Same diagram applies, and I have the following configuration running on the Core routers (which naming, cost and IP differences, but the configuration is identical otherwise): -
Code: Select all
/ip route vrf
add export-route-targets=65009:2 import-route-targets=65009:2 interfaces=r1-vlan,r2-vlan,r3-vlan,core-link-vrf,msr2 route-distinguisher=65009:2 routing-mark=ospf-test
/routing ospf instance
set [ find default=yes ] distribute-default=always-as-type-1
add distribute-default=always-as-type-1 name=private redistribute-static=as-type-1 routing-table=ospf-test
/routing ospf area
add instance=private name=backbone-priv
/routing ospf interface
add cost=1000 interface=r1-vlan
add cost=1000 interface=r2-vlan
add cost=1000 interface=r3-vlan
add cost=4 interface=core-link-vrf
add cost=1000 interface=msr2
/routing ospf network
add area=backbone-priv network=192.168.51.0/24
add area=backbone-priv network=192.168.52.0/24
add area=backbone-priv network=192.168.53.0/24
add area=backbone-priv network=192.168.200.0/24
add area=backbone-priv network=192.168.111.0/24
add distance=1 gateway=31.205.49.186@main routing-mark=ospf-test
add distance=1 dst-address=192.168.41.1/32 gateway=core-link-vrf routing-mark=ospf-test
/ip address print
13 192.168.51.1/24 192.168.51.0 r1-vlan
14 192.168.52.1/24 192.168.52.0 r2-vlan
15 192.168.53.1/24 192.168.53.0 r3-vlan
16 192.168.200.1/24 192.168.200.0 core-link-vrf
17 192.168.111.1/24 192.168.111.0 msr2
Code: Select all
/ip address print
7 192.168.51.2/24 192.168.51.0 core-vlan
8 192.168.151.1/24 192.168.151.0 core2-vlan
/ip route vrf
add export-route-targets=65009:2 import-route-targets=65009:2 interfaces=core-vlan,core2-vlan route-distinguisher=65009:2 routing-mark=ospf-test
add name=private routing-table=ospf-test
/routing ospf area
add cost=1000 interface=core-vlan
add interface=core2-vlan
add area=backbone-priv network=192.168.151.0/24
Now here is the routing table I get on each of the spoke routers: -
Code: Select all
/ip route print where routing-mark=ospf-test
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
1 ADC 192.168.51.0/24 192.168.51.2 core-vlan 0
2 ADo 192.168.52.0/24 192.168.51.1 110
3 ADo 192.168.53.0/24 192.168.51.1 110
4 ADo 192.168.111.0/24 192.168.51.1 110
5 ADo 192.168.121.0/24 192.168.51.1 110
6 ADC 192.168.151.0/24 192.168.151.1 core2-vlan 0
7 ADo 192.168.152.0/24 192.168.51.1 110
8 ADo 192.168.153.0/24 192.168.51.1 110
9 ADo 192.168.200.0/24 192.168.51.1 110
Code: Select all
[showlette@r1] /routing ospf instance> /routing ospf lsa print where area=external
AREA TYPE ID ORIGINATOR SEQUENCE-NUMBER AGE
external as-external 0.0.0.0 192.168.200.1 0x80000004 1008
external as-external 0.0.0.0 192.168.200.2 0x80000026 606
external as-external 192.168.41.1 192.168.200.1 0x80000023 1680
[showlette@r1] /routing ospf instance> /routing ospf lsa print detail where area=external
instance=private area=external type=as-external id=0.0.0.0 originator=192.168.200.1 sequence-number=0x80000004 age=1029 checksum=0x4C4F options="E|DN" body=
netmask=0.0.0.0
forwarding-address=0.0.0.0
metric=1
route-tag=0x0
type1
instance=private area=external type=as-external id=0.0.0.0 originator=192.168.200.2 sequence-number=0x80000026 age=627 checksum=0x276 options="E|DN" body=
netmask=0.0.0.0
metric=1
route-tag=0x0
type1
instance=private area=external type=as-external id=192.168.41.1 originator=192.168.200.1 sequence-number=0x80000023 age=1701 checksum=0x4C89 options="E|DN"
