I am mikrotik RB411 user. Basically I fixed port problems, like for skype and utorrent, tests show that ports are open, also in action torrent client works great, I upload torrent and everybody can connect to me instantly.
Before I used fallowing config, to open ports
IP FIREWALL/NAT
1.1 /ip firewall nat add chain=dstnat dst-address=80.233.160.xxx(WAN IP) in-interface=wlan1 protocol=tcp dst-port=0-65000 \\
action=dst-nat to-addresses=192.168.88.5(LAN IP) to-ports=0-65000
1.2 /ip firewall nat add chain=dstnat dst-address=80.233.160.xxx in interface=wlan1 protocol=udp dst-port=0-65000 \\
NAT MANGLE
chain=forward dst-address=192.168.88.5(LAN IP) action=accept
chain=output dst-address=192.168.88.5(LAN IP) action=accept
Note: Gateway for LAN is 192.168.88.1
So now what I started to wounder about. IP/Firewall rules I left the way they are. I edited what is in NAT MANGLE:
/ip firewall mangle add chain=forward(or Input) in interface=wlan1 action=mark connection connection mark=1
/ip firewall mangle add chain=forward(or Input) out interface=ether1 action=mark connection connection mark=1
Also this way in port test show tha everything is ok, but poroblem couse when I try to run a gaming server, nobody can connect to me.
What should be correct config? I wanted to open ports in certain range like 0-65000, so whatever program is using some port, so I dont need to create a bunch of rules for all of them.
Also to create rule which would allow to pass traffic in the router and out of it.
Thanks for help
