eworm
6.31rc16 and wireless-cm2 high CPU load
Tue Aug 11, 2015 6:38 pm
Just updated to version 6.31rc16, but it breaks. This system is CAPsMAN.
[admin@jupiter] > /system resource print
                   uptime: 4m13s
                  version: 6.31rc16
               build-time: Aug/11/2015 12:53:46
              free-memory: 81.4MiB
             total-memory: 128.0MiB
                      cpu: MIPS 74Kc V4.12
                cpu-count: 1
            cpu-frequency: 600MHz
                 cpu-load: 100%
           free-hdd-space: 108.8MiB
          total-hdd-space: 128.0MiB
  write-sect-since-reboot: 213
         write-sect-total: 27885284
               bad-blocks: 0.2%
        architecture-name: mipsbe
               board-name: CRS125-24G-1S
                 platform: MikroTik
[admin@jupiter] > /tool profile
NAME                    CPU        USAGE
ovpn                    all           0%
wireless                all          64%
spi                     all           4%
ethernet                all           1%
ntp                     all           0%
console                 all         0.5%
flash                   all        27.5%
ssh                     all         0.5%
networking              all           0%
management              all           0%
profiling               all           0%
queuing                 all           0%
unclassified            all         2.5%
Commands in / caps-man do not finish. Looks like I have to go back to v6.30.2...
plisken
Re: 6.31rc16 and wireless-cm2 high CPU load
Tue Aug 18, 2015 8:20 pm
Update your router with RoS 6.31
eworm
Wed Sep 02, 2015 10:42 pm
This still happens on update from version 6.31 to 6.32. Had to update all CAPs manually first, then CAPsMAN.
plisken
Thu Sep 03, 2015 11:10 am
Try disable Capsmanager maby a bug.
eworm
Thu Sep 03, 2015 12:28 pm
Sure this is a bug. :-p
To disable CAPsMAN is not an option... I do need it. However the workaround (to update the CAPs first) works for me.
My guess is that the CAP update functionality in CAPsMAP is broken with the new release model.
plisken
Thu Sep 03, 2015 12:58 pm
Downgrade to the working version.
I hope that's working
Sorry for my bad Englisch
Ridddick
Tue Dec 01, 2015 9:07 am
No, it's not. ROS 6.30.2, capsman is still loading 100% cpu during caps registration, some caps are disconnecting. Awfull. :(
eworm
Tue Dec 01, 2015 3:06 pm
You should update your CAPsMAN to 6.32.3 (latest bugfix) or 6.33.2 (latest current). CAPs will connect and do auto-update if configured.
Ridddick
Thu Dec 03, 2015 5:51 pm
I was on 6.32.2 when i faced with the problem then updated to 6.34rc6 then downgraded on 6.30.2 but the result was the same.
