So PLEASE, let the winbox window of closed unit stay!
There can be a message the unit actually is disconnected and a button to re-connect if you'd want.
I didnt see any1 commenting on this suggestion from WirelessRudy, but I want to STRONGLY second it!!
The ability to look at open windows and possibly copy out f.ex. SSIDs etc. is a VERY nice feature of v2, and has saved me more then once if I did something wrong intentionally during config or by accident!
BIG +1 from me!!! :)
Basdno
Re: Winbox 3 RC
Sat Mar 07, 2015 2:32 pm
Want to second WirelessRudys original post here too, too often I find myself looking for something in log and when I find it all I should need to do was copy that IP/MAC-adress or whatever and paste it into the rule/connectlist/accesslist whatever and it would have been done in 3 seconds.
As it works now I have to write it down manually, making sure I read right line in log etc. (But atleast after freez button came I can stop log from moving). But still, copy&paste from log would make so many situations easier!
Another BIG +1 from me today! :)
dada
Re: Winbox 3 RC
Sun Mar 08, 2015 12:01 pm
/log pri
is a way how to get copyable log lines. Although if the log is larger it is not too much comfortable.
honzam
Re: Winbox 3 RC
Mon Mar 09, 2015 4:44 pm
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Mon Mar 09, 2015 6:07 pm
Can someone post the rc6 change log ? I can't download it at the moment.
Thanks,
-tp
macsrwe
Re: Winbox 3 RC
Tue Mar 10, 2015 6:38 am
After configuring and playing with the viw feature for a while, it's apparent that it doesn't do what I was hoping it would.
There are at least two levels of configuration needed, and they serve different purposes.
The first (let's call it "format") is to modify the preferences of which fields should appear by "default" in the various Winbox windows (e.g., Firewall, Connect List, Mangle, Registration, Simple Queues, and so on) how wide the columns should be, and their order. A company might well want to standardize this behavior for every router they own, and as new windows are customized or old windows are customized differently, they would want the changes to be automatically applied to all other routers next time they are opened.
The second (let's call it "content") is to keep track of what windows were open when the router was last closed. For example, the set of "default" windows on a core router wouldn't be the same set as you would want for a CPE. This would vary from individual router to individual router.
The problem is that when you use the viw mechanism to achieve a common format, you also impose common content, which you don't want.
It would be nice if we could have both benefits instead of having to settle for only one or the other.
By the way, I mentioned column "order" above. Several earlier postings talk about preserving the "order" of the columns, but I suspect they really meant the presence or absence of columns. In a couple of cases, I tried actually reordering columns left or right of where they show up by default, to create a display that was easier for me to interpret, and I couldn't find any way to move them. Is there a way, and I'm just missing it?
honzam
Re: Winbox 3 RC
Tue Mar 10, 2015 12:23 pm
What's new in v3.0rc6:
*) allow to inline comments per table bases as well;
*) remember table filters in current sessions;
*) remeber Torch window column sorting order & visibility;
*) by default hide all passwords;
*) remember that session was <own> on reconnects;
urknall
Re: Winbox 3 RC
Tue Mar 10, 2015 12:54 pm
In IP -> Firewall i am not able to move rules up an down via drag & drop...
EDIT: Addidionally the order is not sorted like in old winbox.
EDIT 2: Ok, solved: After resorting the rules with the number column i am able to drag and drop again :)
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Tue Mar 10, 2015 2:54 pm
Can someone post the rc6 change log ?[/quote]
*) remember that session was <own> on reconnects;[/quote]
It saves the columns in "Torch"...!! Holy Crap :lol: :lol: :lol:
Thanks Tik guys !!!
-tp
freemannnn
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Tue Mar 10, 2015 4:35 pm
any chance of moving the columns left or right inside a window.
fo example in dhcp server-leases i want the active address column to be the first.
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Tue Mar 10, 2015 4:53 pm
I'm experiencing a lot of Winbox crashes when opening existing templates that worked just fine under v3rc5. Has anyone had this issue?
-tp
ndbjorne
Winbox 3 RC 6 (same problem with rc 5)
Tue Mar 10, 2015 11:23 pm
Not working under wine: it returns
on console:
[b]wine winbox.exe[/b]
creating Window Class routeros_null
creating Window Class routeros_connect
creating Window Class routeros_dbl_canvas
loadConfig C:\users\ndt\Application Data\Mikrotik\Winbox\Addresses.cdb
 discovery started
rescaning
ConnectWindow::onConnect
discovery stopped
sending first handshake
doing handshake
disconnect
~Connection
 discovery started
rescaning
of course no problem if I run winbox 2.18
I removed all files in working dir (but winbox) and after quitting I found a 350 bytes .tmp file.
Anyone else?
Regards
Cha0s
Re: Winbox 3 RC
Wed Mar 11, 2015 1:50 am
On old Winbox, when run on computer with multiple monitors it would remember the monitor on which the winbox loader was run the last time and reopen it on the same monitor.
Also when connecting to a router it would also remember on which monitor was last loaded for that specific router.
My setup is 3 monitors. I want winbox loader to always load on the 2nd monitor (the middle one) and depending on which router I connect it will open on whatever monitor I left it at last time I logged in to that router.
This is how it works on old Winbox.
On the new Winbox the loader will load on whichever monitor the winbox was last closed on.
It remembers on which monitor to load every router I log in to, but the loader will open on which ever monitor I last exited winbox from instead of remembering to open it on the middle monitor (in my case).
Is it possible to revert this behavior back to how it used to work on Winbox2?
freemannnn
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Wed Mar 11, 2015 4:20 pm
when i run winbox, main window starts in my middle of the screen. thats ok. i want it there.
but when winbox shutsdown unexpected or by disconection. next time i open it, it opens on the top left of my screen.
raffav
Re: Winbox 3 RC
Wed Mar 11, 2015 9:12 pm
Hi
for me on the winbox 3rc6 the key shortcut E, D, R, dell is not working any more
someone with this bug?
macsrwe
Re: Winbox 3 RC
Wed Mar 11, 2015 9:28 pm
Hi
This may not be a bug -- it may have been done on purpose due to feedback, though I didn't see any announcement of it.
normis
Re: Winbox 3 RC
Thu Mar 12, 2015 10:21 am
Yes, it was done on purpose, we will invent some more secure shortcut or find another solution. "R" was just too easy to press accidentaly
raffav
Re: Winbox 3 RC
Thu Mar 12, 2015 5:31 pm
Ok
thanks for answering
maybe a ctrl + dell with confirmation ?
Some time ago i read in the forum that the winbox loader will be replaced this is valid or not ?
BoingoNOC
Re: Winbox 3 RC
Thu Mar 12, 2015 9:10 pm
Missing Features in new Winbox, please see attached screenshots
Allot of these features that used to be there we use everyday.
Any assistance would be appreciated.
macsrwe
Re: Winbox 3 RC
Fri Mar 13, 2015 2:22 am
Although I welcome this change, I must admit I was a little flummoxed today when I actually had to delete an entry on purpose, and was no longer sure how to do it. :-) I finally thought of right-clicking, which I suspect is the only remaining way.
I should add that when you right-click, the contextual menu still documents the shortcut that no longer exists.
macsrwe
Re: Winbox 3 RC
Fri Mar 13, 2015 2:25 am
These features show up in my routers. Is it possible you neglected to load the ppp and wireless RouterOS packages on that router?
macsrwe
Re: Winbox 3 RC
Fri Mar 13, 2015 5:47 am
Here's a strange bug (don't know whether it's new in Winbox 3)...
The IP Pool window shows a comment field, but /ip pool has no comment property!
BartoszP
Re: Winbox 3 RC
Fri Mar 13, 2015 3:24 pm
See the picture...same ROS, same boards, WinBox RC 6
normis
Re: Winbox 3 RC
Fri Mar 13, 2015 3:27 pm
What is the issue here exactly? Please post full problem description
BartoszP
Re: Winbox 3 RC
Fri Mar 13, 2015 3:31 pm
Different number of displayed fields. No Frequency. Different names.
normis
Re: Winbox 3 RC
Fri Mar 13, 2015 3:43 pm
Sorry, I didn't see the image on the right before. OK, I will look into it
BartoszP
Re: Winbox 3 RC
Fri Mar 13, 2015 4:24 pm
The only difference I see is not used but installed CAPSMan on the right side.
BoingoNOC
Re: Winbox 3 RC
Fri Mar 13, 2015 6:55 pm
The older version works fine.
The new version shows those options when I first open in for the day , it seems, then they are gone.
Any ideas
DLNoah
Re: Winbox 3 RC
Fri Mar 13, 2015 8:48 pm
The boards are not running the same wireless package.
The one on the left is running the old wireless package (no CAPsMAN present in the menu bar).
The one on the right is running wireless-fp (CAPsMAN present in the menu bar). Wireless-fp uses the new interface designed for 802.11ac support, which changes how it reports channels and other similar information.
BartoszP
Re: Winbox 3 RC
Fri Mar 13, 2015 9:02 pm
Thanks...I have just found/verified it :-)
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Sat Mar 14, 2015 10:38 pm
Winbox version 3.0rc6
RouterBoot fw: 3.22
RouterOS ver.: 6.27, 6.27, 6.28rc6
Device: RB750G, SXTG-5HPacD, SXT Lite2
If repeatedly run profile from winbox (Tools->Profile) - winbox will be crash.
I can confirm this as it has been the source of all my Winbox 3.0rc6 crashes. Till they get a fix, simply do not use it.
Other than that it seems to work great.
I do wish that "Torch" would remember the selection of the "collection" items that I chose, instead of just the defaults each time it starts.
Also, remember the last interface I selected too.
I DOES keep getting better each time though.. 8)
avlipa
Re: Winbox 3 RC
Mon Mar 16, 2015 10:36 pm
Same thing with Tools->Ping. The crash can occur even if I try to open/close other windows (not from tools menu) after closing Tools->Ping.
macsrwe
Re: Winbox 3 RC
Tue Mar 17, 2015 11:55 pm
Here's one I haven't seen posted previously.
I often use Winbox to perform large drag-and-drop file transfers into routers, most often a half dozen or so packages of a new RouterOS release, that take appreciable real time to copy. Under Winbox 2, while the transfer was going on, I could move the progress window aside, view other Winbox panels, maybe open or close some functions. Under Winbox 3, not only can't I do any of that, I can't even bring the main Winbox window to the front or move it around the screen.
Trezona
Re: Winbox 3 RC
Thu Mar 19, 2015 1:29 pm
Yes i have this same problem!
strods
Re: Winbox 3 RC
Fri Mar 20, 2015 8:19 am
Trezona, avlipa, alexboroda - We repeated Winbox crash in our lab. It will be fixee in upcoming versions.
