molham777
User Manager with two MT Router boards
Wed Feb 18, 2015 10:29 pm
Hello Guys
could I use two router boards and every one have its hotspot but i need to run the same username and password in the two routers
I mean i need to connect two router board to the same radius server ( user manager ) how can i do that
many thanks
hossain2004a
Re: User Manager with two MT Router boards
Thu Feb 19, 2015 8:41 am
Obviously you can, check this picture, in your UM router page you can add 2 MT. easy
and in radius section of your 2nd router you should enter the 1st mikrotik ip and shared password so the 1st router would be your database and 2nd one will only read from it.
molham777
Wed Mar 11, 2015 1:40 am
many Thanks for your answer
but my problem didn't solve till now and it is as the photo below
so what the need configuration to do that
hossain2004a
Thu Mar 12, 2015 7:33 am
In your 2nd RB:
In radius page:
enter the IP of your 1st RB (which has UM) and the secret code
- The IPs of two RBs should be different (it's obvious!)
In your 1st RB --> in UM --> Routers:
add your second RB and it's secret codes
I don't think there is no other specific config and option. this should work.
molham777
Sat Mar 14, 2015 4:46 am
Great Many thanks My friend it is solved :D
rakista257
Sat Sep 24, 2016 7:04 am
It didn't work , this is my config
1st router
radius 10.10.0.1 secret=1234
User-man
Routers:
10.0.5.1 secret=1234
2nd router
radius 10.0.5.1 secret=1234
User-man
Routers:
