hemant
User Manager 5.11 & RouterOS Login
Sun Dec 18, 2011 2:26 pm
Hello Guys,
I am new to this forum, Came here to find the solution a problem which is driving me nuts from past 3 days.
I have a RB1100 which is connected to RB433AH and my Laptop.
RB1100 ether1 -10.40.2.3/24 -----Laptop 10.40.2.4/24
RB1100 ether4- 10.40.2.1/24-----RB 433AH ether3 10.40.2.2/24
I have UserManager 5.11 installed in RB1100 ROS 5.11 and using the Login Authentication in RB433AH ROS 5.11,
I did in RB433AH #radius add service=login address=10.40.2.1 secret=123456, other setting(ports) remained default.
And also in the User AAA use radius and accouting & default Group is set to full.
In the usermanager i created a Customer first login=hemant password=password parent=admin permissions=full
then i added the RB433 Router Name=MikroTik(sys identity of RB433) Owner=hemant ip address=10.40.2.2 shared secret=123456 with all the logs
Then i created a User username=user password=pass owner=hemant
After all that i tried to connect to my RB433ah from RB1100 by telnet with user and pass created on UserManager,Cann't Log into It.
I checked the Radius Stact. in RB433AH it was sent=10 reject=10 some thing like that..
Can any one help me here...I want to Create the user on a Single RB with Usermanager and Then want to use these users to login to other RB's by the Radius there..
Please Any guidance here..??
cybercoder
Re: User Manager 5.11 & RouterOS Login
Sun Dec 18, 2011 3:15 pm
I think you should assign a profile to user
check the Log of userman, it will be very helpful.
hemant
Sun Dec 18, 2011 3:25 pm
Tried Assigning the profile to the user. was not working in this scenario also.
The log says authentication failure, user<user> not found in users.
cybercoder
Sun Dec 18, 2011 3:30 pm
check is there a user with that username in USERS menu? :shock:
USERS and CUSTOMERS is diverse
hemant
Sun Dec 18, 2011 3:36 pm
Here it is cody the created user, i tried with creating 2-3 more users,then tried to login in to RB433AH with user account and customer account both were not working. I tried with customer login name to just give it a try, may t will be work,
yes it is also not working with the created users in usermanager i created.
I check the RB433AH Radius statics it was sent=11 and reject=11, i have ping to usermanager router from my RB433AH.
So what now Friend..?? :(
cybercoder
Sun Dec 18, 2011 4:21 pm
/radius
add accounting-backup=no accounting-port=1813 address=127.0.0.1 \
    authentication-port=1812 called-id="" disabled=no domain="" realm="" \
    secret=123 service=login timeout=3s
/user aaa
set accounting=yes default-group=full interim-update=0s use-radius=yes
Usermanager :
/tool user-manager profile
add name=login name-for-users="" override-shared-users=off price=0 starts-at=\
    logon validity=0s
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin parent=admin password="" \
    paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
    permissions=owner signup-allowed=no time-zone=-00:00
/tool user-manager router
add customer=admin disabled=no ip-address=127.0.0.1 log=\
    auth-ok,auth-fail,acct-ok,acct-fail name=Mikro1 shared-secret=123
/tool user-manager user
add customer=admin disabled=no name=1 password=1 shared-users=1 \
    wireless-enc-algo=none wireless-enc-key="" wireless-psk=""
I did that about a minute ago as example for you, and it worked on ROS 5.11 well.
hemant
Sun Dec 18, 2011 5:20 pm
Thanks a lot Cybercoder
It worked finally, I resetted both the routers and again did the same configuration.
But this time i had same name for the user and customer.
Now trying some users for the read only access.
You saved my day man..Thanks
Users browsing this forum: No registered users and 25 guests