Trezona
Re: Winbox 3 RC
Fri Mar 20, 2015 8:27 am
Thanks very much.
zikachu
Re: Winbox 3 RC
Fri Mar 20, 2015 1:52 pm
rc6 closed by itself when you moving sections. rc5 more stable than this.
normis
Re: Winbox 3 RC
Fri Mar 20, 2015 1:54 pm
t is closed by itself when you moving sections. rc5 more stable than this.
which sections did you change ?
zikachu
Re: Winbox 3 RC
Sat Mar 21, 2015 3:29 pm
in wireless registration tab. time to time want to mac telnet or ping or double click the client it is closed by itself in rc6.
in rc5 there is no problem like that.
kraic
Re: Winbox 3 RC
Sat Mar 21, 2015 5:20 pm
Crashes all time
marlab
Re: Winbox 3 RC
Sun Mar 22, 2015 2:29 pm
I run 3.0rc6 on OS X, under Wine. It's pretty stable, and session save works pretty well, still - I do not trust it :lol: For example, I just noticed the Leases list on IP/DHCP Server sometimes show incomplete list. Then I need to enable/disable inline comments to see the full list again. I have RB2011UiAS-2HnD, and OS 6.27
garlicbulb
Re: Winbox 3 RC
Mon Mar 23, 2015 8:03 am
Whatever happened to the ability to adjust column widths on the log screen? I think it worked in b2 but it certainly doesn't work for me in b3
Hotz1
Re: Winbox 3 RC
Mon Mar 23, 2015 9:25 pm
In addition to the neighbor list not populating after running for a while (the "Refresh" button returns an empty list), when you do run Winbox, sometimes when you close a Terminal window within the Winbox session, the entire session closes.
This is with 3.0rc5, running on Win7.
mboy
Re: Winbox 3 RC
Fri Mar 27, 2015 5:56 pm
Please add import from the csv file.
freemannnn
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Sun Mar 29, 2015 4:57 pm
a double click in the sides of the title column could resize column to fit content. like in excel.
garlicbulb
Re: Winbox 3 RC
Mon Mar 30, 2015 8:05 am
No title row on the log screen
mboy
Re: Winbox 3 RC
Mon Mar 30, 2015 1:40 pm
I have more than 500 connections and manually add the address book is unrealistic.
solaoxo
Re: Winbox 3 RC
Tue Mar 31, 2015 4:19 am
winbox 3 rc6 difficult to use, stable, always turn off automatically, or rc5 good, very stable, but I did not save, I do not know now where can be downloaded to.
Clauu
Re: Winbox 3 RC
Fri Apr 03, 2015 8:21 pm
Hello, where is the 'hide password' feature like in old winbox? Does this v3 has such thing?
raffav
Re: Winbox 3 RC
Fri Apr 03, 2015 9:50 pm
yes
it was moved to settings menu
Clauu
Re: Winbox 3 RC
Fri Apr 03, 2015 11:23 pm
Doh silly me, thanks
empwebs
Re: Winbox 3 RC
Sat Apr 04, 2015 3:53 am
Just want to share something that oddly happened to me while using rc5 the other day on a ccr1009. DNS setting suddenly got deleted and DNS resolution timeout was set to 0.
Caused me a lot of panic... Until I realized that the resolution time was 0!
pukkita
Trainer
Trainer
Re: Winbox 3 RC
Sat Apr 04, 2015 4:33 pm
A suggestion I already told to Sergejs and Normunds (I believe) at the MUM: being able to switch between opened windows inside the same winbox session with some kind of key combo, CTRL-Tab already switches between tabs, something like shift-tab, ctrl-shift-tab or anything not too contorted :)
Clauu
Re: Winbox 3 RC
Sat Apr 04, 2015 4:49 pm
Ok so at the moment of accesing tools-profile my winbox sessions instantly closes.. anyone with the same problem?
Clauu
Re: Winbox 3 RC
Mon Apr 06, 2015 2:07 am
Ok so now doesn;t matter what i do my session will close instanlty after pressing the connect button.. what the hell :|
Taylor
Re: Winbox 3 RC
Mon Apr 06, 2015 8:36 am
Same here
TomosRider
Re: Winbox 3 RC
Mon Apr 06, 2015 1:57 pm
Just want to say, great work guys....salute to MIkrotik staff!
macsrwe
Re: Winbox 3 RC
Tue Apr 07, 2015 12:12 am
I know it's late in the product cycle, but...
One thing that would make a lot of my work easier is a simple facility (right-click menu option, or whatever) that would do a reverse DNS on a selected IP address.
marcelbohmer
Re: Winbox 3 RC
Thu Apr 09, 2015 7:47 pm
Hi Guys
Is there a way to speed up winbox, its very sluggish when applying settings or reading firewall rules. It also crashes if the info takes to long to load. It cant be the connection as it does it on all router even it connected directly.
marcodefreitas
Re: Winbox 3 RC
Sat Apr 11, 2015 10:22 am
I have some problems using Winbox 3.0rc6 with MikroTik 5.26. The MPLS, IPv6 and Routing menus don't show:
macsrwe
Re: Winbox 3 RC
Sun Apr 12, 2015 12:09 am
Bug has been reported several times -- seems to be tied to router not running ROS v6. Saw it myself today for the first time on newly purchased unit shipped with 5.24 -- wanted to access system routerboard menu to reboot to netinstall, and had to use terminal window to change setting.
avantwireless
Re: Winbox 3 RC Dangerous....
Sun Apr 12, 2015 3:58 am
Winbox DANGEROUS... Today I was working on a customer and, while the interface page was open tapped the d key. That disabled the highlighted interface. ONE key stroke, no Alt, no Ctl, no other input. In this case it was the wireless interface on a customer CPE and now it is down. I see this a such a fundamental flaw in UI that it is laughable. THIS is Unacceptable.
macsrwe
Sun Apr 12, 2015 4:06 am
The "naked key" UI issue (which I believe exists in the production Winbox as well) was fixed (removed) for the Winbox address window in beta 3, but now it sounds like it also exists in other contexts. I was entirely unaware that naked key commands existed in the router window itself. That might explain a number of similar mysterious wireless disablings I have experienced myself (without realizing I may have brushed the keyboard).
honzam
Re: Winbox 3 RC
Wed Apr 15, 2015 10:48 am
Cha0s
Re: Winbox 3 RC
Wed Apr 15, 2015 3:05 pm
What happened to RC7? Did I miss something?
Also is there any changelog available for RC8?
rtlx
Re: Winbox 3 RC
Wed Apr 15, 2015 5:09 pm
Digital Signature
Dear Mikrotik, please sing new Winbox with digital signature, so we can be sure that executable comes from you. It is called Microsoft Authenticode.
Make sure that it is mature signature, not old MD5/SHA1 based. SHA-256 is today's standard for certificates. It is not expensive, especially shouldn't be expensive for you.
You can also do it like Microsoft did: SHA-1 for compatibility with older systems and SHA-256 for newer:
Think also about PGP signature for software relases (download page) - this can be done without any expenses!
Also use mature RSA key length, at least 2048 bits, but 4096 bits would be better (it also doesn't cost you a penny!) and use at least SHA-256.
And the last thing, please attach SHA-256 cheksums for downloads. MD5 is really obsolete for today. Every Linux distribution (and even new Windows, via PowerShell) allows users to calculate such hashes.
Thank you very much for understanding this very important issue.
Abdock
Re: Winbox 3 RC
Wed Apr 15, 2015 5:18 pm
With the new rc6, keys like E and D do not work, has this been changed ?
Thanks,
23q
Re: Winbox 3 RC
Sun Apr 19, 2015 3:37 pm
normis
Re: Winbox 3 RC
Mon Apr 20, 2015 6:23 am
Thanks,
yes, there were bug reports here to disable these keys, since it was too easy to disable and remove interfaces and rules. we will think of a compromise, maybe introduce new shortcuts, like alt+shift+e or something, so that everybody is happy :)
jarda
Mon Apr 20, 2015 6:51 am
Good idea. Hope ctrl + c (x, v) will operate normally everywhere within winbox even in telnet window opened from winbox.
Abdock
Re: Winbox 3 RC
Mon Apr 20, 2015 9:28 am
I hope it works over RDP ! as the standard D, E were way good and am very much used to them now !
may be introduce something with can change these, depends on what a person likes, ctrl / or direct.
strods
Re: Winbox 3 RC
Mon Apr 20, 2015 1:40 pm
New Winbox beta version has been uploaded to download site:
*) added RoMON support;
*) show default values in CAPSMAN settings;
*) fixed crash when reopening ping or profile window;
*) added advanced mode.
zikachu
Re: Winbox 3 RC
Mon Apr 20, 2015 2:16 pm
Winbox Rc9 not working here! (windows7 ultimate)
Log Name:      Application
Source:        Application Error
Date:          20.04.2015 2:08:09 PM
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Computer
Description:
Faulting application name: winbox.exe, version: 0.0.0.0, time stamp: 0x552d12d0
Faulting module name: ntdll.dll, version: 6.1.7601.18247, time stamp: 0x521ea8e7
Exception code: 0xc0000374
Fault offset: 0x000ce753
Faulting process id: 0x3cc4
Faulting application start time: 0x01d07b5a43d51c66
Faulting application path: C:\Users\Computer\Desktop\winbox.exe
Faulting module path: C:\Windows\SysWOW64\ntdll.dll
Report Id: 86a2f609-e74d-11e4-a406-6036dd160ebc
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2015-04-20T11:08:09.000000000Z" />
    <EventRecordID>5358867</EventRecordID>
    <Channel>Application</Channel>
    <Computer>Computer</Computer>
    <Security />
  </System>
  <EventData>
    <Data>winbox.exe</Data>
    <Data>0.0.0.0</Data>
    <Data>552d12d0</Data>
    <Data>ntdll.dll</Data>
    <Data>6.1.7601.18247</Data>
    <Data>521ea8e7</Data>
    <Data>c0000374</Data>
    <Data>000ce753</Data>
    <Data>3cc4</Data>
    <Data>01d07b5a43d51c66</Data>
    <Data>C:\Users\Computer\Desktop\winbox.exe</Data>
    <Data>C:\Windows\SysWOW64\ntdll.dll</Data>
    <Data>86a2f609-e74d-11e4-a406-6036dd160ebc</Data>
  </EventData>
</Event>
strods
Re: Winbox 3 RC
Mon Apr 20, 2015 2:39 pm
Please try to delete Winbox files.
You can do it by deleting folder: c:/users/xxxx/Application data/Mikrotik
After you delete these files, please try to reconnect.
Remember that if you will delete these files, then sessions and saved addresses also will be deleted. If you need to save them, then export address list to the file and save it into safe place. Also copy out sessions which you will need to use. After you have deleted files and reconnected to router import address list back and put needed sessions back into their folder.
