sanjeev
Disable Filter rules at one shot from Terminal
Sun Oct 12, 2008 9:27 am
hi all
i have firewall filter rules from 1 to 100 and i want to disable the rules and enable the rules during testing phase
this method doesn't works
[admin@MikroTik] ip firewall filter> disable 0-120
invalid item number
[admin@MikroTik] ip firewall filter> disable (0-120)
item number too large
this method works but disables 0 and 120 rules only not from 1 to 120
[admin@MikroTik] ip firewall filter> disable 0,120
however this works but its tedious you have to specify 0 to 100 using commas
[admin@MikroTik] ip firewall filter> disable 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,
15,16,17,18,19,21,22,23,24,25,26.....99,100
so my question here is what's the syntax to disable rule from 1 to 100 at one shot
Thankyou
omega-00
Re: Disable Filter rules at one shot from Terminal
Sun Oct 12, 2008 3:38 pm
:for x from 1 to 100 do={/ip firewall filter set $x disabled=yes}
That should help you ;-)
sanjeev
Tue Oct 14, 2008 11:42 am
Thanks..
that really helped me..
but i think that was a programming syantax
not a command
thanks any way
omega-00
Tue Oct 14, 2008 12:15 pm
that is a command you can paste directly into a terminal window (tested on 3.14)
d2285
Mon Dec 12, 2016 2:49 pm
How to remove with it?
JB172
Mon Dec 12, 2016 5:38 pm
:for x from 1 to 100 do={/ip firewall filter remove $x}
total13
Tue Dec 20, 2016 6:38 pm
Hello!
I am having issues with this command:
I sometimes get response:
no such item (4)
And sometimes it just deletes rules as it should. Any ideas why is this happening?
Rhobro
Thu Dec 22, 2016 10:21 am
The loop goes from Item 1 to Item 100.
If you deleted some of those items in between or you simply dont have 100, it throws a warning
total13
Tue Jan 24, 2017 6:28 pm
Hmm, sometimes it worked fine and sometimes not, although I admit it was bit "crude" tool, so I found better:
/ip firewall filter remove [/ip firewall filter find]
Users browsing this forum: No registered users and 93 guests
