maxcuban
setting up usermanager via winbox
Mon Dec 10, 2012 2:14 am
hi everyone,
pls i have a new routeroboard RB951-2n and have set up hotspot but i want to
add usermanager to it.
i followed a very convenient online step by step guide but once i completed,
i entered router-ip/userman and i got
ERROR 404 - NOT FOUND
I would like to know if anyone can direct me to a step by step guide that works (using winbox)
to set up user manager or if you can help me fix the problem.
ps. i've seen a very similar and recent post but i didn't follow the solution because according to the OP, everything works right except when creating user. but in my case nothing is really right.
thanks,
max
skot
Long time Member
Long time Member
Re: setting up usermanager via winbox
Mon Dec 10, 2012 4:45 am
1. You need to download the All Packages files that has the same version as your router from http://www.mikrotik.com/download
2. Extract the user-manager....npk file from the .zip archive.
3. In Winbox, click the Files menu, and drag+drop the user-manager...npk file into this window. You could also use ftp.
4. After the upload is complete, reboot the router (In Winbox, System > Reboot)
After reboot, I think the logs tell you whether the new package was installed successfully or not... Assuming install was successful, router-ip/userman should be accessible.
I don't need any karma... I have Ιησους Χριστος!
maxcuban
Tue Dec 11, 2012 12:23 am
this is exactly the setup i went through.. though i have routerOs 5.16 so i used the all packages for that version and copied the usermanager file from there.
when i go to system --> packages, i can see usermanager there
but one thing is i already set up hostpot on i already.. could that be conflicting?
thanks
skot
Long time Member
Long time Member
Tue Dec 11, 2012 12:45 am
Perhaps if you trying to connect from behind the hotspot. See the Note at the bottom of this page: http://wiki.mikrotik.com/wiki/User_Mana ... _interface
samuelongui
Tue Dec 11, 2012 7:15 pm
Are you connected to the hotspot's interface or where?
maxcuban
Wed Dec 12, 2012 9:06 am
yes i am connected to the interface.
but in the mean time i want to try the workaround in the link provided by Skot and see how it goes.
I will provide feedback when am done
thanks
samir494
Thu Dec 13, 2012 12:50 pm
hi,
go to ip, hotspot , server profile select you hotspot server, tick us raduis
now move to radius (ln main Menu ) set ip 127.0.0.1
ref attached snaps
Mistry Samir
Unique and Different
India
9920670022
Give me more Karma
maxcuban
Wed Dec 19, 2012 12:54 pm
look at these screen shots.
everything seems to be in order
but still can't access router-ip/userman
whether inside hotspot or outside hotspot interface.
help needed pls :(
--max
radius server
userman shows rightly installed
radius configuration
samir494
Wed Dec 19, 2012 2:59 pm
it seems ok,
let check r u able to login in hotspot ? if yes than share IP add details
or you can share me valid out side ip or Team viewer from your pc which is connect to internet
Mistry Samir
India
9920670022
Give me more Karma
maxcuban
Wed Dec 19, 2012 4:06 pm
samir494 wrote:
it seems ok,
my hotspot router_ip is 192.168.88.1 so am trying to connect to userman via 192.168.88.1/userman
with no success.
yes, am able to connect to the hotspot alright. but still 192.168.88.1/userman doesn't bring up the usermanager interface
samir494
Mon Dec 24, 2012 9:18 am
try to bypass you ip from hotspot and check you userman access
Mistry Samir
India
9920670022
Give me more Karma
maxcuban
Thu Dec 27, 2012 7:16 pm
how do i do that please?
ditonet
Forum Veteran
Forum Veteran
Fri Dec 28, 2012 1:57 am
Grzegorz | MTCNA, MTCRE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
samir494
Fri Dec 28, 2012 7:42 am
snap attached
Mistry Samir
India
9920670022
Give me more Karma
maxcuban
Thu Jan 03, 2013 3:02 pm
samir494 wrote:
snap attached
thanks very much. I did it yesterday and since then i've had usermanager working.
but one more thing pls, the routerboard has 5 ports, I'm using port one for WAN, port 2 for the hotspot interface but i don't know how to configure it so that ports 3,4,5 will also work as LAN interface so we can connect cables for customers whose laptop's wireless isn't functioning..
I really appreciate you help so far, regards, max
samir494
Thu Jan 03, 2013 3:09 pm
open port three , there is option called " master port" select ether2
repeate the same for 4 & 5
Mistry Samir
India
9920670022
Give me more Karma
maxcuban
Thu Jan 03, 2013 5:12 pm
cool, it's working now..
Thanks man..!! :)
mimransa
Thu Feb 13, 2014 7:40 am
This is my Mikrotik Router Board Configuration and I am still unable to access the user manager page via web browser via the 192.168.0.1/userman and also unable to do IP Binding to bypass the login page.
Can you please guide me where my settings go wrong. I will be highly thankful to you.
Interface List.jpg (106.09 KiB) Viewed 15248 times
Radius Authentication.jpg (117.13 KiB) Viewed 15248 times
Package List.jpg (119.42 KiB) Viewed 15248 times
mimransa
Thu Feb 13, 2014 7:43 am
Remaining attached files
IP Routes.jpg (115.31 KiB) Viewed 15248 times
IP Hotspot Server Profiles.jpg (96.98 KiB) Viewed 15248 times
Users browsing this forum: No registered users and 3 guests