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Mon Apr 20, 2015 3:02 pm
I have the same problem too. But I don't see error it just closes after trying to connect.
I have tried deleting settngs but that doesn't help. Actually mine are here : C:\Users\xxx\AppData\Roaming\Mikrotik.
Also see attached image how it always starts. The size is always that small, it does not remember size when closed even though it remembers being maximised.
P.S. Even though I don't see the error here is what I have in logs :
Faulting module name: ntdll.dll, version: 6.1.7601.18798, time stamp: 0x5507b3e0
Fault offset: 0x000cea0b
Faulting process id: 0x2a20
Faulting application start time: 0x01d07b613a095c40
Faulting application path: D:\Files\winbox.exe
Report Id: 7efb2f5a-e754-11e4-a133-005056c00008
strods
Re: Winbox 3 RC
Mon Apr 20, 2015 3:07 pm
CyberTod - Which version of RouterOS is installed on your router? As for size issue - we will fix it in next rc version.
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Mon Apr 20, 2015 3:31 pm
I have tried on routerboards with v6.28
kikikaka
Re: Winbox 3 RC
Mon Apr 20, 2015 4:02 pm
winbox 3.0rc9 crash in win7 ultimate x64 after clicking "connect"
Łukasz
Re: Winbox 3 RC
Mon Apr 20, 2015 4:48 pm
I have the same problem - Win7 Home Premium.
Abdock
Re: Winbox 3 RC
Mon Apr 20, 2015 7:54 pm
all my names and groups are lost on the update, how can i get tthem back ? that was a hard work lost !
can we download the rc6 or earlier then 9. i think even 5 was ok.
WirelessRudy
Re: Winbox 3 RC
Mon Apr 20, 2015 8:57 pm
What is "RoMON"
Łukasz
Re: Winbox 3 RC
Tue Apr 21, 2015 12:25 am
What is "RoMON"
http://wiki.mikrotik.com/wiki/Manual:RoMON
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Tue Apr 21, 2015 2:04 am
What is "RoMON"
Hopefully, someone will describe it in greater detail at the Miami-MUM this week. 8)
Hotz1
Re: Winbox 3 RC
Tue Apr 21, 2015 5:09 am
What is "RoMON"
As usual, the manual offers a thorough description of how the controls work--but not a lot of insight into what the feature does or how it might be useful. :?
strods
Re: Winbox 3 RC
Tue Apr 21, 2015 9:23 am
CyberTod, zikachu, kikikaka and Łukasz - Is it possible that winbox has some kind of compatibility configuration enabled or something like that? I have tested at my workplace and at home. All the time Winbox works and connects when used in Windows 7 64 bit.
RoMON stands for "Router Management Overlay Network". This option allows for you to connect to routers after multiple hops in your routed network.
For example, if you have computer 192.168.88.1 and router with address 192.168.88.254 then you always were able to establish direct Winbox connection. Now if you configure RoMON and your router has neighbour which is reachable through address in another subnet, for example 172.16.1.0/24, then now you will be able to connect to this router directly from your computer. All routers in path have to have RoMON enabled and use same secret.
joegoldman
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Tue Apr 21, 2015 2:09 pm
I'm having similar problem to above running under WINE on Ubuntu Linux - window opens small, the 'Autosave', 'Group', 'note' and other fields are missing, and it only shows some columns in the connect database - can re-add them but it doesnt remember them. Sticking to older rc for now as rc9 feels unusable
strods
Re: Winbox 3 RC
Tue Apr 21, 2015 2:24 pm
joegoldman - Go under Tools menu in Winbox loader and switch to Advanced mode. Then all options will be available.
skillful
Trainer
Trainer
Re: Winbox 3 RC
Tue Apr 21, 2015 2:32 pm
A work around for those experiencing winbox3.0RC9 crash. Check mark "Open in New Window" before click on connect.
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Tue Apr 21, 2015 2:36 pm
Thank you. That workaround works. Actually I remember a similar problem with some previous version, but don't remember was it needed to be checked or not.
On the bright side I notice that the initial connect to the router is much faster. Am I the only one with this problem ? :)
P.S. Another problem - if used from Dude it does not load session settings. If used separately it works fine.
strods
Re: Winbox 3 RC
Tue Apr 21, 2015 3:12 pm
I noticed that on screen shot, which was posted earlier, connection to router is started from Managed tab. We have tried to reproduce this Winbox crash here locally and no luck. Please someone who can not establish connection to router describe what is saved for this specific router in address list (Group, Note, "Keep password", "Secure mode", etc.).
Łukasz
Re: Winbox 3 RC
Tue Apr 21, 2015 4:06 pm
For me it works to. Thank You.
@strods
No I don't use any comaptible configuration. I downloaded like a new file, saved as winbox_3.0rc9.exe. I did not use "Check for updates" option in winbox menu.
WirelessRudy
Re: Winbox 3 RC
Tue Apr 21, 2015 5:08 pm
This new version rc9 is very unstable. Worse than rc6 I tried up to now... Up to an extend I don't even use it anymore... back to old winbox loader (and miss the very useful improvement that ARE made...) :(
Many times when I want to open a router by its IP it just flash opens to close immediately. Sometimes I have to try several times. Old winbox loader opens without any problems. And if I enable "open winbox in new window" checkbox on a full desktop after a while I have many of these open. Also when you have many sessions running but due some failure connectivity is lost to all they all open a new winbox loader window after reconnecting the closed sessions. I end up with many open winbox loaders on my desktop. Have now to close the ones not in use.
Many times when I click on a setting inside an open winbox session it makes the hole winbox session to close. Open the session again and it works. But this happen so often that is really becomes an irritation.
We have it on several types of routers, on different PC's (all Win8).
One other issue still not solved; When a router disconnects for whatever reason, after a while the 'dead' winbox session also closes. Very inconvenient. Many times when trouble shooting you need to see what the settings in a router were...
Example: When running a wireless scan in a remote (wireless connected) router you can run the scan by running it in the terminal window of the winbox session of that router.
Sometimes links to remote router are very unstable and thus connect regularly or only a 2 or 3 sec scan will make the session survive.
But as long as I can see the result in the terminal I at least can see what the result is.
Now, many times the router closes the session after a second and I loose all the info. It hardly give me enough time to read the outcome. In the old winbox loader this doesn't happen. First is doesn't loose the connection that easy, and when it does at least the window stays open. Move the "winbox session is closed" notification and you can still read all the data.
Now I developed a routine of immediately creating a screendump before the window is lost again. At least I can still read it. And at the end of a day of hard work I have to clean my dropbox screendump archive since its full of screen dumps made that day!
Sorry, but I really can't see the improvement in this...... :(
Another, minor but irritating issue; When you have several winbox sessions open and you are in the process in opening a new one (typing a new IP for instance in the loader) while at that same moment one of the open session is closed, it 'steals' the active window and suddenly you are typing in another loader session than you think you are. But since this is a closed session waiting to be opened again it won't respond you what you typed and you are all getting messed up.
Very irritating behaviour.
This winbox 'tool' is supposed to be a tool to use in troubleshooting networks. Now it seems I am more engaged in troubleshooting the tool itself. ........
kikikaka
Re: Winbox 3 RC
Tue Apr 21, 2015 5:39 pm
tried removing cached files, re-download winbox.exe ...etc... still crash
But the trick "Open in new windows" works.
I remember the 3.0rc2 also crash similarly. It is fixed in rc3 ( or which version... .. i cant remember clearly..)
crash info:
Problem signature:
Problem Event Name: APPCRASH
Application Name: winbox.exe
Application Version: 0.0.0.0
Application Timestamp: 552d12d0
Fault Module Name: StackHash_f821
Fault Module Version: 6.1.7601.18247
Fault Module Timestamp: 521ea8e7
Exception Code: c0000374
Exception Offset: 000ce753
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: f821
Additional Information 2: f821734351f2347e1d6446ab1ffd59a2
Additional Information 3: de5b
Additional Information 4: de5ba675ba9b2c213f8e3b947096a688
noyo
Re: Winbox 3 RC
Tue Apr 21, 2015 6:38 pm
Debian 7.8
Wine-1.4.1
In RC9 does not remember selected show columns, window size. :/
does not help remove the user/Mikrotik
joegoldman
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Wed Apr 22, 2015 2:04 am
Beautiful, didn't know that option was there with it turned off by default, that has brought back what I needed though.
It now remembers my window size and columns perfectly.
strods
Re: Winbox 3 RC
Wed Apr 22, 2015 8:42 am
joegoldman, noyo - Simple mode uses only few columns so they are hidden/shown by default. If you use Advanced mode, then you can manage columns as you like.
ddt
Re: Winbox 3 RC
Wed Apr 22, 2015 7:52 pm
The advanced mode definitely threw me off too, until I found it under the menus.
Also, it would be nice if the RoMON agent fields were toggle-able-- like "show Romon fields?" in the menu or something. I don't know if I will ever use RoMON so it would be nice to hide it.
Using v3.0rc9 on Win7 x64, I also want to confirm that I can't get Winbox to connect to anything unless I check "open in new window." Unless that is checked, upon clicking connect it just closes Winbox. I deleted all of my preferences under my Roaming folder of AppData, so this isn't an issue of it trying to use old preference files or such.
Something else I've noticed with version 3, going back to rc3 (and maybe before): if I am running a traceroute or ping test through the terminal, this is how it should look:
 SEQ HOST                                     SIZE TTL TIME  STATUS
  180 130.211.143.185                            56  43 50ms
  181 130.211.143.185                            56  43 48ms
  182 130.211.143.185                            56  43 51ms
  183 130.211.143.185                            56  43 48ms
  184 130.211.143.185                            56  43 49ms
  185 130.211.143.185                            56  43 48ms
  186 130.211.143.185                            56  43 48ms
  187 130.211.143.185                            56  43 49ms
  188 130.211.143.185                            56  43 48ms
  189 130.211.143.185                            56  43 49ms
  190 130.211.143.185                            56  43 48ms
  191 130.211.143.185                            56  43 48ms
  192 130.211.143.185                            56  43 49ms
  193 130.211.143.185                            56  43 48ms
  194 130.211.143.185                            56  43 95ms
  195 130.211.143.185                            56  43 48ms
  196 130.211.143.185                            56  43 48ms
  197 130.211.143.185                            56  43 92ms
  198 130.211.143.185                            56  43 86ms
  199 130.211.143.185                            56  43 86ms
    sent=200 received=200 packet-loss=0% min-rtt=47ms avg-rtt=49ms max-rtt=95ms
But if I minimize Winbox, and then go back to the window, this is how it looks:
 56  4
3 86ms
  277
130.21
1.143.
185
 56  4
3 86ms
  278
130.21
1.143.