body=
netmask=255.255.255.255
metric=20
route-tag=0x0
type1
Code: Select all
10:55:34 route,ospf,debug Deleting an LSA
10:55:34 route,ospf,debug lsa=Router LSA id=192.168.200.2 originator=192.168.200.2 seqnum=0x8000003a
10:55:34 route,ospf,debug LSA Update received: Installing and flooding it
10:55:34 route,ospf,debug header=AS-External LSA id=0.0.0.0 originator=192.168.200.2 seqnum=0x80000026
10:55:34 route,ospf,debug Installing an LSA
10:55:34 route,ospf,debug lsa=AS-External LSA id=0.0.0.0 originator=192.168.200.2 seqnum=0x80000026
10:55:34 route,ospf,debug old=AS-External LSA id=0.0.0.0 originator=192.168.200.2 seqnum=0x80000026
Code: Select all
10:56:50 route,ospf,debug LSA Update received: Installing and flooding it
10:56:50 route,ospf,debug header=Router LSA id=192.168.200.2 originator=192.168.200.2 seqnum=0x8000003c
10:56:50 route,ospf,debug Installing an LSA
10:56:50 route,ospf,debug lsa=Router LSA id=192.168.200.2 originator=192.168.200.2 seqnum=0x8000003c
10:56:50 route,ospf,debug old=Router LSA id=192.168.200.2 originator=192.168.200.2 seqnum=0x8000003b
10:56:50 route,ospf,debug Flooding an LSA
10:56:50 route,ospf,debug area=backbone
10:56:50 route,ospf,debug Adding to neighbor's retransmit list
10:56:50 route,ospf,debug neighbor=192.168.200.1
10:56:50 route,ospf,debug number of retransmits=1
10:56:50 route,ospf,debug Deleting an LSA
10:56:50 route,ospf,debug lsa=Router LSA id=192.168.200.2 originator=192.168.200.2 seqnum=0x8000003b
10:56:50 route,ospf,debug header=AS-External LSA id=0.0.0.0 originator=192.168.200.2 seqnum=0x80000001
10:56:50 route,ospf,debug lsa=AS-External LSA id=0.0.0.0 originator=192.168.200.2 seqnum=0x80000001
10:56:50 route,ospf,debug number of retransmits=2
10:56:50 route,ospf,debug SEND: Link State Update 192.168.11.2 -> 224.0.0.5 on r1-eoip
10:56:50 route,ospf,debug,raw PACKET:
10:56:50 route,ospf,debug,raw 02 04 00 A0 C0 A8 97 01 00 00 00 00 05 4C 00 00
10:56:50 route,ospf,debug,raw 00 00 00 00 00 00 00 00 00 00 00 02 00 02 02 01
10:56:50 route,ospf,debug,raw C0 A8 C8 02 C0 A8 C8 02 80 00 00 3C 82 39 00 60
10:56:50 route,ospf,debug,raw 02 00 00 06 C0 A8 0B 05 C0 A8 0B 05 02 00 00 0A
10:56:50 route,ospf,debug,raw C0 A8 0C 05 C0 A8 0C 05 02 00 00 0A C0 A8 0D 05
10:56:50 route,ospf,debug,raw C0 A8 0D 05 02 00 00 0A C0 A8 78 02 C0 A8 78 01
10:56:50 route,ospf,debug,raw 02 00 00 0A C0 A8 64 01 C0 A8 64 02 02 00 00 04
10:56:50 route,ospf,debug,raw 0B 0B 0B 0B FF FF FF FF 03 00 00 0A 00 02 02 05
10:56:50 route,ospf,debug,raw 00 00 00 00 C0 A8 C8 02 80 00 00 01 D3 4A 00 24
10:56:50 route,ospf,debug,raw 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00
10:56:50 route,ospf,debug RECV: Link State Update <- 192.168.11.1 on r1-eoip (192.168.11.2)
10:56:50 route,ospf,debug,raw 45 C0 00 B4 52 22 00 00 01 59 BA 60 C0 A8 0B 01
10:56:50 route,ospf,debug,raw E0 00 00 05 02 04 00 A0 C0 A8 C8 01 00 00 00 00
10:56:50 route,ospf,debug,raw D4 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 02
10:56:50 route,ospf,debug,raw 00 02 02 01 C0 A8 C8 02 C0 A8 C8 02 80 00 00 3C
10:56:50 route,ospf,debug,raw 82 39 00 60 02 00 00 06 C0 A8 0B 05 C0 A8 0B 05
10:56:50 route,ospf,debug,raw 02 00 00 0A C0 A8 0C 05 C0 A8 0C 05 02 00 00 0A
10:56:50 route,ospf,debug,raw C0 A8 0D 05 C0 A8 0D 05 02 00 00 0A C0 A8 78 02
