DiogoT
OSPF networks
Wed Feb 22, 2017 1:16 pm
why are the networks we add in OSPF shared to other routers?
configuration of the following instance:
/routing ospf instance> print
name="default"
router-id=10.255.255.2
distribute-default=never
redistribute-connected=no
redistribute-static=no
redistribute-rip=no
redistribute-bgp=no
redistribute-other-ospf=no
metric-default=1
metric-connected=20
metric-static=20
metric-rip=20
metric-bgp=auto
metric-other-ospf=auto
in-filter=ospf-in
out-filter=ospf-out
dgnevans
Re: OSPF networks
Wed Feb 22, 2017 3:05 pm
What is listed under OSPF Networks ?
DiogoT
Re: OSPF networks
Wed Feb 22, 2017 3:27 pm
[admin@R1] /routing ospf network> print
 #   NETWORK            AREA
 0   192.168.150.248/29 area1
 1   192.168.100.128/25 area1
[admin@R2] /routing ospf network> print
 #   NETWORK            AREA
 1   192.168.250.248/29 backbone
[admin@R1] /routing ospf route> print
 # DST-ADDRESS        STATE          COST          GATEWAY         INTERFACE
 0 192.168.100.128/25 intra-area     10            0.0.0.0         b-vlan100
 1 192.168.150.248/29 intra-area     10            0.0.0.0         b-vlan150
 2 192.168.250.248/29 inter-area     20            192.168.150.252 b-vlan150
[admin@R2] /routing ospf route> print
 0 192.168.100.128/25 intra-area     20            192.168.150.250 b-vlan150
 2 192.168.250.248/29 intra-area     10            0.0.0.0         b-vlan250
Why network 192.168.250.248/29 appear on the router1?
Why network 192.168.100.128/25 appear on the router2?
StubArea51
Trainer
Trainer
Re: OSPF networks
Wed Feb 22, 2017 4:24 pm
The purpose of OSPF is to exchange routes between routers, so OSPF is doing exactly what it was designed to do. :-)
R1 is learning 192.168.250.248/29 from R2 via OSPF
R2 is learning 192.168.100.128/25 from R1 via OSPF
Is this not what you wanted to happen?
DiogoT
Re: OSPF networks
Wed Feb 22, 2017 4:28 pm
So what are these settings for? Since they are in "no" were not supposed to not share?
StubArea51
Trainer
Trainer
Re: OSPF networks
Wed Feb 22, 2017 4:35 pm
 #   NETWORK            AREA
 #   NETWORK            AREA
When the subnet is added to 'ospf network' it will advertise the prefix
DiogoT
Re: OSPF networks
Wed Feb 22, 2017 4:46 pm
 #   NETWORK            AREA
 #   NETWORK            AREA
Ok, thanks!
dgnevans
Re: OSPF networks
Wed Feb 22, 2017 4:58 pm
If you would like 192.168.250.248/29 not to appear on router 1 you need move this network on router to into it's own area so that it is not passed as a backbone area would be.
If you would like 192.168.100.128/25 not to appear on router 2 you should not put it in area1 as you defined area 1 on both routers.
What routes are you wanting to be passed between the two routers?
DiogoT
Re: OSPF networks
Wed Feb 22, 2017 5:08 pm
Thank you.
I've already tested what you said, and it worked. Thanks.
This doubt arose, since before they were allowed to share routes, they were already shared. However, it has already been explained that when I add a subnet to "OSPF networks" this will share its prefix.
dgnevans
Re: OSPF networks
Wed Feb 22, 2017 6:48 pm
good news.
Users browsing this forum: No registered users and 31 guests