185
 56  4
3 86ms
  279 130.211.143.185                            56  43 83ms
This is very annoying to me as I run a lot of traceroute/ping tests for a long time to troubleshoot connections, and coming back to the window like that is not a game-stopping thing, but it is pretty annoying.
Elfos
Re: Winbox 3 RC
Wed Apr 22, 2015 8:39 pm
Keyboard shortcuts are not working in RC9.
For example, the key "and" to enable, "d" to disable any rule does not work.
WirelessRudy
Re: Winbox 3 RC
Thu Apr 23, 2015 1:36 am
Same for me. New features are nice but even nicer if we could easily hide it if we don't want it.
nje431
Re: Winbox 3 RC
Thu Apr 23, 2015 3:26 pm
Advanced mode offers more clutter than I need. Simple mode would be what I would use if it would open with the Notes column visible ( that's where our 65 routers friendly names are kept), and it fully remembered the window size. By the way, even Advanced mode won't re-open to full window height. It's more like 75% (Win 7).
Cheers
jarda
Re: Winbox 3 RC
Fri Apr 24, 2015 1:51 pm
When router is rebooted and Winbox 3rc9 offers reconnect, it does not work. Looks like logging is performed but no screen is opened.
honzam
Re: Winbox 3 RC
Fri Apr 24, 2015 4:18 pm
zikachu
Re: Winbox 3 RC
Fri Apr 24, 2015 4:42 pm
after all trying trying trying... im gettin upset and getting tired.... i have to use my energy to solve the network problems but this stupid winbox take all that energy from me...
if you want advise, use old one and not get angry and no suprises. after soon i hope the mikrotik find the right coders for this small winbox program...
jarda
Fri Apr 24, 2015 6:27 pm
There is no option when you use smips.
BoingoNOC
Re: Winbox 3 RC
Fri Apr 24, 2015 6:41 pm
Looks like the new Winbox is not showing those menu items on the older versions of the RouterOS. Anyway to make these backwards compatible? I am seeing the options or our devices that have 6.0 and above.
Jivo
Re: Winbox 3 RC
Fri Apr 24, 2015 8:01 pm
Dear all,
I can't tell if nobody cares, or nobody have noticed (which I don't believe) that Winbox3 RC does not seem to work properly with ROS 5.26.
Maybe I am the only one experiencig this because I am doing something wrong?
boen_robot
Re: Winbox 3 RC
Fri Apr 24, 2015 8:09 pm
I'm thinking most people are in the "I don't really care" camp. I for one have all my routers with 6.x versions. And if I get a new one that happens to have 5.x, I could always upgrade it via WebFig or FTP or SSH.
jarda
Re: Winbox 3 RC
Sat Apr 25, 2015 10:49 am
There is an error on logon addresses window. When sorting by address is used, it moves the addresses with explicitly written port to the end, so they are not sorted according the address number.
Correction should be made to next RC.
jarda
Re: Winbox 3 RC
Sat Apr 25, 2015 10:57 am
Request for change:
If using the small down arrow in the table header to change the displayed columns, everytime when the column item is selected or deselected, the whole menu disappears and it is necessary to click trhu the whole menu path again if someone wants to make more changes. It is really annoying.
Please, make the column marking menu visible and acceptable to set all marks to the columns that should/should not be visible at once and let it be hidden only when user clicks out of the "show columns" menu.
Thank you.
jkttim
Re: Winbox 3 RC
Sat Apr 25, 2015 2:47 pm
Hi guys!
You can Tinker with the tray icon? Left icon new RC starting at 6, right Winbox version 3.0rc5
Thank you.
normis
Re: Winbox 3 RC
Mon Apr 27, 2015 9:03 am
Hi guys!
Thank you.
right click it, and either "pin" or "unpin" from taskbar. see the difference
strods
Re: Winbox 3 RC
Mon Apr 27, 2015 12:10 pm
Please everyone who is having trouble with missing menus on Winbox try to delete Winbox files.
jkttim
Re: Winbox 3 RC
Mon Apr 27, 2015 2:04 pm
Hi guys!
Thank you.
Hi!
Thank you :) helped, but still would like by default :)
jarda
Re: Winbox 3 RC
Tue Apr 28, 2015 9:10 am
Not necessary to delete whole folder and to loose the address list. It is enough to delete only the version folder that corresponds to the ros version on the device where problem is observed.
The path written by strods is not correct in some cases. See my experience here:
http://forum.mikrotik.com/viewtopic.php ... 50#p478938
zichovsky
Re: Winbox 3 RC
Tue Apr 28, 2015 3:49 pm
Tried this many time with every rc version of WB3, but still missing "wireless" menu (and maybe others, but wireless is most important for us) when connecting to any device with ROS 5.x
It is bug introduced in "rc" version, with "beta" version it worked OK.
So now I have to use Winbox2 for 5.x devices and Winbox3 for 6.x devices :(
agrisvv
Re: Winbox 3 RC - feature
Wed Apr 29, 2015 11:45 pm
Hi! clear winbox password or all fields after login or protect with master pasword.
1. open winbox.
2. input Master passwod
3. get your host,password and login to router.
4. close winbox.
5. open winbox (inccorect - host and password are saved and you can connect). correct- all info clear and it you can get via master password.
I think something like WinSCP with Master password when you want to login..
chechito
Re: Winbox 3 RC
Sun May 03, 2015 6:22 am
same here,
Problem signature:
Fault Module Name: StackHash_bca8
Fault Module Version: 6.1.7601.18229
Fault Module Timestamp: 51fb1072
Locale ID: 1033
Additional Information 1: bca8
Additional Information 2: bca8637902933902a49b2f5a8ca2ab42
Additional Information 3: 0c34
Additional Information 4: 0c3434e3fde815f0c5c32e3baf7bf81c
Ham
Re: Winbox 3 RC
Sun May 03, 2015 3:29 pm
Error in v3 RC9 - incorrectly reporting vrrp state.
hkusulja
Re: Winbox 3 RC
Sun May 03, 2015 4:27 pm
what about keyboard shortcuts in latest winbox 3.0 for enable (E) and disable (D) on list itmes (interfaces, firewall rules etc.). It seems that this does not work anymore.
ddt
Re: Winbox 3 RC
Sun May 03, 2015 9:12 pm
I believe a lot of people have been commenting on this, and that I think they disabled these short cuts because a lot of users were accidentally hitting D when they didn't mean to.
The cost of accidental key presses outweighs the ease of a simple one-key shortcut most likely.
hkusulja
Re: Winbox 3 RC
Sun May 03, 2015 9:16 pm
Ok, I understand, however where is notice / announcement / release notes about this ?
I believe some shortcuts still can work like "DEL" to delete the item.
Also, winbox could have its own settings (like it has now) and simple checkbox "enable keyboard shortcuts", i believe this is not so hard to implement.
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Sun May 03, 2015 9:56 pm
I think that is the best way to handle this. Shortcuts were disabled because some people complained how easy it is to delete an item, but some people use these shortcuts and rely on them. Just make it an option.
SiB
Re: Winbox 3 RC
Tue May 05, 2015 4:01 am
1)
Old DOS shortcuts aren't work, like
SHIFT+INSERT = CTRL+V
CTRL+INSERT = CTRL+C
SHIFT+DELETE = CTRL + X
2)
R.E.D. shotcuts are not active now, please gray it or disable/remove from RMB
e.g. firewall:
3)
A. DEL. C. - Add, Delete, Comment - please not disable it - there are good positive :).
4)
Why This list isn't a scrolled - it's be a that simple.
Why I cannot Select, select and do next select like on/off on sill open one list. Open this and select by one entry is very.. "not optimal" :) Maybe still pressed CTRL should give me switch on/off?
5)
general filters. Good idea be a safe a few common filters as my favorite like "SIPTrunk connection", "FTP". Now I must create this filters again and again, sometimes I must use 7entry in one filter :(. Simple idea for "HTTPS@LAN":
6)
Maybe it's time to create a way to change a RENAME all entry in AdressList. It's always problematic when I must use few scripts to rename names and rename it again into firewall rules. It's be perfect features.
7)
Connection by MAC address is not stable like via IP. Display address with %? Please change into ":".
who48
Re: Winbox 3 RC
Tue May 05, 2015 11:11 am
help me please
DaveBrowning
Re: Winbox 3 RC
Tue May 05, 2015 12:41 pm
Hi There,
Not sure if I am doing something wrong or if this is a bug:
When I create a new device in my CDB file and I apply it to a group, the group part of the config doesnt seem to apply. It also seems that if I try to change the group of an existing device it simply blanks out the group field.
Things I have tried to resolve:
- Cleared my %appdata%\Mikrotik folder
- Tried multiple PCs (same CDB file)
- Tried a with a fresh CDB file
I am using Winbox v3.0rc9
Any assistance would be greatly appreciated
Cheers,
Dave
SiB
Re: Winbox 3 RC
Tue May 05, 2015 3:28 pm
In my opinion works OK. e.g. creation and change name of group1 to group2:
Sob
Re: Winbox 3 RC
Tue May 05, 2015 5:29 pm
1)
I already mentioned it, but no luck so far. Those other shortcuts are not "old DOS shortcuts" in the obsolete way how it could sound. Those shortcuts are as standard as the more known Ctrl+V/C/X. They worked in every single program I've ever used, even in older WinBox (up to RouterOS 3.x or 4.x) and current WinBox is the only exception. And as could be expected, it's very annoying. The problem is that MikroTik stopped using standard system edit controls, instead created their own and only added support for Ctrl+V/C/X. So once again, please, please, please fix it!
WirelessRudy
Re: Winbox 3 RC
Tue May 05, 2015 8:02 pm
3)
4)
5)
6)
7)
I fully underwrite these points. Special 4 is a long time irritation on the use of winbox. Almost everytime when opening a session I need to open, select, open again, select again etc etc. to get the columns I want. I rarely want the default ones...
syadnom
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Wed May 06, 2015 6:09 pm
It seems that rc9 doesn't save the address list's settings. Comes up w/ address and user, but I have to add the notes field every time I open it. This is really frustrating.
SiB
Re: Winbox 3 RC
Wed May 06, 2015 10:00 pm
I found a bad TAB "way/road/direction".
Of course work a BACK way by "SHIFT TAB" - OK
Why TAB not stay on "Managed/Neighbors" tab? I found this can be change by "CTRL + TAB".
SiB
Re: Winbox 3 RC
Fri May 08, 2015 5:09 pm
When I open WinBox v3 then..
"CTRL + F = Find" is not work. I cannot start WinBox and search a proper MTK to open connection.
Workaround:
1) I must click on bottom section of window, address list and CTRL+F is work.
2) Or without mouse: 2x "SHIFT+TAB".
My opinion: CTRL+F should work from any place where a cursor is blinking/located.
