Hello All.
I just bougth a RB750GL, I the hope that I can change the trash ISP router.
The provider is a triple play conection with a FTTH setup.
The main setup is based in VLAN.
- Internet works fine. Goes thru PPPoE thru VLAN 6.
- IPTV, uses a fixed IP adresses thru 2 VLAN, 2 and 3. The mulicasts emitions comes from VLAN2.
I configured the IGMP-Proxy as
The main issue is that I can "jump start" the Multicast transmision connecting the ISP router, starting VLC, after a few seconds, I turn off the router, switch all the cables and start the mikrotik router, and everthing works!.
If I keep looking at the TV for a time, I don't have any problem.
If I stop the multicast transmission, and restart it, everthing still works...
But.....
If I switch off the router, and start it again, I can not restart the multicast transmission...
If I leave the system without use for a long time (not using TV), also I loss the multicast transmision
thanks for all the help!
