• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Transparent Bridge with NAT?  Page 1 of 1
 [ 4 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
nicfallenangel
 Post subject: Transparent Bridge with NAT?
PostPosted: Tue Feb 21, 2012 8:12 pm
Offline
So this falls into the category of "Can it be done?"
We are setting up a mikrotik to handle QoS and have several devices that act as wireless bridges with internal IP addresses for the sake of argument they run on 192.168.1.x/24
The mikrotik is set up as a transparent bridge to allow client devices to get IP addresses from an external DHCP server and avoid double NAT.
Brief rundown: ether1 is the "master" port and QoS is set on the others (using Mangle and Queue trees) with all five ports bridged together. I know I can set a DHCP client on the bridge/ether1 interface and can get the information about that IP through ARP/other means. Is there a way that I can get remote access to the 192 IPs while still maintaining the transparent bridge?
Setup is as follows:
Modem ---- Mikrotik ---- wireless bridge AP(192.168.1.x/24) ---- Wireless bridge client(192.168.1.x/24) ---- CPE that gets external DHCP/internet access (69.x.x.x as an example)
Top
 Profile
dasiu
 Post subject: Re: Transparent Bridge with NAT?
PostPosted: Tue Feb 21, 2012 11:59 pm
Offline
yes :)
_________________
Did this post help you somehow? Don't forget to give karma :)
Top
 Profile
nicfallenangel
PostPosted: Wed Feb 22, 2012 12:12 am
Offline
dasiu wrote:
yes :)
Thanks for the reply. How?
Top
 Profile
nicfallenangel
PostPosted: Sat Feb 25, 2012 12:42 am
Offline
I managed to work it out. Our setup uses separate vlans to run the management and data connections. I set the data on the bridge of course, then with a proper IP on the bridge, I used a dst-nat to get from the management IP to the IPs on the data bridge. In case anyone wants to know, here's the code I used:
Add the VLANs:
Code:
/interface vlan
add arp=enabled disabled=no interface=ether1 l2mtu=1596 mtu=1500 name=vlan1 \
    use-service-tag=no vlan-id=1
add arp=enabled disabled=no interface=ether1 l2mtu=1596 mtu=1500 name=vlan2 \
    use-service-tag=no vlan-id=2
Create the bridge and add the data vlan and other ports to it:
Code:
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    disabled=no forward-delay=15s l2mtu=1598 max-message-age=20s mtu=1500 \
    name=bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none \
    interface=vlan2 path-cost=10 point-to-point=auto priority=0x80
    interface=ether2 path-cost=10 point-to-point=auto priority=0x80
    interface=ether3 path-cost=10 point-to-point=auto priority=0x80
    interface=ether4 path-cost=10 point-to-point=auto priority=0x80
    interface=ether5 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=no \
    use-ip-firewall-for-vlan=yes
Set IP addresses (x.x.x.x for public and y.y.y.y for local):
Code:
add address=x.x.x.x/x disabled=no interface=vlan1 network=x.x.x.0
add address=y.y.y.y/y disabled=no interface=bridge1 network=y.y.y.0
Add NAT action to move connection from public Management port to private bridge interface:
Code:
add action=dst-nat chain=dstnat disabled=no dst-address=x.x.x.x \
    dst-port=8081 in-interface=vlan1 protocol=tcp to-addresses=y.y.y.y \
    to-ports=80
Add gateway for public address so it properly routes:
Code:
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=x.x.x.x scope=\
    30 target-scope=10
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 4 posts ]
Board index » RouterOS » Beginner Basics
Users browsing this forum: No registered users and 15 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