SiB
Re: Winbox 3 RC
Fri May 08, 2015 10:54 pm
We should have this option in v3 too!. I just have problems with reconnection, break a connection etc. and only clear MikroTik folder was help me.
strods
Re: Winbox 3 RC
Thu May 14, 2015 10:16 am
We have finally managed to reproduce Winbox crash when "Connect" button is pressed.
We will fix it in next release.
SiB
Re: Winbox 3 RC
Thu May 14, 2015 11:06 pm
In my opinion WinBOX v3 is not stable when I connect to v5.26. I must use a WinBox v2 who is stable and works perfect.
First is open a "Error" and after 20sec I see "Could not connect". After pressing any OK button a winbox is closed and I have not any winbox v3 with reconnection...
mtandrew
Re: Winbox 3 RC
Fri May 15, 2015 7:00 pm
Winbox RC1 is available. There are lots of changes since beta 3*
http://download2.mikrotik.com/routeros/ ... winbox.exe
Overall highlights of Winbox 3:
Two extremely needed features that would make winbox more productive and convenient:
1. "taskbar" for windows inside winbox. Now bigger windows cover smaller all the time. All admins I talk to are pissed of because of this.
2. searchable, groupable and selectable logs window for gods sake!!! Now we have option to select storage only (all,disk,memory). We need ability to select facility (say I am looking for ipsec logs, or system, or firewall) that contains particular word in it AND within some time frame. Then we need to be able to select lines for copy'ing.
PLEASE, Mikrotik!
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Fri May 15, 2015 7:27 pm
When 'Open in new window' is selected a new session is opened instanly, no delay, no wait.
If it is not and the session is opened in the same window there you can see 'Logging in' for 2-3 seconds.
This is on a very fast connection to the board.
Not that it is much delay, but if it can be instant in a new window can't the same be achieved without it ?
Jivo
Re: Winbox 3 RC
Sun May 17, 2015 3:31 pm
I must admit that I am pretty much surprised with that approach. It might work fine for someone who jumped to Mikrotik train yesteday, or for someone playing at home with few devices, but if you have installed basis of hundreds of devices in full production, with no reason whatsoever to touch a running system which works fine - it's another story.
If you add problems with Winbox 3, which I simply can't afford, disgracefull bugs appearing in RouterOS 6.x from one update to another ....
If I had not purchased a bunch of hAP's, I would not even consider Winbox 3, and will sure try to avoid it in the near future. I'm still convinced that MiktoTik did not intentionaly made it not to work with RouterOS 5.x or lower.
boen_robot
Re: Winbox 3 RC
Sun May 17, 2015 4:30 pm
Sure, I agree. But the question was if anyone noticed, or if they did and didn't cared to report it.
I didn't noticed it, as I'm not affected... But you're right, I only have a few MikroTik devices in total, which I upgrade semi-regularly (read: any time there's a change in something that I do use in the setup), leaving all of my devices with different 6.x, and zero 5.x ones.
For people with hundreds of devices, there's also mechanisms for mass upgrades in place... While I understand doing those is always a great risk, there's always the possibility to first upgrade one device (that is like the others in everything - hardware, software, settings), and then if it goes well, do the mass upgrade then.
chechito
Re: Winbox 3 RC
Sun May 17, 2015 7:47 pm
I dont understand why some network admin refuse to update at least to some 6.xx ros version but claim updating another tools.
Its simply logic updated tools work with updated rOS, even new units come with rOS 6.xx preinstalled, are you doing downgrade then???
I think its a total carelessness to maintain a network with outdated software.
Some can justify on network stability etc etc, but its a lack of logistic and management not be able to get some good practices to apply updates and maintain the network up to date
karlisi
Re: Winbox 3 RC
Mon May 18, 2015 10:09 am
Or at least 'Windows' menu where we can see all open sub-windows and switch between them.
julianmaria
Re: Winbox 3 RC
Mon May 18, 2015 6:46 pm
Is it me, or I have many many problems with all versions of Winbox 3 rc
I have many Microsoft Servers (Windows 2008 R2) with Remote Desktop Services. I use to administer many routers connected via Remote Desktop
Winbox 3 fails connecting routers saying it cant create files, and it doesnt remember anything I saved
It tries to create files in the same folder I execute it, b
Perhaps the reason is:
-Windows Session profile folder is "copied" to c:\Users (Until I log off) (from a Network Server)
So, me, as an Administrator, Winbox tries to open files and folders from
c:\Users\administrator\AppData\Roaming\Mikrotik\
But What happens when the Windows Session profile folder is "used" ? (ex: C:\Users\Administrator is used by a previous hanged Session)
Hanged Remote Desktop Profile Sessions folders are very common: Some times when a User log off, some dlls (like printer ones) still remains in memory so windows isnt capable of destroying the Session profile folder completelly.
When the user logs in again: Windows Server addapts itself and create a Windows Session profile folder with Domain suffix
In my case:
For example:
c:\users\Administrator.corp (with the domain)
The problem starts there: Winboxs tries to load files and read folders from c:\users\Administrator and not from
c:\Users\Administrator.corp (the real profile folder)
So winbox cant connect any router (cause it cant download anything)
Nutcracker
Re: Winbox 3 RC
Tue May 19, 2015 10:23 am
When will we be getting our hotkeys back in Winbox?
I am talking about the following:
r - remove
d - disable
e - enable
The following still work:
a - accept
c - comment
Been using Winbox for nearly 10 years now, and this frustrates me. As has been suggested in other posts, why isn't there an option to turn it on or off? This cannot be a difficult thing to fix.
I would roll back to an older version of winbox, but then I would get stuck with "corrupted gzip" and the like.
Mikrotik, please fix this.
freemannnn
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Tue May 19, 2015 11:20 am
yes, i also want and option for shortcut keys. its a pitty you remove them.
WirelessRudy
Re: Winbox 3 RC
Tue May 19, 2015 11:51 am
Well, let me explain why;
1. New purchased routerboards NEVER come with the latest OS. I just recieved a whole bunch of new SXT's and they are all v.5.22. I have never seen units coming with an version OS closer than 2 or 3 away from the last. And by the rate new version are been issued its impossible for sales channels to get their stocks updated.
But of course you can update them when you receive the units. Standard procedure.
2. Immediately updating your production units to the latest OS even if the units run fine on an older OS is not always a good practise. Very often new OS comes with new bugs and issues and that might just bring your network down while with the older OS was doing fine. This forum is full of stories about people upgrading only to find disaster on there path.
I try to keep my network to the latest OS but only after a new OS is tested on new units, than on local units, then on some remote and then, if it all still went well, we implement them on the rest of the network. Because yes, in the end new OS should bring new performances. (And not seldom just the plainly needed reboot revives a unit that was working poorly.)
chechito
Re: Winbox 3 RC
Tue May 19, 2015 10:18 pm
ok then take 20 versions to properly test reliability of your actual configurations and putting it on production??
my most outdated implementation has 6.19 (upgrading to 6.28 this week), updating software its not a free duty it requires planning testing and proper rolling back planning, but is not impossible.
If the implementation of a network dont take account of maintenance tasks like updating software and maintaining hardware its a incomplete implementation.
In that kind of incomplete implementations maintenance tasks are seen as a issue and a problem because somebody forget to take it in account.
macsrwe
Re: Winbox 3 RC
Wed May 20, 2015 4:34 am
If you click on Tool / Email, it shows you all the predefined server, port, user, and password values. But when you then click on "Send Email," you get a pane in which none of those are filled in, so you have to type them all by hand. There's really no reason not to fill in the defaults from the Email pane.
This is not a new bug in Winbox 3, but it would be nice if it could be fixed while Winbox 3 was open. Thanks.
dada
Re: Winbox 3 RC
Thu May 21, 2015 4:32 pm
I decided to post my list of bugs/problems related to Winbox 3.0rc9 which bother us:
Crashes
  • when I start winbox and try to connect to a station sometimes winbox windows silently disappears without warning or error message (Winbox probably crashes). Usually the second attempt to connect is OK
  • when connected to a radio with old ROS (4.x, 5.x) the Winbox 3 rc9 crashes every time (sooner or later). It is near unusable for radios with old ROS
  • by clicking some function (menu item) the winbox sometimes crashes („New terminal“ last time). I think you should/could include an exception report dialog box to collect (automatically from internal exception handling) more informations about these problems
UI discomforts/errors
  • CR (Enter) not working properly in initial dialog
    Start Winbox, type IP pres <CR> - nothing happen. It should connect (much faster than using mouse to activate the Connect button). Funny thing is that when connection attempt is cancelled using „Cancel“ button and IP edit box is focused the <CR> starts a new connection attempt
  • Non-persistent winbox window
    when Winbox loses connection to remote radio it's window disapears silently. Often I have some information in the window I would like to see (just created spectral scans, information from the box I can (re)use - and they can be totally lost because it could happen I can never see them again - lost connection to the radio when something odd happens)
  • Blocking file copy
    when a file (new ROS) is being copied to the station using Winbox I cannot access anything on the remote radio. Winbox 2.x allowed this. So I could see some thing I forgot to check before the file transfer was started. I even could inspect cached values when connection was lost and the 'termination confirmation' dialog was shown.
  • MAC ping reusing the same window
    Older Winbox allowed to use multiple MAC Ping windows from an AP
  • Remembered password problem/confusion
    Winbox 3 doesn't remember the correct password. I use 'Keep password' but often I have to retype the password even if I connect to a radio which has the same password as the one I connected before it. Maybe I didn't understand the sessions or maybe it is not working. The winbox offers often bad (not the last used one) password. Note: We heavily use Winbox started from browser via helper utility which is associated with browser. This way is working (the helper utility sends username and password via command line to winbox). But when winbox is invoked manually it often uses unknown passwords (not the last one used when winbox was started manually last time). Winbox 2.2.18 had no such problem.
  • Icons
    allow to disable left menu icons. They are disturbing, non-informative/confusing and space vasting.
  • Communication is not send through proper interface
    when you have multiple NICs (even virtual ones) Winbox tends to send the discovery packets (and the communication packets too) through only one interface (often the improper one). I have 2 nics in the PC and some Virtual box related virtual NICs and using the Winbox in this situation is a pain. Even o notebook I have to disable Wifi interface to be able to connect to or discover MT device on ethernet.
    Send the discovery to all interfaces and the communication to proper ones or allow us to select the interface.
  • Ethernet Status tab
    This is the one of the most important tabs for ethernet and Winbox3 moved it from the 3rd position in the Interface dialog window to 6th. It looks like it is not problem of Winbox itself but higher ROS versions. If you are not able to create the proper order on the first time then let it be and do not change it in future (when users are used to the order).
  • Monitor too small to use winbox
    some config dialogs in some situations are not usable - Ingress vlan translation on 24port CRS for example. There is noway to use Winbox dialog to manage VLANs in this case even on 1920x1200 resolution.
