• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
RB450G initial setup and config  Page 1 of 1
 [ 2 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
rookieb
 Post subject: RB450G initial setup and config
PostPosted: Wed Apr 06, 2011 5:48 pm
Offline
Just got a Mikrotik Routerboard 450G with RouterOS 5 license and don't know where to start. It looks like I will need to use the serial port for the initial configuration. Here is what I am trying to achieve:
1. Connect the Routerboard to the DSL router.
-DSL Router LAN - 192.168.1.254 255.255.255.0
-RB eth1 - 192.168.1.1 ?
2. Clients connected to the Routerboard should not be able to see clients connected to the DSL router and vice versa - Routerboard clients on different subnet, vlan, dhcp .
3. Set up dhcp server on routerboard eth5 for routerboard clients - 10.10.10.100 - 150. Clients connected to the routerboard should NOT be able to get ip addresses from the DSL router.
4. DSL router clients and Routerboard clients share the same internet connection from the DSL router.
5. Bandwidth management - routerboard clients must share evenly the available bandwidth (no bandwidth hogging)
Can you help?
Thanks!
Top
 Profile
ciphercore
 Post subject: Re: RB450G initial setup and config
PostPosted: Wed Apr 06, 2011 9:15 pm
Offline
You can config it via serial or Winbox. Winbox is a GUI front end that is supported on Windows (works under wine in OSX and Linux)
I would suggest using winbox.
Here is a good video to get started
http://gregsowell.com/?p=957
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 2 posts ]
Board index » RouterOS » Beginner Basics
Users browsing this forum: Bing [Bot] and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
