gread
RB433AH
Wed Dec 14, 2011 12:58 am
Hello everybody, i connect to RB433AH using Winbox, then i get a message "Router has been Disconnected".
Some idea of what it is the problem?
I try to ping RB (192.168.88.1) and can not reach it either.
Thanks in advanced!
dasiu
Re: RB433AH
Wed Dec 14, 2011 1:29 am
http://www.youtube.com/watch?v=p85xwZ_OLX0
(have you tried turning it off and on again?) :)
And have you tried to delete Winbox files (from Application data)? - maybe the plugin is invalid...
Do other services (telnet/ssh/webfig) work normally?
edit: wait, just let's go back to the basics :)
You have just connected the RouterBoard to your PC (or network), right? And WinBox shows it on a list - and you try to connect with MAC address? Maybe communication using MAC is failing - and you need to try to connect with IP.
If it's the case - just try to set a 192.168.88.2/24 address on your computer - and then connect with the RB using the IP.
Or it can be the case, when WinBox shows the routerboard, but without any IP - maybe it had a reset with "no-defaults", and it doesn't have 192.168.88.1 address at all? :)
Did this post help you somehow? Don't forget to give karma :)
gread
Re: RB433AH
Wed Dec 14, 2011 1:36 am
Dasiu, thanks for your recommendatios. I'll try it.
Regards.
dasiu
Re: RB433AH
Wed Dec 14, 2011 1:41 am
Ych, you're too quick, I didn't manage to edit my post in time :). So - at first try that "edit" part - and figure out, why you can't ping 192.168.88.1 (did You manually set a 192.168.88.x address on your computer?)
gread
Re: RB433AH
Wed Dec 14, 2011 2:11 am
1-You have just connected the RouterBoard to your PC (or network), right? Yes.
2-WinBox shows it on a list - and you try to connect with MAC address? Maybe communication using MAC is failing - and you need to try to connect with IP.... Yes, i log-in and 5 seconds later says "router has been disconnected" :(
3- just try to set a 192.168.88.2/24 address on your computer - and then connect with the RB using the IP.. Yes, this is the way i;ve tried :(
4-when WinBox shows the routerboard, but without any IP - maybe it had a reset with "no-defaults", and it doesn't have 192.168.88.1 address at all? How can i fix it?
Thanks.
dasiu
Re: RB433AH
Wed Dec 14, 2011 2:24 am
Do you have a console cable and a serial port or usb->serial adapter? I would try to "look inside" the RouterBoard by console port. And then use "/system reset-configuration" and it should have 192.168.88.1 on ether1 :). (I forgot - of course you are connecting to ether1 on the routerboard? :) )
Or you can use the reset hole, if you don't have the possibility to use serial connection. http://wiki.mikrotik.com/wiki/Manual:Password_reset = it clears the config :).
mahnet
Long time Member
Long time Member
Re: RB433AH
Wed Dec 14, 2011 5:28 am
this problem we r facing with the new ROS 5.5 LOADED products. the IP goes to 0.0.0.0 ad then we have to re-login with MAC address and add another IP
gread
Re: RB433AH
Wed Dec 14, 2011 11:16 pm
Hi, i could log-in, but i thing there's a problem with the internal battery, because when i configure the RB and turn it off, date, hour etc. change to default parameters.
Thanks for your help.
Regards,
Guillermo
ditonet
Forum Veteran
Forum Veteran
Re: RB433AH
Wed Dec 14, 2011 11:40 pm
RB433AH don't have internal battery.
Set clock and SNTP client:
http://wiki.mikrotik.com/wiki/Manual:System/Time
HTH,
Grzegorz | MTCNA, MTCRE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
gread
Re: RB433AH
Fri Dec 16, 2011 1:13 am
Hello, my RB433AH (v3.10) loses the configuration when i turn it off.
Some idea of the possible solution? Maybe any jumper?
Regards...
mahnet
Long time Member
Long time Member
Re: RB433AH
Fri Dec 16, 2011 6:25 am
upgrade the router OS. 3.10 is ancient now. i am not sure u can directly upgrade 3.10 to 5.x. upgrade to 4.11 and then to 5.x. ask support where u can find 4.11.
there r no batteries on the 433ah board so u cannot store setting or date time etc.
gread
Re: RB433AH
Fri Dec 16, 2011 4:02 pm
Mahnet, thanks.
Regards,
Guillermo
gread
Re: RB433AH
Fri Dec 16, 2011 11:30 pm
Hello folks, i've been upgrade to v5.11, but when it boots, loses the configuration and get the "default" one...
mahnet
Long time Member
Long time Member
Re: RB433AH
Sat Dec 17, 2011 5:34 am
what settings r u talking about.....which goes to default. the ssid, freq, etc don't change after reboot
gread
Re: RB433AH
Sun Dec 18, 2011 5:41 am
I configure all parameters and save it, but if i disconect the router and turn it on, date and all configuration return to default (1970 date)... thanks ...
mahnet
Long time Member
Long time Member
Re: RB433AH
Sun Dec 18, 2011 6:04 am
it happens with everyone :) so no worries. i have a separate server to manage date time n user accounts.
gread
Re: RB433AH
Sun Dec 18, 2011 6:20 am
...but all configuration is gone! wireless, SSID, etc ... :(
mahnet
Long time Member
Long time Member
Re: RB433AH
Sun Dec 18, 2011 6:22 am
no..wireless, SSID, etc remains. just date and time vanish.
contact mikrotik support or replace the board.
gread
Re: RB433AH
Sun Dec 18, 2011 7:10 am
Ok, thanks for your help...
Regards.
Users browsing this forum: Baidu [Spider], baragoon, Bing [Bot], nuttervm and 19 guests