    The solution here could be ranges of interfaces (ether2-ether20 for example). Ranges of interface would simplify CLI settings/reading too.
  • ERROR: could not create file
    when connecting to a radio this error appears (rarely). And it is not possible to connect to the radio. Even subsequent attempts fails with the same problem. Give us more information instead of general error message.
  • Terminal window problem
    editing commands which don't fit one line tends to cause problems with displaing the line properly.
Wishes
  • Get rid of the DLLs downloaded from target box
    replace them by definition files. After it you can create Linux version of Winbox more easily.
  • BW test predefined parameters
    IP/test type/tcp connection count/admin/password. It would speed up general connection testing.
WirelessRudy
Re: Winbox 3 RC
Thu May 21, 2015 5:30 pm
Crashes
I can confirm this.
[*]when connected to a radio with old ROS (4.x, 5.x) the Winbox 3 rc9 crashes every time (sooner or later). It is near unusable for radios with old ROS
Or connected by mac while unit on the desk and in an old version. Meaning new purchased units connect to for 1st time config always disconnect first time. Work around is to inmediately set ip dhcp-cl and use the obtained IP for further login. Otherwise unit keeps quiting....
[*]by clicking some function (menu item) the winbox sometimes crashes („New terminal“ last time). I think you should/could include an exception report dialog box to collect (automatically from internal exception handling) more informations about these problems[/list]
I can confirm this.
Units also disconnect regularly while filetransfer is running. In both mac and ip mode!
Complained about this some version ago. Very, VERY, inconveniant. Because indeed at times the 'old' window contains still readable info. Now it just got lost.....
[*]Blocking file copy
Confrimed. And annoying. Now you have to wait untill upload is finished. In the meantime cannot do anything in winbox session. Not even move the windows because in the meantime I want to read some info.. very inconveniant
[*]MAC ping reusing the same window
[*]Remembered password problem/confusion
[*]Icons
+1
[*]Communication is not send through proper interface
[*]Ethernet Status tab
Fully support this opinion!
[*]Monitor too small to use winbox
[*]ERROR: could not create file
[*]Terminal window problem
editing commands which don't fit one line tends to cause problems with displaing the line properly.[/list]
Indeed
Wishes
Allthough the new winbox has some improvements compared to the old versions these are hardly enough to choose it over the old vesion due all the new imperfections introduced compared with lots of 'old' irritations still not been touched.
When a new winbox version is to be made it should do much better and the developments should also go faster. Its now already going for months, longer than most of the software upgrades take to see the light! :?
Cha0s
Re: Winbox 3 RC
Thu May 21, 2015 6:04 pm
dada++
WirelessRudy++
At the moment, even with all the new features and improvements to Winbox 3, it's pretty much useless in production environments.
For home use, where most users will login once every year to their router might be ok.
But for professionals managing tens of Mikrotik installations everyday all the new features are not enough to give up on the perfectly usable and stable Winbox v2.
A true upgrade to v3 would be to keep the workflow intact while introducing new features (and NOT bugs).
Right now it's really annoying to use having to learn new ways to do things (fast).
macsrwe
Re: Winbox 3 RC
Thu May 21, 2015 11:10 pm
Especially when MikroTik keeps advising that we have to upgrade to ROS 6.28 to solve many of the Winbox problems we are reporting. You can't just upgrade a production network like that.
SiB
Re: Winbox 3 RC
Fri May 22, 2015 2:03 pm
dada +
WirelessRudy +
and more... in my opinion WinBox v3 should be BETA with many, many new release before we can speak about RC. MikroTik, why you lost a numbering like x.y.z, this was a good ideology.
Today little GUI bug:
When we move up and down the WinBox v3 list then last entry is cut. Pressing "v" correct the position but now on the top we have this a entry cut...
SCare
Re: Winbox 3 RC
Tue May 26, 2015 1:07 pm
Sometimes you are just trying to figure out what happened by digging through the log. But there is so much info and specially when you want a quick look into when and how many times something happened it would be nice if you can just temporarily 'select' parts of the text. Would be even better if we than also could copy and paste it somewhere else for further study.
fbslim
Re: Winbox 3 RC
Wed May 27, 2015 11:34 am
Last version rc9 crashes on Windows Server 2008 R2 and some desktops on Windows 7
I saw it tries to download plugin and when crashes
And I have to use it with hAP lite... and no way... :(
fbslim
Re: Winbox 3 RC
Wed May 27, 2015 6:56 pm
Can somebody tell me why appears the new line of products on smips without quality support?!
I mean my post upper.
jarda
Re: Winbox 3 RC
Wed May 27, 2015 8:49 pm
Because it is the way how mikrotik does things.
fbslim
Re: Winbox 3 RC
Wed May 27, 2015 9:40 pm
ahahahaaaa!!! :D :D :D
jarda
Winbox 3 RC
Thu May 28, 2015 7:11 am
Yeah. Funny enough. The life would be so gray without these easter eggs we are finding each day. I am just trying to handle it somehow, because even it brings those bad things, there is no better option for me.
Nollitik
Re: Winbox 3 RC
Fri May 29, 2015 7:12 am
Make the log a rich text file that can be easily exported for further analysis if one needs.
normis
Re: Winbox 3 RC
Fri May 29, 2015 1:28 pm
rc10 fixes crash
fbslim
Re: Winbox 3 RC
Fri May 29, 2015 5:51 pm
rc10 fixes crash
Thank you very much :!: :!: :!:
And another bug. Now, after each connecting to any router creates tmp file in same directory where winbox.exe exists:
viw83DD.tmp
viwD151.tmp
etc...
kometchtech
Re: Winbox 3 RC
Fri May 29, 2015 7:44 pm
rc10 fixes crash
Part of the upgraded from listed in the Winbox3.0rc9 was RB no longer see.
# No output list
honzam
Re: Winbox 3 RC
Fri May 29, 2015 11:04 pm
What's new in v3.0rc10:
*) remember first window size;
*) fixed crash when trying to connect to the router;
*) fixed connecting by mac addresses on Windows with multiple network cards (needs at least RouterOS v6.29 on the router as well);
*) added back keyboard shortcuts for tables (INS for add, DEL for remove and all other with Ctrl prefixes);
*) added support for Shift+Ins, Ctrl+Ins, Shift+Del shortcuts in text entry fields;
*) fixed crash when connecting to v5 routers;
*) fixed problem where group column contents were not shown;
kikikaka
Re: Winbox 3 RC
Sat May 30, 2015 8:31 am
rc9 crash...
Just tested RC10, crash problem is fixed . Seems ok so far.
zervan
Re: Winbox 3 RC
Sat May 30, 2015 4:52 pm
Hello! I decided to try new WinBox 3 (RC9) few days ago - I like the session feature. But I had some troubles with Safe Mode - is it working correctly? I had turned on Safe Mode, made some changes, lost connection. I reconnected back, but there was the old session in the Active Users list and I was not able to start new Safe Mode.
macsrwe
Re: Winbox 3 RC
Sat May 30, 2015 11:23 pm
It also changed the way the list is sorted by group. Previously, when I sorted by group, it would group the entries by the entire group name (e.g., Central, Central CPE, City-E, City-S, City-W, etc.). Now it groups the entries by first letter only, throwing all the Cs into the same group. I much preferred the previous behavior.
macsrwe
Re: Winbox 3 RC
Sat May 30, 2015 11:26 pm
If you lose connection during Safe Mode, manage to reconnect before the Safe Mode times out, and ask for Safe Mode again, you will always be told that someone else owns Safe Mode. This is not new with Winbox 3. You have always had to bring up a Terminal window, request Safe Mode there, and choose whether you want the old Safe Mode changes to be rolled back or not.
zervan
Re: Winbox 3 RC
Sat May 30, 2015 11:44 pm
Thank you for information! I didn't know about this - I barely used Safe mode before...
macsrwe
Re: Winbox 3 RC
Sun May 31, 2015 2:09 am
Bug: If you choose two routers that have the same default session file, and click "Connect to all," one opens up with the proper session windows, and the other opens up to a blank gray window.
Autosave Session and Open in New Window are both checked.
This is true in at least rc9 and rc10.
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Sun May 31, 2015 10:47 am
And again sessions are not used when opened from within Dude.
nishadul
Re: Winbox 3 RC
Sun May 31, 2015 12:45 pm
When I select IP > webproxy > access then winbox closed
pturkey
Re: Winbox 3 RC
Sun May 31, 2015 7:29 pm
winbox 3.0rc10 is now creating a folder instead of a data file of the 1.1.1.1.viw.
I am using Linux with wine.
BartoszP
Re: Winbox 3 RC
Sun May 31, 2015 9:21 pm
Same on Windows....no session state saving.
electrocat
Re: Winbox 3 RC
Mon Jun 01, 2015 1:33 pm
Small investigation for Winbox 3.0 rc10 on Windows:
- In the Session folder creates a folder "<ip>%<port>.viw" (Session="own")
- If Menu/Sessions/Autosave on Close is turned on, then when you close the program in Winbox's folder "viw<number>.tmp" file is created. After each run, there is one additional file.
bigears
Re: Winbox 3 RC
Tue Jun 02, 2015 5:20 am
upgraded to ROS 6.29.1 to fix the problem where some CRS could not be reached (introduced in v6.29);
This problem still happens with Winbox RC10 even after I cleared cache and tmp files. Winbox RC9 does not have this problem.
strods
Re: Winbox 3 RC
Tue Jun 02, 2015 8:31 am
We have reproduced this issue where .tmp files are being created. We will fix it in next release.
tomaskir
Trainer
Trainer
Re: Winbox 3 RC
Tue Jun 02, 2015 10:05 am
The C button no longer works for me to set comments in RC10.
Is this also happening for others?
normis
Re: Winbox 3 RC
Tue Jun 02, 2015 10:30 am
It was announced before somewhere, that single letter shortcuts are removed, because there was a risk of accidentaly removing, disabling, etc. We will add shift or something to these keys
hashbang
Re: Winbox 3 RC
Tue Jun 02, 2015 11:14 am
in rc 10 last settings are not save. I have to manually add ip address turn on the advance mode. It was fine in rc9. Running on wine. Connect to field is always empty
tomaskir
Trainer
Trainer
Re: Winbox 3 RC
Tue Jun 02, 2015 11:27 am
Yes, I read that and I understand why that was done for remove/disable etc.
But comment was not mentioned.
