iqt
User Manager Limitations
Tue Oct 07, 2014 3:02 pm
I try to give timed access to the internet via Hotspot/User Manager. Setup with MAC login and an empty profile is working.
Problems arise with the limitations. (The Wiki does not document this feature :( )
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name="" ip-pool=LAN name=LocalNet owner=\
    admin transfer-limit=0B upload-limit=0B uptime-limit=0s
/tool user-manager profile profile-limitation
add from-time=20h limitation=LocalNet profile=Local_R till-time=23h59m59s weekdays=\
    sunday,monday,tuesday,wednesday,thursday,friday,saturday
Profile Local_R (with restriction to LAN access only from 20:00 to midnight) is then attached to the user.
And now the following happens (out of the log entries):
Login before 20:00: access denied at this time --> but I didn't set any limitations before 20:00
Login after 20:00 is working (as expected) but at midnight User Manager is sending a Disconnect-Request 6 and removes the profile from the user.
Could anybody please explain how to use the Profile Limitations functionality - incl. periods - correctly and update the Wiki.
Thanks Dirk
bluemoon
Re: User Manager Limitations
Sat Mar 07, 2015 12:39 am
You will be lucky if you get a solution here :)
I have almost the same issue. My time based limitation not working at all. I set my time limitation from 21:00 to 6:59:59 but I am unable to login during this time and I am getting access denied error and no one knows the solution.
indnti
Wed Jun 10, 2015 1:03 pm
Hi
[quote="iqt"]
Login after 20:00 is working (as expected) but at midnight User Manager is sending a [b]Disconnect-Request 6[/b] and [u]removes[/u] the profile from the user.
[/quote]
Same problem here - after the limitation time is reached, the profile is removed but shown as active.
We try to limit access and uptime from 16:00 till 22:00 but sometimes the profile is lost, sometimes not. By now we can't find a reason or any regularity.
See the screenshots.
[attachment=0]um1.png[/attachment]
[attachment=1]um2.png[/attachment]
Users browsing this forum: No registered users and 12 guests
