hi guys
i want to make load balancing to :
3 in wan
1 oul lan
what is the best way to do that ??
thanx
/ ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=wlan1
add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=wlan2
/ ip firewall mangle
add chain=input in-interface=wlan1 action=mark-connection new-connection-mark=wlan1_conn
add chain=input in-interface=wlan2 action=mark-connection new-connection-mark=wlan2_conn
add chain=output connection-mark=wlan1_conn action=mark-routing new-routing-mark=to_wlan1
add chain=output connection-mark=wlan2_conn action=mark-routing new-routing-mark=to_wlan2
add chain=prerouting dst-address=10.111.0.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=10.112.0.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/0 \
action=mark-connection new-connection-mark=wlan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/1 \
action=mark-connection new-connection-mark=wlan2_conn passthrough=yes
add chain=prerouting connection-mark=wlan1_conn in-interface=Local action=mark-routing new-routing-mark=to_wlan1
add chain=prerouting connection-mark=wlan2_conn in-interface=Local action=mark-routing new-routing-mark=to_wlan2
/ ip route
add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_wlan1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 routing-mark=to_wlan2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.111.0.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=wlan1 action=masquerade
add chain=srcnat out-interface=wlan2 action=masquerade
/ ip address
add address=10.113.0.2/24 network=10.113.0.0 broadcast=10.113.0.244 interface=wlan3
add chain=input in-interface=wlan3 action=mark-connection new-connection-mark=wlan3_conn
add chain=output connection-mark=wlan3_conn action=mark-routing new-routing-mark=to_wlan3
add chain=prerouting dst-address=10.113.0.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:3/0 \
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:3/1 \
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:3/2 \
action=mark-connection new-connection-mark=wlan3_conn passthrough=yes
add chain=prerouting connection-mark=wlan3_conn in-interface=Local action=mark-routing new-routing-mark=to_wlan3
/ ip route
add dst-address=0.0.0.0/0 gateway=10.113.0.1 routing-mark=to_wlan3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.113.0.1 distance=3 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=wlan3 action=masquerade