Comment is a benign function, and removing the shortcut seriously impacts work-flow.
normis
Re: Winbox 3 RC
Tue Jun 02, 2015 11:39 am
ok, we will figure something out. I guess when the programmers removed the shortcuts, they removed all, and will return all as well.
http://xkcd.com/1172/
freemannnn
Forum Veteran
Forum Veteran
Winbox 3 RC
Tue Jun 02, 2015 12:05 pm
Sometimes during the day i connect to romon devices nicely, other times i get the message disconnected from romon. I dont know if its a winbox issue or ros. By the way very nice feature!
normis
Re: Winbox 3 RC
Tue Jun 02, 2015 12:40 pm
shortcuts are already back in rc10:
BoingoNOC
Re: Winbox 3 RC
Tue Jun 02, 2015 9:46 pm
Thank you for the updates and bug fixes
Are there any plans to make this new version fully compatible with the older ROS versions?
Any version prior to 6.0 has missing menu options.
Yes I know they should be brought up to the current ROS, which we are doing slowly but surely.
The issue is replacing hardware among other things to consider and it would be great to be able to use 1 version of Winbox to access all of our devices.
w0lt
Long time Member
Long time Member
Re: Winbox 3 RC
Tue Jun 02, 2015 9:57 pm
Please preserve the checked boxes in "Torch" from one session to another.
-tp
normis
Re: Winbox 3 RC
Wed Jun 03, 2015 10:09 am
Delete the Winbox folder if you have missing menu items. It has cached some menu layout there. Clear the foler and relaunch to fix this.
BoingoNOC
Re: Winbox 3 RC
Wed Jun 03, 2015 7:24 pm
This does not resolve the issue, Winbox 3 is not completely compatible with ROS version below 6.0, I am not the only one having this issue.
For trouble shooting purposes I did it again and still the same issue.
nz_monkey
Re: Winbox 3 RC
Fri Jun 05, 2015 12:54 am
Not being able to C for comments is driving me insane! I hope this comes back soon.
Maybe just have dual-key shortcuts for dangerous commands like remove/disable/enable
honzam
Re: Winbox 3 RC
Fri Jun 05, 2015 9:28 am
What's new in v3.0rc11:
*) fixed session saving;
*) move cursror to password or login field when host is selected in address list or in neighbors
normis
Re: Winbox 3 RC
Fri Jun 05, 2015 9:53 am
Accidenatly "Debug window" was enabled.
Simply re-download Winbox.exe from our download page. Problem gone
normis
Re: Winbox 3 RC
Fri Jun 05, 2015 9:54 am
Right click in the list window to see the shortcuts, they are already made
noyo
Re: Winbox 3 RC
Fri Jun 05, 2015 10:16 am
However, my mail was not wasted. Have added advanced mode. :D thanks, a good move
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Fri Jun 05, 2015 10:42 am
In rc11 still when opened from Dude sessions are not loaded. Working fine with rc6
normis
Re: Winbox 3 RC
Fri Jun 05, 2015 10:45 am
make sure to delete the winbox files (viw and others), then try again
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Fri Jun 05, 2015 10:50 am
But that will delete all my remembered sessions. They load fine if I just open winbox.exe from explorer, but if I open it like a tool from dude with command : winbox.exe [Device.FirstAddress] [Device.UserName] [Device.Password] - no session is loaded.
noyo
Re: Winbox 3 RC
Fri Jun 05, 2015 10:56 am
RoMON does not work in the RC11 and ROS 6.29.1
honzam
Re: Winbox 3 RC
Fri Jun 05, 2015 2:08 pm
Yesterday rc11. Today rc12 :)
What's new in v3.0rc12:
*) added "clear cache" command to Tools menu;
bda
Re: Winbox 3 RC
Fri Jun 05, 2015 2:10 pm
very good!
NAB
Trainer
Trainer
Re: Winbox 3 RC
Fri Jun 05, 2015 4:10 pm
Ran 3.0rc12 for the first time, opened a session. Clicked 'X' to close session window and got the error message:
"Unable to create the folder 'sessions\'. The system cannot find the path specified."
normis
Re: Winbox 3 RC
Fri Jun 05, 2015 4:15 pm
Try the new "clear cache" button. Also, do you use Windows and a standard path?
panosla
Re: Winbox 3 RC
Fri Jun 05, 2015 9:51 pm
WinBox 3rc12 crashes when trying to create virtual ethernet on hap lite 6.29.1
toohid
Re: Winbox 3 RC
Sat Jun 06, 2015 12:50 pm
Problem :
in ipsec Policy cannot be change vale of priority to 0 or 1 (use winbox )
from ver 6.27 to 6.29.1 i tested
in terminal it works fine
macsrwe
Re: Winbox 3 RC
Mon Jun 08, 2015 1:02 am
On devices with POE-out ports, any chance of getting a new "POE" pane in the window for the POE-in port to allow us to set ether1-poe-in-long-cable from Winbox?
tussockland
Re: Winbox 3 RC
Mon Jun 08, 2015 10:11 am
Yeah! This is the only way I got my RB750up to stop port flapping. I had poe-out port flapping on v6.18/19 a few times a day/week, so thought it was time to update to the latest 6.29.1 , what a mistake, port flapped all night, every 10-15 mins. Much worse, and all my cables are super short. As soon as i set poe-in long cable, stopped immediately. What's more, it used to port flap every time i logged in with webfig and winbox, and i certainly could not leave them running on-screen. Now i can leave them running on-screen all day...
Oh, and here's a screen shot of an interesting session of port flapping, so you can't tell me it's not the device's fault when it's doing it on-the-hour! I've seen similar patterns before. It's software {possibly hardware?} for sure, not something else attached:
[img]
[/img]
gnuttisch
Re: Winbox 3 RC
Mon Jun 08, 2015 12:32 pm
r - remove
d - disable
e - enable
a - accept
c - comment
This would be great BUT please, add an function to enable/disable this feature in winbox settings.
I got kids ans cats.... :)
normis
Re: Winbox 3 RC
Mon Jun 08, 2015 1:46 pm
r - remove
d - disable
e - enable
a - accept
c - comment
It is already returned, and the key shortcuts are different now - right click the firewall list to see the shortcuts. They are no longer single keys, and are kid/cat-proof
NAB
Trainer
Trainer
Re: Winbox 3 RC
Wed Jun 10, 2015 12:35 pm
Still get the same error and yes, standard Windows paths.
macgaiver
Re: Winbox 3 RC
Wed Jun 10, 2015 1:42 pm
Just move your session folder to existing location and all will be fixed. Atm you probably somehow deleted in in windows user files, and winbox doesn't have permisions to create anything there.
NAB
Trainer
Trainer
Re: Winbox 3 RC
Thu Jun 11, 2015 1:00 am
No session folder anywhere in sight. Winbox 3.0rc9 continues to work correctly in this regard.
Nope. Not deleted anything.
junctura
Re: Winbox 3 RC
Fri Jun 12, 2015 5:25 pm
I am using Winbox v3.0rc12 and am receiving the following error when attempting to connect to any routerboards I have, versions varied from 5.22 up to 6.28:
The procedure entry point ucrtbase.abort could not be located in the dynamic link library api-ms-win-crt-runtime-l1-1-0.dll
The error comes up 3 times and then Winbox connects, but the connection is flaky and I am having to reconnect.
I have a fresh install of Windows 7 Pro. I have .Net 4.5.2 installed with all available Windows updates. Do you require any other information from me?
BBSing is a terminal disease and I have the ANSI strain.
mortar8
Re: Winbox 3 RC
Mon Jun 15, 2015 9:33 am
About RoMON.
I've added a gateway host - I can connect to it with plain winbox.
I've enabled RoMON on a switch behind it and on the gateway. I can discover both from eachother. When I click "connect to RoMON" button, it connects, I can discover the switch.
Now here is the problem:
When I'm connected with RoMON, all the Managed list is gone. Ok I've manually added the switch by MAC address to the list after connecting with RoMON. When I click that host from the list and click connect (all when connected through RoMON) the new window opens, flashes briefly and I see the connect window with a message that "*host* has beed disconnected xx:xx:xx: ago".
I click reconnect and it works.
Ok. I see that I can specify a RoMON agent - with a hostname. From an unordered list. And it seems that it does not work. It says wrong password, thou I'm not sure what host exactly and with what credentials I am connecting to RoMON. Or is the password wrong on the RoMON or the target host..
Seriously, You guys have to think things through, plan, and test. More. And document.
plankanater
Re: Winbox 3 RC
Tue Jun 16, 2015 2:20 pm
It appears that somewhere around RC10 that SwitchOS devices are no longer able to be discovered. They still can be scene with the discovery tool on 2.2.18 but not with 3.0 rc12. The first time I noticed this was with RC10.
freemannnn
Forum Veteran
Forum Veteran
Winbox 3 RC
Wed Jun 17, 2015 1:20 pm
Winbox working folder should be the same folder winbox.exe exist so it could be portable. I login to customer routers from different pc and places and i have to make every time new viw files the way i want. Why it is in windows user folder?
In the same folder all ini and viw files even this is a usb stick or desktop folder
normis
Re: Winbox 3 RC
Wed Jun 17, 2015 1:21 pm
Winbox working folder should be the same folder winbox.exe exist so it could be portable. I login to customer routers from different pc and places and i have to make every time new viw files the way i want. Why should it be in windows user folder? In the same folder all ini and viw files !
This is set in preferences. You can choose another folder, even the same one.
Tools -> Move Sessions folder
freemannnn
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Wed Jun 17, 2015 2:55 pm
i know that. i mean that it should choose by default the path that i am running winbox.exe.
if i have a folder on my flash drive in root ...\winbox everything should be placed there and not in %appdata%
normis
Re: Winbox 3 RC
Wed Jun 17, 2015 3:00 pm
How can it know where you want it? Just set the folder once, and Winbox will remember it.
Hotz1
Re: Winbox 3 RC
Wed Jun 17, 2015 3:12 pm
I think he is suggesting winbox should store all files in the same folder where the winbox.exe was found, so that when he moves a flash drive from one machine to the next, he doesn't have to guess what drive letter the next machine will assign to it.
normis
Re: Winbox 3 RC
Wed Jun 17, 2015 3:18 pm
Usually applications store preferences in localsettings folder. I don't know of many tools that have a Folder next to them.
The only way we could solve this, is to have a "Preferences" window for Winbox, and then you could have a checkbox "Store settings next to Winbox" which would grey out the "Move sessions folder" button
Winbox is getting too complicated :)
freemannnn
Forum Veteran
Forum Veteran
Re: Winbox 3 RC
Wed Jun 17, 2015 8:34 pm
this is what i am suggesting, so everywhere i go around places i plug my usb run winbox and every setting and viw the lastime i had in my routers should be there.
look in the picture below! this is an example of what i mean
"sessionpath" or "path" file of course is not needed as it will be the current folder of winbox
Hotz1
Re: Winbox 3 RC
Thu Jun 18, 2015 5:46 am
I wonder what would happen if you set the folder to "."?
jstump
Re: Winbox 3 RC
Thu Jun 18, 2015 5:17 pm
I'd like to +1 the idea for total mobility with Winbox. I've been searching for a way to have my sessions and "managed" routers sync between work desktop, laptop, and home desktop as well.
