• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
LDP flapping after changing wireless BH link.  Page 1 of 1
 [ 5 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
Inssomniak
 Post subject: LDP flapping after changing wireless BH link.
PostPosted: Tue Jun 21, 2011 1:25 pm
Offline
We had a mikrotik to mikrotik backhaul link in operation for a few years, and it worked fine with LDP protocol between these two routers. We replaced the wireless link in between with a ubiquiti link instead (using an available ethernet port on each routerboard instead of the wifi cards), not changing any other configuration on the routers, but now the LDP neighbors keep flapping on and off between these two routers now, No changes in OSPF link states or anything. The funny thing is that on the other side of each of these routers identical ubiquiti configurations/links are working fine.
Mikrotik ->ubi->Mikrotik ->ubi -> Mikrotik -> ubi -> Mikrotik
The 2nd router will show just a "D" for its neighbor but the 3rd router it just disappears off the list.
Above example the LDP between the 2 middle mikrotiks the LDP is unstable. This is only one leg of our network, our other leg also has the exact configurations as well and works fine. The only real difference is one of the boards is an RB600 and its the only one we have in our network. If I set the LDP neighbor force targeted hello between the routers its also stable, it just doesnt work dynamically anymore?? Anyone have any ideas??? Been beating my head on the wall with this one for a week.
Top
 Profile
Mplsguy
 Post subject: Re: LDP flapping after changing wireless BH link.
PostPosted: Wed Jun 22, 2011 7:55 am
Offline
If LDP adjacency is maintained fine with targeted hellos, I would say that your link is having trouble forwarding multicast packets (LDP hellos). You can check that with sniffer.
Top
 Profile
Inssomniak
PostPosted: Wed Jun 22, 2011 1:59 pm
Offline
This was my first guess, OSPF doesnt work without NBMA turned on too. Ive examined the configuration of this link to our other identical links and found no differences so Im lost as to why it sometimes does pass multicast and other times it doesnt.
Top
 Profile
diegotormes
PostPosted: Sun Jul 10, 2011 12:22 am
Offline
try to set
hello-interval=3s hold-time=20s on ldp interfaces.
Top
 Profile
diegotormes
PostPosted: Sun Jul 10, 2011 12:27 am
Offline
would be helpful if ldp neighbors have adjacency time like ospf neighbors ... and state changes too.
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 5 posts ]
Board index » RouterOS » Forwarding Protocols
Users browsing this forum: Google [Bot] and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
