jt2048
Simple OSPF problem
Thu Feb 16, 2012 11:53 pm
I'm trying to get an RB750 to join and existing (Fortigate) OSPF area. Routing is very simple in this area, all area 0, network 192.168.0.0/16 . I can see broadcasts being sent by both ends but can't form an adjacency (no neighbor on the RB750).
Config as follows;
[admin@MikroTik] /routing ospf network> print
# NETWORK AREA
0 192.168.0.0/16 backbone
[admin@MikroTik] /routing ospf interface> print
Flags: X - disabled, I - inactive, D - dynamic, P - passive
# INTERFACE COST PRI NETWORK-TYPE AUT... AUTHENTICATIO...
0 ether1-gateway 10 1 broadcast none
1 ether2-master-local 10 1 broadcast none
[admin@MikroTik] /routing ospf instance> print
Flags: X - disabled
0 ;;; foo
name="default" router-id=192.168.88.1 distribute-default=never
redistribute-connected=as-type-1 redistribute-static=as-type-1
redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no
metric-default=1 metric-connected=20 metric-static=20 metric-rip=20
metric-bgp=auto metric-other-ospf=auto in-filter=ospf-in
out-filter=ospf-out
No neighbors
[admin@MikroTik] /routing ospf neighbor> print
Packet sniff from Fortigate end;
Fortigate-DE $ diagnose sniffer packet internal 'proto 89'
interfaces=[internal]
filters=[proto 89]
5.319350 192.168.250.1 -> 224.0.0.5: ip-proto-89 44
8.319288 192.168.51.1 -> 224.0.0.5: ip-proto-89 44
9.854719 192.168.51.116 -> 224.0.0.5: ip-proto-89 44
14.319342 192.168.250.1 -> 224.0.0.5: ip-proto-89 44
(RB750 broadcast in red)
I'm clearly missing something but what?
TIA ... JT
jt2048
Re: Simple OSPF problem
Sat Feb 18, 2012 1:59 am
And the answer is... :shock: User idiocy....
Somehow the instance-id was confused on the interface facing the rest of the system. I happened to disable ether1-gateway interface in OSPF and noticed that the new, dynamic interface was working (OSPF broadcast packets were the correct size for a system with an adjacency). I have no idea where that instance-id of 52 came from, I don't even know how to set one....
[admin@MikroTik] > /routing ospf interface print detail
0 X interface=ether1-gateway cost=10 priority=1 authentication=none
authentication-key="" authentication-key-id=1 network-type=broadcast
instance-id=52 retransmit-interval=5s transmit-delay=1s hello-interval=10s
dead-interval=40s use-bfd=no
1 interface=ether2-master-local cost=10 priority=1 authentication=none
instance-id=0 retransmit-interval=5s transmit-delay=1s hello-interval=10s
2 interface=Network 52 cost=10 priority=1 authentication=none
3 D interface=ether1-gateway cost=10 priority=1 authentication=none
(after deleting bogus instance)
0 interface=ether2-master-local cost=10 priority=1 authentication=none
1 interface=Network 52 cost=10 priority=1 authentication=none
2 D interface=ether1-gateway cost=10 priority=1 authentication=none
[admin@MikroTik] >
So, get everyone in the same instance and it works fine. Since I do have a network 52 I must have somehow fat fingered the instance ID, still not sure how. So, can I give myself karma now ? :lol:
Users browsing this forum: janus20 and 11 guests