Couldn't you just move the Addresses.cdb file into the "sessions folder" too? That would solve the problem for me as I'm just using dropbox to sync that folder.
-Joshua
Fourway.NET
CyberTod
Long time Member
Long time Member
Re: Winbox 3 RC
Fri Jun 19, 2015 8:58 am
I am writing again about a problem, but with some updates :
When using winbox v3.0rc7+ as a tool from Dude sessions are not loaded. Actually it does not read them from the session folder, but expects to find them in C:\. When exiting it saves the session changes to C:\. So it becomes very inconsistent when using winbox both from Dude and separately.
And you may say that the easiest thing to do is just move the session folder to C:\ and all is fine. Yes it is and it will work, but then my root system folder will have hundreds of files and will be a bit messy.
macsrwe
Re: Winbox 3 RC
Sat Jun 20, 2015 4:46 am
I have confirmed a similar problem with 3.0 rc12. I just netinstalled a shipment of a half dozen new mAP and hAP units. After I netinstall either out of the box, Winbox sees it no problem (except for one of the hAPs, which never showed up at any time). Once I load my generic configuration onto it, Winbox won't pick it up anymore unless you type the MAC address manually. An old copy of "MikroTik Neighbor Viewer" (that I've had for four years and use very rarely) picks the device up immediately, every time, but Winbox rc12 just sits there, blank I ran a ten-minute session on one of the mAPs and Winbox never showed it as a neighbor until I shut it down and logged out -- then suddenly it appeared.
It's not a firewall problem, because I don't load any firewall rules, NAT, or anything else. Each of our mAPs and hAPs is configured as just a dumb AP bridge (switch chip bridging the ethernets, added to software bridge for the wireless) with a single IP address, which is pretty simple.
Winbox 3.0 really does have neighbor protocol problems.
WirelessRudy
Re: Winbox 3 RC
Mon Jun 22, 2015 1:04 pm
dada +
WirelessRudy +
Noticed the same, very irritating...
WirelessRudy
Re: Winbox 3 RC
Mon Jun 22, 2015 1:11 pm
I have to set the long cable by default. Even on 2 or 3 units attached with 1 mtrs pre-fab cat5e or 6 cable (shielded and or not) and even sometimes it works for a couple of days, after a while units can't be powered up anymore by the rb750. It makes the whole 750 to start flipping. Only setting the long cable option make it work again. We use it by default now because its the only way to get a reliable PoE device at remote site......
WirelessRudy
Re: Winbox 3 RC
Mon Jun 22, 2015 1:19 pm
Installed loader v.3.0rc12 this weekend and since can't open any new router anymore that has basic factory setting.
I have to open it with old loader first, upgrade the routerboard and only after that the discovery tool will find it.
Then, mac sessions to routers on my desk are very unstable. I have quickly to set a dhcp-client on the board so it picksup a IP from my server and than login by IP. Otherwise it's a matter of less than a minute before board disconnects.
Sometimes boards just don't connect by mac. I can try many times and board comes up to close inmediately.
Old winbox doesn't have any of these issues. It just does do what it is suppose to do, open a board. Either by mac or by IP if is has one....
I've got the feeling each new loader's update brings new issues... its almost lika ROS procedures! Disregard the first 20 or so versions because they give you more headaches than it solves...... :( :( :(
WirelessRudy
Re: Winbox 3 RC
Mon Jun 22, 2015 1:38 pm
I think the website should still have the old v2. loader version as first choice. Not this unstable release candidate.
At times you are out in the field without a laptop so use the client's device. Need to download winbox and get this unstable version... I wan't the 'old' stable one...
jarda
Mon Jun 22, 2015 8:19 pm
What version of winbox do your devices offer on their login page?
WirelessRudy
Re:
Tue Jun 23, 2015 1:23 am
I don't understand your question? I login with winbox loader. "Login page"? If you mean the webpage of the building webserver? Never use that....
The bottom line is; when I take a new router out of the box (so factory default) I can't open it with the new winbox. If this is what MT thinks of improving winbox I think they lost directions....
Hotz1
Re: Re:
Tue Jun 23, 2015 1:50 am
If you leave 3.0rc12 open long enough (on the order of a minute or two), it will eventually display the factory-default RB.
I consider this just slightly less painful than entering the MAC address manually. :?
WirelessRudy
Re: Re:
Tue Jun 23, 2015 2:25 am
Well, tried that, but on some units after 5 mins still nothing happened. And some indeed after a longgggg time connected.
I use now the 'old' loader to find and open de board the first time. After I've set a dhcp-client I take the IP and go from there with the new loader. After upgrade to latest ROS the new loader 'sees' the board....
But far from an improvement......
jarda
Winbox 3 RC
Tue Jun 23, 2015 6:44 am
I just wanted to say that the webpage of each (excluding smips) device offers the winbox v. 2. There is no need to search for it elsewhere. I am using v.3rc12 for some time already having no problems with any new or old devices. Just once it didn't detetect the new neighbour device. So I opened other neighbouring device, use look at its neighbours, copy the mac and put it into winbox 3rc12.
Maybe the explore delay could be caused by more than one network interfaces of winbox running computer connected to the same network as it is definitely my case.
jstump
Re: Winbox 3 RC
Tue Jun 23, 2015 9:06 pm
Aside from portability/sync support for my saved sessions, I'd love to see the title bar show the router identity first, then the user@ip so that I can more easily tell which session is which in my taskbar when I have 5+ open!
mboy
Re: Winbox 3 RC
Thu Jun 25, 2015 12:29 pm
Please add the export and import addresses from a CSV (Tool>Import,Export)
WirelessRudy
Re: Winbox 3 RC
Thu Jun 25, 2015 1:03 pm
That's no help. New routerboards come by default with another network than we use. So as long as I didn't change the IP of the interfaces to be in my network I can't open any webpage. The whole fun of winbox loader used to be we have access to routers independed if its in an IP network or not. But that advance use compared to other that have IP-level access only is now gone.
The big 'love' for winbox loader by many was that no matter what network issue you had, you could always login to a router with winbox loader, even without knowing its IP or network it was set for. Now we are losing this advance...
The 'old' loader never had such issues. Why should we now have to find work arounds on a new upgraded version?
No. It happens on all of our 7 different office PC's. None of them have more than one interface. But yes, they are all in one network. But again, 'old' loader has no issues.
jarda
Re: Winbox 3 RC
Thu Jun 25, 2015 1:34 pm
WirelessRudy,
what is the problem with saving a winbox.exe from one of your router to your computer local disk and use it whenever you want?
I have not lost any advance with 3rc12. There is no limitation to use Layer3 only, the Layer2 works also normally like always. In case I need, I still can run v2.2.18. Both are locally stored on my disk...
WirelessRudy
Re: Winbox 3 RC
Thu Jun 25, 2015 3:29 pm
WirelessRudy,
I'm not quit understanding what you are asking here?
On all my 7 PC's and 4 laptops we have winbox.exe stored (not all the latest but ok) like we downloaded them from the Mikrotik website.
On 3 of the working stations in use for day to day configurations of new units we also have the old winbox loader.
These are on the desktop, but like all info on a PC, ultimately stored on the hd.
So we can use it whenever we want. And I have been one of the users in this forum over the past asking serveral times for improvements on the 'old' winbox loader. When they now finally started to make upgrades (I have installed almost all version when they were released) I was delighted to see the new options finally making it.
BUT (almost as usual, like ROS) they come with lots of errors and new issues. Some of the new versions were hard to work with. My technicians hate the new versions now and all fell back to the old v2 winbox loader...
I didn't download a winbox loader yet from a routerboard for 2 reasons:
1. I need IP level connectivity to do the download. After all we need to browse to the routerboard? Since the board is connected with the ethernet port that has another default network as ours we can't login by html. (And we DON'T want to work with the default 192.168.88.0/24 network that everybody knows now. Would be a bad idea anyway. Sometimes we hook up 2 or 3 new devices at the same time. If we would have a .88.0/24 network we would create IP conflicts every time again. All boards have the same IP.)
2. The version to be downloaded from the website, or downloaded as result of the upgrade order, should be working.
I just can't understand why they are not able to make a simple working version that works under all circumstances.... like the old v2.x?
But than again, I complained about this in version 3.2 or 3.3 or so and at the time I got the reply I was the only one complaining and the rest of the user group was very happy! Well, now we are at version 3.12 or so and many, many more posts with remarks and complaints later and still it doesn't.
But I'll guess after 10 years using MT I still don't understand how it works with Mikrotik.....
BartoszP
Re: Winbox 3 RC
Thu Jun 25, 2015 4:28 pm
RC 12 does not recognize SwOS devices or it takes ages to discover them.
WinBox 2.x finds them the time and immediately.
macsrwe
Re: Winbox 3 RC
Thu Jun 25, 2015 6:53 pm
My machine to setup newly-purchased CPEs has one interface, and is plugged directly into each CPE being initialized, so there is only one device on the cable. Winbox 3 still takes either a long time to show each device, or never shows it. Winbox 2 and MT Neighbor Viewer show it immediately. Once the unit has been upgraded to 6.29.1, it appears somewhat more reliably, but still I need to quit and re-open Winbox 3 frequently to get it to show a router when I switch to a new unit on the cable without closing Winbox.
pukkita
Trainer
Trainer
Re: Winbox 3 RC
Thu Jun 25, 2015 11:35 pm
A feature I'm constantly missing is a filter/search feature for the logs. Would be a very nice feature to have.
macsrwe
Re: Winbox 3 RC
Sat Jun 27, 2015 7:57 am
I encountered some bizarre sorting behavior in 3.0rc12 (don't know when it was introduced)...
View the firewall filters. Click on the action column to sort by action. Now click on the # column to return to the standard top-to-bottom view. The view returns for a second or two, then immediately jumps back into a sorted view. This happens no matter what other column you sort by -- you can never return to normal order view any more.
This behavior doesn't fail in other places, e.g., firewall nat.
The ROS in question was 6.29.1.
mboy
Re: Winbox 3 RC
Sat Jun 27, 2015 12:16 pm
fronik
Re: Winbox 3 RC
Tue Jun 30, 2015 10:44 pm
Pleeeeeeeassse, added support portable!!! It's so easy to implement now!
Please check the configuration files in folder winbox.exe.
If found file config in winbox.exe folder then use them.
If not found file config in winbox.exe folder then use %appdata%
It is very necessary and very useful feature!
Sorry for my English. I use Google translate.
Users browsing this forum: BenceLK, billyerasmus101, GoogleOther [Bot], HeinoHomm, sas2k and 194 guests
