Um, not sure if this topic is closed - but I am having small issues with the usermanager bundled with v5.
Not anything hectic, functionally the manager seems fine, for what I do with it. Just the updates to the screen when working on the web site are buggy, can you add a "refresh button" please, so after you have changed the profile of a user on the user page, the page updates. Currently I have to re-sort the list to get the new profile displayed.
Also, when adding / changing profiles in the profile section , the refreshing also isnt great, if I scroll between the profiles, sometimes the name I assigned , gets assigned to all the profiles, and even worse, sometimes the actual profile name, if I add a new profile, then choose an old profile in the drop down list, gets given the same name as the new profile, so the names all get messed up - very weird behavior.
And, in the limits section, there is no "save" button, only an "add" button - which is for saving - thats confusing - cant it be called "save" rather because if you make a change, why do you then click on "add" to save the change?. Surely "add" should be for creating new entries, not changing existing ones..
Otherwise, the upgrade from v4 to v5 worked easily enough, except I had 100 users, so I had to manually assign the profile to each user since you cant do it via cli and there is no way in the gui to select many users, and set their profile at same time, you can choose a lot of users, and remove but not make a global profile change.
O ya, just remembered, when I select a bunch of users, then choose disable - I get some strange script error pop up window. If I click ok, then log out and back in , the users appear to be disabled - and I get the same error when enabling them as well.
Still happy with the application though.