10:56:50 route,ospf,debug,raw C0 A8 78 01 02 00 00 0A C0 A8 64 01 C0 A8 64 02
10:56:50 route,ospf,debug,raw 02 00 00 04 0B 0B 0B 0B FF FF FF FF 03 00 00 0A
10:56:50 route,ospf,debug,raw 00 02 02 05 00 00 00 00 C0 A8 C8 02 80 00 00 01
10:56:50 route,ospf,debug,raw D3 4A 00 24 00 00 00 00 00 00 00 01 00 00 00 00
10:56:51 route,ospf,debug SEND: Link State Acknowledgement 192.168.11.6 -> 224.0.0.5 on r1-eoip-core2
10:56:51 route,ospf,debug,raw PACKET:
10:56:51 route,ospf,debug,raw 02 05 00 40 C0 A8 97 01 00 00 00 00 B1 BF 00 00
10:56:51 route,ospf,debug,raw 00 00 00 00 00 00 00 00 00 01 02 01 C0 A8 C8 02
10:56:51 route,ospf,debug,raw C0 A8 C8 02 80 00 00 3C 82 39 00 60 00 01 02 05
10:56:51 route,ospf,debug,raw 00 00 00 00 C0 A8 C8 02 80 00 00 01 D3 4A 00 24
10:56:51 route,ospf,debug SEND: Link State Acknowledgement 192.168.11.2 -> 224.0.0.5 on r1-eoip
10:56:51 route,ospf,debug,raw 02 05 00 40 C0 A8 97 01 00 00 00 00 B1 BD 00 00
10:56:51 route,ospf,debug,raw 00 00 00 00 00 00 00 00 00 02 02 01 C0 A8 C8 02
10:56:51 route,ospf,debug,raw C0 A8 C8 02 80 00 00 3C 82 39 00 60 00 02 02 05
10:56:51 route,ospf,debug Recalculating all OSPFv2 intra-area routes
10:56:51 route,ospf,debug Recalculating all inter-area routes
10:56:51 route,ospf,debug summary-area=backbone
10:56:51 route,ospf,debug Recalculating AS-external routes
10:56:51 route,ospf,debug Installing an OSPF route in the main routing table
10:56:51 route,ospf,debug prefix=0.0.0.0/0
10:56:51 route,debug,calc Begin calculation
10:56:51 route,debug,event Updated route
10:56:51 route,debug,event previous-state=CANDIDATE
10:56:51 route,debug,event state=CANDIDATE
10:56:51 route,debug,event dst-address=0.0.0.0/0
10:56:51 route,debug,event attributes
10:56:51 route,debug,event protocol=OSPF
10:56:51 route,debug,event scope=20
10:56:51 route,debug,event next-hop= address=192.168.11.5
10:56:51 route,debug,event origin-type=OSPF
10:56:51 route,debug,event origin-instance-id=0
10:56:51 route,debug,event ospf-metric=11
10:56:51 route,debug,event ospf-type=external-type-1
10:56:51 route,debug,calc Select route
10:56:51 route,debug,calc dst-address=0.0.0.0/0
10:56:51 route,debug,calc attributes
10:56:51 route,debug,calc protocol=STATIC
10:56:51 route,debug,calc distance=1
10:56:51 route,debug,calc scope=30
10:56:51 route,debug,calc target-scope=10
10:56:51 route,debug,calc next-hop= address=31.205.49.190
10:56:51 route,debug,calc origin-type=STATIC
10:56:51 route,debug,calc End calculation
Code: Select all
<HP>display ip routing-table vpn-instance ospf-test-2
Routing Tables: ospf-test-2
Destinations : 15 Routes : 15
Destination/Mask Proto Pre Cost NextHop Interface
0.0.0.0/0 O_ASE 150 11 192.168.121.1 Eth0/0.3013
127.0.0.0/8 Direct 0 0 127.0.0.1 InLoop0
127.0.0.1/32 Direct 0 0 127.0.0.1 InLoop0
192.168.41.1/32 O_ASE 150 34 192.168.121.1 Eth0/0.3013
192.168.51.0/24 OSPF 10 1014 192.168.121.1 Eth0/0.3013
192.168.52.0/24 OSPF 10 1014 192.168.121.1 Eth0/0.3013
192.168.53.0/24 OSPF 10 1014 192.168.121.1 Eth0/0.3013
192.168.111.0/24 Direct 0 0 192.168.111.2 Eth0/0.3012
192.168.111.2/32 Direct 0 0 127.0.0.1 InLoop0
192.168.121.0/24 Direct 0 0 192.168.121.2 Eth0/0.3013
192.168.121.2/32 Direct 0 0 127.0.0.1 InLoop0
192.168.151.0/24 OSPF 10 20 192.168.121.1 Eth0/0.3013
192.168.152.0/24 OSPF 10 20 192.168.121.1 Eth0/0.3013
192.168.153.0/24 OSPF 10 20 192.168.121.1 Eth0/0.3013
192.168.200.0/24 OSPF 10 14 192.168.121.1 Eth0/0.3013
