jjmuw
BGP routing filter syntax
Fri Dec 18, 2009 12:14 am
I'm fairly new to BGP and I want to make sure that these sorts of filters are what I'm looking for. Here's my scenario. I have a router with a lot of internal addresses and other sorts of routes that I don't want advertised upstream. On my peer configuration I have redistribute-static=no, redistribute-connected=no and all other redistribute options set to no. Currently, I have some "test" routers upstream that do receive my blocks correctly. I accomplished this by using network statements and configuring a routing filter as follows:
0 chain=ISP1 prefix=X.X.X.0/21 prefix-length=21-32 invert-match=no action=accept set-bgp-prepend=5
1 chain=ISP1 prefix=Y.Y.Y.0/21 prefix-length=21-32 invert-match=no action=accept set-bgp-prepend=5
2 chain=ISP1 invert-match=no action=discard
3 chain=ISP2 prefix=X.X.X.0/21 prefix-length=21-32 invert-match=no action=accept
4 chain=ISP2 prefix=Y.Y.Y.0/21 prefix-length=21-32 invert-match=no action=accept
5 chain=ISP2 invert-match=no action=discard
We have two upstream providers, and I want our path to "ISP1" to be seen as not preferred, and have ISP2 be the more attractive route to routers upstream. Am I correct in that these filters will suitably prevent any routes from being advertised by my router that do not fall under my x.x.x.0/21 and y.y.y.0/21 blocks, and that "ISP1" will have our AS number prepended 5 times to the AS path list?
Also, is the correct way to apply a BGP filter or am I taking the wrong approach?
Thank you in advance for any assistance.
changeip
Re: BGP routing filter syntax
Fri Dec 18, 2009 12:27 am
that looks right. be aware that prefixes within the /21 might get annouced with the 21-32 prefix length. other than that, it looks good.
changeip
with redistribute no on all those you should only get the networks specifically in the networks list annouced.
jjmuw
Fri Dec 18, 2009 12:44 am
Great, thanks!
