shadowskippie
OSPF network connecting to internet
Wed Aug 10, 2011 9:36 am
morning
I need some help with this problem
I want to build a network consisting of a ring of routers that use OSPF to interconnect them.
Now one of those routers hooks to the gateway router that connects to the net, how do i tell the OSPf network how to connect to the internet and still retain its redundancy (one the the routers goes down in the ring)
*current network is a line with 0.0.0.0/0 pointing each tower to the down the line until end, this needs to change*
blake
Re: OSPF network connecting to internet
Wed Aug 10, 2011 2:08 pm
On the router which connects to the internet:
/routing ospf instance
set default distribute-default=if-installed-as-type-1
It will broadcast a default route to the other OSPF routers as long as it also has a default route in its own routing table.
shadowskippie
Wed Aug 10, 2011 5:16 pm
and this would be a 0.0.0.0/0 point to say 192.168.100.1, and this would be sitting in the ip routes table, correct?
blake
Thu Aug 11, 2011 3:39 am
Correct.
shadowskippie
Thu Aug 11, 2011 8:21 am
thank you :)
Users browsing this forum: No registered users and 51 guests
