Hello
I want the Mikrotik router to act as a VPN-server (PPTP) for a VPN-Client (a PC). The configuration is:
[PC]----Internet----[DSL-Router]----LAN----[Mikrotik-Router]
That's what I've done so far:
1) I configured Mikrotik to accept incoming PPTP connections.
2) I tested the VPN from inside the LAN and everything works (the VPN is successfully established).
3) I configured the DSL-Router to forward PPTP-Packets to the Mikrotik Router.
Now when i try to access the VPN via the internet (via the public IP-address of the DSL-Router), my packet monitor inside the LAN shows, that the first pptp-packet (SYN) is correctly forwarded to the Mikrotik Router. But it also shows that Mikrotik is not responding to this SYN-Packet.
I thought that the mikrotik-firewall may block packets and opened it for all packets. Still it doesn't answer to the incoming syn-packet.
How do i have to configure the mikrotik router to let it respond correctly to a VPN-Client outside the LAN?
Any help would be appreciated.
Thomas
