I can't make OSPF MD5 encryption work between a RB450G running OS 4.16 to a 2851 Cisco router, but a RB1100 right next to it running OS v.5.0rc7 works just fine.
The two router boards will not talk to each other on OSPF. Is there a bug on OS 4.16 running MD5?
The OSv4.16 board gets an error message
"discarding packet wrong authentication"
mine=null authentication
message=cryptographic authentication
Source=xxx.xxx.xxx.10
and this is what I have on it.
/routing ospf interface
add authentication=md5 authentication-key=123456ospf authentication-key-id=3 comment="" cost=10 dead-interval=40s \
disabled=no hello-interval=10s instance-id=0 interface=ether1-gateway network-type=broadcast passive=no priority=1 \
retransmit-interval=5s transmit-delay=1s use-bfd=no
Router board with v5.0rc7 I have this error in the log
mine=cryptographic authentication
message=null authentication
source=xxx.xxx.xxx.11
add authentication=md5 authentication-key=123456ospf authentication-key-id=3 cost=10 dead-interval=\
40s disabled=no hello-interval=10s instance-id=0 interface=ether1-gateway network-type=broadcast \
passive=no priority=1 retransmit-interval=5s transmit-delay=1s use-bfd=no
as you can see they think that encryption is null on the OS v4.16 board, but it is not as you can see.
Anyone run across this??
Glenn Allen
