• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Userman help please. 4 timeouts after every reboot.  Page 1 of 1
 [ 4 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
kameelperdza
 Post subject: Userman help please. 4 timeouts after every reboot.
PostPosted: Mon Oct 26, 2009 11:27 pm
Offline
Hi when i reboot my mikrotik then when it starts and i cheack my radius server then it will show that there is 4 timeouts. But everyone that should be connected is connected. And there is no one that is trying to connect to me.
Here is what userman log says
Code:
  16  0.0.0.0 127.0.0.1 Jan/01/2002 01:00:09 accounting failure
  19  0.0.0.0 127.0.0.1 Jan/01/2002 01:00:17 accounting failure
  20  0.0.0.0 127.0.0.1 Jan/01/2002 01:00:33 accounting failure
  21  0.0.0.0 127.0.0.1 Jan/01/2002 01:01:05 accounting failure
  3 00:0C:42:61:4D:29 0.0.0.0 10.0.0.1 Jan/01/2002 01:00:15 authorization success
  15 00:0C:42:61:4D:29 0.0.0.0 127.0.0.1 Jan/01/2002 01:36:21 authorization success
  18 00:0C:42:61:4D:29 0.0.0.0 127.0.0.1 Jan/01/2002 01:00:15 authorization success
  14 00:02:6F:43:3A:18 0.0.0.0 10.0.0.2 Jan/01/2002 01:36:21 authorization success
  2 00:0C:42:60:01:F2 0.0.0.0 10.0.0.1 Jan/01/2002 01:00:14 authorization success
  12 00:0C:42:60:01:F2 0.0.0.0 127.0.0.1 Jan/01/2002 01:36:13 authorization success
  13 00:0C:42:60:01:F2 0.0.0.0 127.0.0.1 Jan/01/2002 01:36:20 authorization success
here is my tool user-manager customer says
Code:
 0   subscriber=MikroTik login="MikroTik" password="password"
     time-zone=+00:00 permissions=owner parent=MikroTik signup-allowed=no
     paypal-allowed=no paypal-secure-response=no paypal-accept-pending=no
and here is tool user-manager router
Code:
 0   subscriber=MikroTik name="KKT-HS" ip-address=127.0.0.1
     shared-secret="123456" log=auth-ok,auth-fail,acct-ok,acct-fail
 1   subscriber=MikroTik name="Emile-HS" ip-address=10.0.0.2
here is tool user-manager user
Code:
 1     subscriber=MikroTik name="00:0C:42:61:4D:29" password=""
       first-name="Hannes Home" last-seen=jan/01/2002 01:00:15 credit-count=0
       credit-left=0s credit-duration=0s credit-price=0 credit-time-added=0s
 2     subscriber=MikroTik name="00:1B:77:61:2F:D6" password=""
       first-name="HP 530" last-seen=jan/02/1970 01:08:32 credit-count=0
 3     subscriber=MikroTik name="00:02:6F:43:3A:18" password=""
       first-name="LB de Wet Home" last-seen=jan/01/2002 01:36:21
       credit-count=0 credit-left=0s credit-duration=0s credit-price=0
 4     subscriber=MikroTik name="00:0C:42:60:01:F2" password=""
       last-seen=jan/01/2002 01:00:14 credit-count=0 credit-left=0s
 5     subscriber=MikroTik name="00:02:6F:48:82:E7" password=""
another thing that i would like to know is must router "Emile-HS"(in router list) be added to the user list? I had to do that so that i can connect. But i dont think that they say in the wiki that the routers on the router list must be added to the user list.
Code:
is
Code:
I have also increased the timeout to 3000ms but that did not help
My ip addresses on KKT-HS(radius server) is
Code:
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   10.0.0.1/24        10.0.0.0        10.0.0.255      wlan1
 1   172.19.85.201/24   172.19.85.0     172.19.85.255   bridge1
 2   192.168.0.10/24    192.168.0.0     192.168.0.255   ether1
 3   10.0.1.1/24        10.0.1.0        10.0.1.255      wlan2
Wlan1 is used to connect to secondary router(Emile-HS)
If someone please can tell mewhat i should do then it would help alot.
I want to know what must i make my radius server ip? Must i add secondary router(Emile-HS) to the router-list and user-list?
Any help would e appreciated. thanx :(
_________________
MTCNA
Top
 Profile
sergejs
 Post subject: Re: Userman help please. 4 timeouts after every reboot.
PostPosted: Tue Oct 27, 2009 3:31 pm
Offline
If you have User Manager and router on the same IP, then use 127.0.0.1 as IP address in /tool user-manager router and /radius.
Please, use radius timeout 300ms or lower, it is not necessary to use bigger one.
Top
 Profile
kameelperdza
PostPosted: Wed Oct 28, 2009 8:06 am
Offline
Thanx my radius is working but i still get timeouts.
I have done some test. First i set time ms to 100ms and then to 3000ms. I have disabled all wlan interfaces and rebooted the mikrotik.When i checked the radius status i saw that there was 4 timeout. So i went to useman/log and see there is four errors.
they are....
1 0.0.0.0 127.0.0.1 Jan/01/2002 01:00:07 accounting failure
6 0.0.0.0 127.0.0.1 Jan/01/2002 01:00:15 accounting failure
8 0.0.0.0 127.0.0.1 Jan/01/2002 01:00:22 accounting failure
9 0.0.0.0 127.0.0.1 Jan/01/2002 01:00:31 accounting failure
When i click on one of then then is says this....
Username:
User IP: 0.0.0.0
Host IP: 127.0.0.1
Status: accounting failure
Time: Jan/01/2002 01:00:07
Description: missing User-Name
NAS Port: 0
NAS Port Type: unknown
NAS Port ID:
ACCT Session ID:
Calling Station ID:
Why would it do that, but the radius server does work
my userman/router looks like this...
Emile-HS 10.0.0.2 123456 auth ok & auth fail & acct ok & acct fail
KKT-HS 127.0.0.1 123456 auth ok & auth fail & acct ok & acct fail
_________________
MTCNA
Top
 Profile
alex_rhys-hurn
 Post subject: [SOLVED] Re: Userman help please. 4 timeouts after every reb
PostPosted: Fri Feb 18, 2011 4:04 pm
Offline
I know this is an old thread, but I wanted to mark it as solved for anyone else searching for this issue.
I had EXACTLY the same problem, and this seems to be a bug/fault in the userman radius server when it is upgraded.
My solution was to upgrade to the next release of routeros.
My problem in short was that the logs showed that the user was authenticated successfully and the userman logs showed that too, but the reply from radius back to hotspot failed.
Alex
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 4 posts ]
Board index » Other topics » The User Manager
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
