maxwind
user manager session logs print or export
Wed Aug 04, 2010 5:22 pm
hi,
i would like to know if it is possile to export or print the session log.
i have 2 hotspot with centralized radius with an rb450g.
i need to print the session logs and hand them over to the hotspot holder.
thank you for your help.
Massimiliano
maxwind
Re: user manager session logs print or export
Tue Aug 10, 2010 10:35 am
some answer ??
thank you
Christiano
Mon Aug 30, 2010 8:30 pm
Session Logs i don´t know but with the logs, in terminal of winBox:
/system log print file=test.txt
In winBox, go to menu files. In window 'Files list' you see the 'test.txt'. Click, drag and drop the desktop windows for example.
I think is the same with session logs. Use tab key to autocomplet help and see the options of command in terminal of winbox.
