Hello.
I'm trying to make a PCP field to propagate through CRS-125-24G without success.
PCP is set with bridge rule on CCR, then travels with VLAN to the CRS. I use mirroring to sniff out packets.
I can see the PCP field set on packets entering the switch on port 1, then they leave with the field unset (0) on the other.
I have set egress vlan translation on out port with pcp propagation set.
I have set egress PCP propagation for exit port
I have set ingress PCP propagation for input port.
VLANs work as expected, just the missing pcp field is the problem.
ROS v 6.29.1
I don't think that any bridging is an acceptabble solution. It's a switch, we should be switching.
config as follows (cut down to most important parts) :
port 1 is the trunk where tagged (with prio set) traffic comes in from router
on port 21 there is the AP that i want to receive tagged and prioritized traffic
set [ find default-name=ether1 ] name=ether1-master-downlink
set [ find default-name=ether2 ] master-port=ether1-master-downlink name=ether2-slave-uplink1
.. to all ports
add ports="ether1-master-downlink,ether2-slave-uplink1,ether3-slave-uplink2,ether5-slave-srv1,ether6-slave-srv2,ether7-slave-wicedyrektor,ether8-slave-ksiegow\
osc,ether9-slave-qnap,ether10-slave-pracownicy,ether11-slave-pracownicy,ether12-slave-pracownicy,ether18-slave-AP,ether19-slave-AP,ether21-slave-APs3,swit\
ch1-cpu" vlan-id=10
add ports="ether1-master-downlink,ether3-slave-uplink2,ether4-slave-uplink3,ether13-slave-AP-mgmt,ether18-slave-AP,ether19-slave-AP,ether20-slave-AP,ether21-s\
lave-APs3,ether22-slave-APs7,ether23-slave-APs10,ether24-slave-APs14,switch1-cpu" vlan-id=50
add ports=ether1-master-downlink,ether14-slave-goscie,ether19-slave-AP,ether21-slave-APs3,switch1-cpu vlan-id=30
add ports=ether1-master-downlink,ether19-slave-AP vlan-id=20
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether1-master-downlink,ether3-slave-uplink2,ether19-slave-AP,ether21-slave-APs3,switch1-cpu vlan-id=10
add tagged-ports=ether1-master-downlink,ether2-slave-uplink1,ether3-slave-uplink2,ether4-slave-uplink3,switch1-cpu vlan-id=50
add tagged-ports=ether1-master-downlink,ether19-slave-AP,ether21-slave-APs3,switch1-cpu vlan-id=30
add tagged-ports=ether1-master-downlink,ether19-slave-AP vlan-id=20
/interface ethernet switch egress-vlan-translation
add customer-vid=50 customer-vlan-format=tagged new-customer-vid=0 pcp-propagation=yes ports=\
ether13-slave-AP-mgmt,ether18-slave-AP,ether19-slave-AP,ether20-slave-AP,ether21-slave-APs3,ether22-slave-APs7,ether23-slave-APs10,ether24-slave-APs14
add customer-vid=30 customer-vlan-format=tagged pcp-propagation=yes ports=ether21-slave-APs3
add customer-vid=10 customer-vlan-format=tagged pcp-propagation=yes ports=ether21-slave-APs3
set 0 egress-pcp-propagation=yes pcp-propagation-for-initial-pcp=yes qos-scheme-precedence=\
pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 20 egress-mirror-to=mirror0 egress-pcp-propagation=yes ingress-mirror-to=mirror0 pcp-propagation-for-initial-pcp=yes qos-scheme-precedence=\
pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based vlan-type=edge-port
ch1-cpu" vlan-id=10
