hugo007
Usermanager on Version 5.11
Thu Dec 15, 2011 1:34 am
Hello all
today I update my router board to the last version and I want to use the user manager.I was reading the way how it works and I'm confused, does the package will also work on the last version (5.11)?
I have the package installed but it wont open the web site manager using http://ip_router_board/userman
I also change the default port WWW to 81 just in case but nothing.
Can someone give me a tip ?
thanks for all
Bongo
Re: Usermanager on Version 5.11
Sat Jan 07, 2012 5:16 pm
Check your STORE option under system
should show usermanager active
if not set it active
cybercoder
Sun Jan 08, 2012 10:48 am
is there Hotspot server on that mikrotik OS?
hugo007
Sun Jan 08, 2012 1:19 pm
I have the module enabled and stangly it can be acessed outside of my lan. In my configuration I have a ppoe client to autenticate from my ISP ADSL and then a NAT to a local lan. today I notice if I try to acess from the Internet side it works!!
I also have hotspot configured internaly, could it be because of this?
cybercoder
Sun Jan 08, 2012 8:16 pm
if you are connected to hotspot, you can allow direct connection to router by set the address in walled garden.
Users browsing this forum: No registered users and 31 guests
