• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Multiple Hostspots/user profiles on one router  Page 1 of 1
 [ 6 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
bwa
 Post subject: Multiple Hostspots/user profiles on one router
PostPosted: Wed Jun 23, 2010 6:08 pm
Offline
I have set up multiple Hot Spot servers on my RB493 on multiple ethernet ports. I have also created multiple user profiles. The problem I have is how do I assign a specific user profile to a specific Hot Spot instance? Each user profile has different rate limit attributes. All logins are authenticated through a Free Radius server.
Top
 Profile
fewi
 Post subject: Re: Multiple Hostspots/user profiles on one router
PostPosted: Sat Aug 14, 2010 4:38 pm
Offline
Can you be more specific? What does 'assign a user profile to an instance' mean?
Top
 Profile
bwa
PostPosted: Sat Aug 14, 2010 4:45 pm
Offline
I have several Hot Spot Server instances running on a single MT and they all use the Default User Profile. I would like to assign a different User Profile to each Hot Spot Server Instance but I do not see a way to do this
Top
 Profile
fewi
PostPosted: Sat Aug 14, 2010 4:52 pm
Offline
It doesn't work that way. User profiles only apply to user accounts. User accounts in turn can be limited to certain Hotspot instances.
Hotspot instances take their parameters from Hotspot profiles (not Hotspot user profiles). Set those up as required and select them in the Hotspot instance.
Top
 Profile
bwa
PostPosted: Sat Aug 14, 2010 4:56 pm
Offline
My goal was to rate limit each user on a specific Hot Spot. I know I can apply a rate limit to the HS Server Profile, but is the rate limit per user or for the entire Hot Spot?
Appreciate the help
Top
 Profile
fewi
PostPosted: Sat Aug 14, 2010 5:10 pm
Offline
User profile rate limits are applied to specific users by installing a dynamic simple queue targeting that user's IP address. New dynamic queues are installed on log in and uninstalled on log out. They are installed at the top of the list of queues. At the bottom of the list sits a queue at is just tied to the interface, and any user that doesn't match a more specific queue by IP falls through to it. That interface queue takes the parameters from the rate limit on the server profile. It generally applies to users that are bypassed from login in IP bindings and users that are not authenticated yet.
Since you're using RADIUS you just use RADIUS attributes to rate limit users, though.
http://wiki.mikrotik.com/wiki/Manual:RADIUS_Client#Access-Accept
You can either make user profiles and use the Mikrotik-Group attribute to log users into them, or you can just bypass all that and use the Mikrotik-Rate-Limit attribute to directly tell the router what rate limit to apply to that user's IP address.
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 6 posts ]
Board index » RouterOS » Beginner Basics
Users browsing this forum: Bing [Bot] and 6 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
