edmond
RB 951G-2HnD wlan1 switch off problem
Sat Mar 16, 2013 10:38 pm
Hello.
I want to schedule WIFI access on my router. I found help at viewtopic.php?f=7&t=32721 and made all the steps. Scripts work and schedule also works.
But I found out later: when I switch OFF wlan1 I can't get access to ethernet ports. Suddenly all ethernet ports are frozen and I must reset it to default. Of course, I tried to delete scripts, schedule and reset to defaults. Everything works fine till I disable wlan1. Disabling wlan1 directly from /wireless/ setting also freeze ethernet ports on router.
Routerboard type is RB 951G-2HnD (firmware 3.04) and software version is 5.24.
Thank you.
ohara
Odp: RB 951G-2HnD wlan1 switch off problem
Sat Mar 16, 2013 10:46 pm
Go to IP>Addresses, then change the interface from 'wlan1' into 'bridge-local'.
edmond
Re: Odp: RB 951G-2HnD wlan1 switch off problem
Sat Mar 16, 2013 10:54 pm
Solved ! I was thinking about it two days.... :shock:
Thank you very very much and have a great weekend
ohara
Sat Mar 16, 2013 10:56 pm
np. same to you
Users browsing this forum: pe1chl, plisken and 6 guests
