• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
bgp-local-pref not applied on IPv6 routes  Page 1 of 1
 [ 2 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
Jeeves
 Post subject: bgp-local-pref not applied on IPv6 routes
PostPosted: Mon Jul 11, 2011 12:04 pm
Offline
I was looking into the issue that my peering-routes aren't prefered over my transit-routes, and it seems that the set-bgp-local-pref action I defined on my peers_in-routing filter isn't applied.
Peer definition:
14 E name="XXX" instance=default remote-address=XXX remote-as=XXX tcp-md5-key="" nexthop-choice=default multihop=no route-reflect=no hold-time=3m ttl=255
max-prefix-limit=8000 in-filter=nlix_peers_in out-filter=nlix_peers_out address-families=ipv6 default-originate=never remove-private-as=no as-override=no passive=no use-bfd=no
In-filter definition:
45 chain=nlix_peers_in invert-match=no action=jump jump-target=bogons_v4
46 chain=nlix_peers_in invert-match=no action=jump jump-target=bogons_v6
47 chain=nlix_peers_in invert-match=no action=jump jump-target=local_pref_150
Local_pref_150 definition:
53 chain=local_pref_150 invert-match=no action=passthrough set-bgp-local-pref=150
The received route:
355 Db dst-address=2001:4830:1600::/40 gateway=XXX gateway-status=XXX reachable distance=20 scope=40 target-scope=10 bgp-as-path="XXX,30071"
bgp-origin=igp received-from=XXX
There is no bgp-local-pref in any of the IPv6 routes, but there are on the ipv4 ones. Is this a bug or am I doing something wrong?
Top
 Profile
Jeeves
 Post subject: Re: bgp-local-pref not applied on IPv6 routes
PostPosted: Mon Jul 11, 2011 12:24 pm
Offline
47 chain=nlix_peers_in address-family=ipv6 invert-match=no action=jump jump-target=local_pref_150
Hmm. It seems that you must add a new rule specific for ipv6 to make it work..
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 2 posts ]
Board index » RouterOS » Forwarding Protocols
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
