This config has to work. It hasn't the loadbalancing-mode, but has the Failover-mode.
You have to change "x" in 10.x.5.1 and 10.x.7.254.
Uncheck box "Add default route" in both ISP-connections, if it's using now.
Also change AAA.AAA.AAA.AAA to ip-address of Gateway ISP1 (only IP! not interface-name etc.)
And BBB.BBB.BBB.BBB to ip-address of Gateway ISP2 (only IP! not interface-name etc.)
Other ip addresses used here for ping-checking internet. It's public DNS servers.
/ip firewall address-list
add list=static-wan2 address=10.x.5.1-10.x.7.254 comment="IP to WAN2"
/ip firewall mangle
add action=mark-routing chain=prerouting comment="Mark STATIC route to WAN2" dst-address-type=!local new-routing-mark=to-wan2 src-address-list=static-wan2
add comment="STATIC Route-1 to WAN2" distance=1 gateway=192.168.100.2 routing-mark=to-wan2
add comment="STATIC Route-2 to WAN2" distance=2 gateway=192.168.100.1 routing-mark=to-wan2
add comment="Default Route to WAN1" distance=1 gateway=192.168.100.1
add comment="Default Route to WAN2" distance=2 gateway=192.168.100.2
add check-gateway=ping comment="Virtual host for ISP1-host1" distance=1 dst-address=192.168.100.1/32 gateway=151.197.0.38 scope=10
add check-gateway=ping comment="Virtual host for ISP1-host2" distance=2 dst-address=192.168.100.1/32 gateway=4.2.2.1 scope=10
add check-gateway=ping comment="Virtual host for ISP2-host1" distance=1 dst-address=192.168.100.2/32 gateway=151.197.0.39 scope=10
add check-gateway=ping comment="Virtual host for ISP2-host2" distance=2 dst-address=192.168.100.2/32 gateway=4.2.2.2 scope=10
add comment="Static PING way by ISP1-host1" distance=1 dst-address=151.197.0.38/32 gateway=AAA.AAA.AAA.AAA scope=10
add comment="Static PING way by ISP1-host2" distance=1 dst-address=4.2.2.1/32 gateway=AAA.AAA.AAA.AAA scope=10
add comment="Static PING way by ISP2-host1" distance=1 dst-address=151.197.0.39/32 gateway=BBB.BBB.BBB.BBB scope=10
add comment="Static PING way by ISP2-host2" distance=1 dst-address=4.2.2.2/32 gateway=BBB.BBB.BBB.BBB scope=10
add comment="HELP for reverse GW1(1)" distance=20 dst-address=151.197.0.38/32 type=blackhole
add comment="HELP for reverse GW1(2)" distance=20 dst-address=4.2.2.1/32 type=blackhole
add comment="HELP for reverse GW2(1)" distance=20 dst-address=151.197.0.39/32 type=blackhole
add comment="HELP for reverse GW2(2)" distance=20 dst-address=4.2.2.2/32 type=blackhole
