I try to configure a Port 80 and Port 443 port forwarding to an external proxy.
For Port 80 it works, I configured:
1 chain=dstnat action=dst-nat to-addresses=95.172.68.147 to-ports=9400
protocol=tcp dst-port=80
For Port 443 it does not work, I configured
0 chain=dstnat action=dst-nat to-addresses=95.172.68.147 to-ports=9400
protocol=tcp dst-port=443
www and www-ssl IP services are both disabled on the router
Using Firefox manual proxy configuration behind the router everything works fine also for ssl on port 9400.
Unfortunately I have no idea what´s wrong with the configuration.
Thanks in advance
Can anyone help me?
