I have on my mikrotik create a pptp server like describe on http://wiki.mikrotik.com/wiki/Manual:Interface/PPTP I can connect with the vpn client. Also I can ping the mikrotik router. But I can’t ping any host on the local network. I have enabled proxy-arp on the local interface as described in the manual.
Has anyone any idea what I’m donning wrong. I'm using version 5.21 on RB450G
Code: Select all
[admin@MikroTik] /ppp secret> print detail
Flags: X - disabled
0 name="user1" service=any caller-id="" password="test" profile=VPN-profile
routes="" limit-bytes-in=0 limit-bytes-out=0
[admin@MikroTik] /ppp profile> print
Flags: * - default
0 * name="default" remote-ipv6-prefix-pool=none use-ipv6=yes use-mpls=default
use-compression=default use-vj-compression=default use-encryption=default
only-one=default change-tcp-mss=yes
1 name="VPN-profile" local-address=172.26.12.117 remote-address=VPN-pool
remote-ipv6-prefix-pool=(unknown) use-ipv6=yes use-mpls=default
use-compression=default use-vj-compression=default use-encryption=yes
only-one=default change-tcp-mss=yes dns-server=172.26.12.29,172.26.12.92
2 * name="default-encryption" remote-ipv6-prefix-pool=none use-ipv6=yes
use-mpls=default use-compression=default use-vj-compression=default
use-encryption=yes only-one=default change-tcp-mss=yes
[admin@MikroTik] /ip pool> print
# NAME RANGES
0 default-dhcp 192.168.88.10-192.168.88.254
1 VPN-pool 172.26.12.200-172.26.12.250
[admin@MikroTik] /interface pptp-server server> print
enabled: yes
max-mtu: 1460
max-mru: 1460
mrru: disabled
authentication: mschap1,mschap2
keepalive-timeout: 30
default-profile: default-encryption
[admin@MikroTik] /interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1-g... 1500 00:0C:42:BD:8E:01 enabled none switch1
1 R ether2-l... 1500 00:0C:42:BD:8E:02 proxy-arp none switch1
2 ether3-l... 1500 00:0C:42:BD:8E:03 enabled none switch1
3 ether4-l... 1500 00:0C:42:BD:8E:04 enabled none switch1
4 ether5-l... 1500 00:0C:42:BD:8E:05 enabled none switch1
