Are you planning to do xml/sql export to the user manager database?Thank you,
Is there an estimated date or release number for this update?
create a profile in your routeros hotspot, give it a name and set it to your desired simultaneous number u needThis thread has several requests for "simultaneous-use" or "multiple session" support in User Manager. As far as I can tell this is not supported in 3.6 and I have not seen any reply about whether this is being considered.
What I would like is for a single user account to be able to sign in with multiple computers at the same time instead of getting an "already logged on" error.
Mikrotik and RouterOS rocks!
Nate
I too have also adapted those scripts for our setup with excellent success. We have managed to control many aspects of usermanager and ROS etc via scritpting.
These scripts I mainly got working due to a excelent scripter, qnect. I took his script and rewrote it to my needs with great success.
Hey Heiko In my siggy is the url to the script he uses. However he has edited his to meet his requirements, if you needs his then you will have to get it from him but if you want the original you can get it from the url below. Good luck -JordanHi "G" ,
i'd like to do some scripting for Userman to get accountin infos via email.
I think very similar to that what you are doing.
Is it possible that you send me your script via email or post it here? ;o)
Many thanks in advance!
Regards
Heiko
Hi airstream,I too have also adapted those scripts for our setup with excellent success. We have managed to control many aspects of usermanager and ROS etc via scritpting.
Hi AirstreamI too have also adapted those scripts for our setup with excellent success. We have managed to control many aspects of usermanager and ROS etc via scritpting.
Hi Heiko
Can anybody say why there is no syntax highlighting in the editor an why you don't get ANY information why a script isn't running?
Is there a hidden feature to get debug informations ?
Heiko
I have used /log info "script working untill this point"Hi Heiko
Heiko
Unfortunately there is no debugger or syntax highlighting in the editor. I have also requested the syntax highlighting feature, as it's already working in MT3.x CLI. I debug by hashing out certain lines (put a # on the left of a newly added line) and remove the hashes till I find the problem.
You can also test your lines in the CLI and by using tabs (press the tab key) to see your valid entries.
G
Indeed this is the best way to troubleshoot scriptsI also use log entries, and specify variables so I can see the variables's actual values at that time eg:
:log info "The A variable's value is: $a and B Variable's value is $b"
This is extremely useful when working with foreach, while, etc loops
Sure, I have a few helpful scripts I can share as well as backwards compatible 2.9 versions.
Hi Airstream
Would you mind sharing your version? Perhaps we could learn from each others' scripts!
I'll trim mine a bit over the weekend and post asap!
G
Or even better would be to allow us to choose which fields we want to see on the screen, as I would like to see the date the user activated but don't need to see the first or last names (or macs for that matter) because you can always click on the user and get the personal info.It would also be really handy if the User List in userman could show "First Name" "Last Name" fields, as with username set to MAC address its hard to identify which account belongs to what user
There is a field "Caller ID" in the new User Manager for specifying MAC address of the user.Please Add Mac Binding too
aweseom, what about billing? is anything being done with that? -JordanThere is a field "Caller ID" in the new User Manager for specifying MAC address of the user.Please Add Mac Binding too
There is no straight way for User Manager to know, which IP belong to each IP pool, as the pool may be located on completely different router.yea instead of Pool name there should be a drop down option to select pool & below it second drop down option to select ip address from the selected pool. this way it will be very easy to assign ips or pool & also no one will assign same ips for more then 1 users.
User Manager could check IP pools of the local router. But it would not help if the Hotspot/PPP is located on remote router.it would be great if we can make ip pools in usermanager. it can be done if name & ips of the pools are same with the pools created in routers.
can you add this feature in future?
it is too hard to remember pool names & ip address.
please can you show me some screenshots of your UM?We do this on our own system by having a list of gateway devices (hotspot routers) that we can use the API to pull data from, including things like free sites, ip-pools etc.
Just something for you to oogle over, its not for saleplease can you show me some screenshots of your UM?We do this on our own system by having a list of gateway devices (hotspot routers) that we can use the API to pull data from, including things like free sites, ip-pools etc.
donePlease, send the suggested demo link to support[at]mikrotik.com !
can we integrate sms & mail server to send sms & mails to users
Also automatic sms & mailing system to warn users to recharge their account before 2 days of expiry or if their bandwidth limit is almost finished.
Also if possible warning message in userpage too
sorry i know that my expectations are high
Warning emails upon reaching some usage level are already in planned feature list. And scheduled reports (for example, daily/monthly usage) report as well. And we will consider SMS report option.can we integrate sms & mail server to send sms & mails to users
It is already in our feature request list and will be implemented.can you place a tick box beside caller id so that if the tick box is ticked user macid will be automatically placed to his caller id when he will login for 1st time & also make that box default ticked when we add new user.
Disabled row foreground color is now configurable as style attribute.2. can you change color of disabled user in user list from grey to red
complaint="Description of a complaint" status=active
complaint="Description of another complaint" status=solved
It's already in our TODO list.More csv template options
Creation Date, Renewal Date, Expiry date, Profile, Phone, IP address, Caller ID, Shared users, First name, Last name, Location, Comment & Email.
This will not be implemented due to performance reasons.also add All in perpage option.
Specify uptime limit (not credit/profile validity time) in this case.Assuming someone asked for like 1hr browsing
That's how it is designed - first local HotSpot user table is checked, if user is found there, no request is sent to User Manager.if you create a user in hotspot thru winbox, and incidentally the same name is created in UM with a different password, that user cannot login with the account created in UM.
That's already available in version 4.I want Mikrotik to implement timed option in their UM, where a user can browse based on time band, Morning hours (6am - 9am), evening hours, Night and wkends so that users can choose time band that suites them
Is there an estimated implementation time for this feature?It is already in our feature request list and will be implemented.can you place a tick box beside caller id so that if the tick box is ticked user macid will be automatically placed to his caller id when he will login for 1st time & also make that box default ticked when we add new user.
you use an ancient version. buy a license and install v4 where all the new features are inhello,
user manager is great, i use box 2.9.27. but my user manager does not have days of expiry for each ticket or batch i try to generate, is there soution for this .
pls forum let me know whats up.
God bless Mikrotik
I am runung UM v4.4 but cant get this features! gone the manual but finding difficult. Where exactly is this features? Credits, Users, Customers etc?Specify uptime limit (not credit/profile validity time) in this case.Assuming someone asked for like 1hr browsing
