• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
HWMP+ Questions  Page 1 of 1
 [ 2 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
rojwilco
 Post subject: HWMP+ Questions
PostPosted: Tue Apr 06, 2010 6:34 pm
Offline
I've been reading about HWMP+ on the wiki and have been playing with it using a couple of RouterBOARD 750s on a bench with ethernet cables and switches. It works pretty well in-lab, and I'm planning on using it for a deployment where these nodes will connect to other layer-2 bridges which control their own wireless setup. I don't doubt there will be numerous challenges to overcome, so I am reading up as much on it as I can to try to plan for any hitches.
On the wiki (http://wiki.mikrotik.com/wiki/Manual:Interface/HWMPplus), there are a few "problem" setups mentioned which I am trying to avoid. In the first one (where not all routers are in the mesh), there is mentioned an idea of a "designated ethernet router" for the network. What is this? Is this another way of saying the portal node for the proactive-mode HWMP+? Or is this referring to another configuration either in the switch or the mesh?
Second, is there any other documentation on how HWMP+ works? The wiki mentions a little about how it sends packets (tunneling?), but I would like to know as much as possible about the protocol, from how the routing algorithms work to how it actually sends data from one end of the mesh to the other. Is this information available anywhere?
Thanks in advance!
Top
 Profile
el berto
 Post subject: Re: HWMP+ Questions
PostPosted: Wed Jun 01, 2011 5:37 pm
Offline
I'm not sure: in the example above
Quote:
from Wiki - Also note that there will be no problem, if either:
- router A supports and is configured to use HWMP+;
- or Ethernet switch is replaced with and router that supports HWMP+ and has Ethernet interfaces added as mesh ports.
Does this mean it will works correctly:
- if I use Router A (such as RB450) where I have ethernet ports added as ports in "mesh1" and I use a simple ethernet switch
or
- if I use a simple router and I use a RB450 as switch (instead a simple switch) with ethernet ports added to mesh
Which one correct?
I mean, if I have to connect Routers A, B and "a client" through cable, what have I to place, a router with ethernet ports as mesh ports or anything else?
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 2 posts ]
Board index » RouterOS » Forwarding Protocols
Users browsing this forum: c0d3rSh3ll and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
