directlogic
MIkrotik BGP Monitoring
Wed May 22, 2013 8:14 am
Dear All,
I am using BGP with 2-3 peer with RB1100AHx2. I want to monitor BGP session. Is it possible to monitor with nagios or grate graphs with cacti so the we can keep log of BGP up/down.
Thanks,
Direct_Logic
omega-00
Re: MIkrotik BGP Monitoring
Thu May 23, 2013 3:29 am
You could do this via SNMP if the BGP tables you're receiving aren't full tables (full tables and SNMP output don't work very nicely together due to the amount of data required to be sent).
Alternatively via the API or ssh if you're creating a custom probe.
directlogic
Thu May 23, 2013 8:04 am
Thx for reply .
But i am unable to find any SNMP OID to get BGP state. Could anybody help in this.
Direct_Logic
zakai
Thu May 23, 2013 2:36 pm
there are 3 MIBs for BGP: Some useful OIDs (there are a whole lot more objects and details in the RFCs):
  • - peer state: .1.3.6.1.2.1.15.3.1.2.<peer-ip>. Possible values are: idle(1), connect(2), active(3), opensent(4), openconfirm(5), established(6).
  • - peer admin state: .1.3.6.1.2.1.15.3.1.3.<peer-ip>
  • - peer remote AS: .1.3.6.1.2.1.15.3.1.9.<peer-ip>
  • - peer last error: .1.3.6.1.2.1.15.3.1.14.<peer-ip>
If you're using Nagios (or whatever NMS) and want a "fully automated" monitoring, you can retrieve the entire BGP neighbor table (in your case 2-3 row entries) which will contain all these parameters for all the neighbors listed in the table or you can hardcode the IP addreses for the neighbors you're interested in and check only for those. The OID for the table is .1.3.6.1.2.1.15.3.
Hope this helps,
Cheers!
mandrade
Fri May 24, 2013 11:13 pm
Hope this helps,
Cheers!
On CCR-1026 running ROS 6.0 FIANL, returns nothing to it... ideas???
BR
zakai
Mon May 27, 2013 9:39 am
Hi mandrade,
monitoring BGP sessions on MikroTik RouterOS was also on my list but unfortunately the BGP-related MIBs are not supported, at least not on RouterOS v5.x. Only some generic and MikroTik specific MIBs are implemented as of yet. The supported MIBs are:
MIBs used in RouterOS v5.x:
MIKROTIK-MIB
MIB-2
HOST-RESOURCES-MIB
IF-MIB
IP-MIB
IP-FORWARD-MIB
IPV6-MIB
BRIDGE-MIB
DHCP-SERVER-MIB
CISCO-AAA-SESSION-MIB
ENTITY-MIB
UPS-MIB
SQUID-MIB
Maybe a MikroTik official can shed some light regarding their plans to support the RFC4273 in the future, if any.
mandrade
Mon May 27, 2013 2:16 pm
Hi mandrade,
MIKROTIK-MIB
MIB-2
HOST-RESOURCES-MIB
IF-MIB
IP-MIB
IP-FORWARD-MIB
IPV6-MIB
BRIDGE-MIB
DHCP-SERVER-MIB
ENTITY-MIB
UPS-MIB
SQUID-MIB
Hey MikroTik Team any plan to support RFC4273 MIBs????
BR
Cris@usai.net
Wed Oct 09, 2013 7:31 pm
Agreed on all accounts. I can monitor my bgp sessions on all the Cisco routers I have.. would like to do the same on the
Mikrotik routers.
BGP peer state would be very helpful .
mspeed
Thu Oct 10, 2013 1:17 am
Agreed as well. Also, http://www.observium.org/wiki/Main_Page is a fantastic tool for usage/port/session status etc. monitoring.
Ascii
Thu Jan 23, 2014 8:53 am
any word from mikrotik?
gregsowell
Sat Jan 25, 2014 7:00 pm
If you guys could have a wishlist for BGP monitoring, what would it be?
I'd like:
Peer State
Peer # of routes received
Peer # of routes advertised
3 very simple, but useful things.
robertpenz
Sun Jan 26, 2014 6:38 pm
These 3 would be also my favorites .
meetriks
Sun Jul 06, 2014 7:21 pm
I hope that bgp monitoring with snmp will be implemented soon.
AlexS
Wed Sep 17, 2014 8:04 am
Bringing up an old thread.
Does any one know if this has been implemented ?
nz_monkey
Thu Sep 18, 2014 10:13 am
I have been told by support that this will be improved in RouterOS v7
lz1dsb
Thu Sep 18, 2014 2:18 pm
A lot of interesting features and improvements are expected in v7... I wonder when it will be released...
pincio
Fri Aug 05, 2016 10:09 am
if you looking for a solution to bgp peer in nagios yet i have write a plugin.
https://github.com/pincioc/check_bgp_mikrotik_nagios
hknet
Sun Aug 07, 2016 8:25 pm
Hey pincio,
thanks for the API idea, though if possible I'd ask you to go with https://github.com/efaden/MikroTikPerl as the api library.
(ssl support and so on)
based on your script I was able to check the route-count in a specific vrf:
my @cmd = ("/ip/route/print","=count-only=","?routing-mark=". $ng->get('vrf'));
the issue I'm now stuck at is: where does winbox get the prefix-count per peer from, I see no such value via
/routing bgp peer print
any hint is greatly appreciated.
regards
hk
Cha0s
Sun Aug 07, 2016 9:10 pm
Try
/routing bgp peer print status
hknet
Sun Aug 07, 2016 10:28 pm
Thanks Cha0s,
this definitely did the trick!
finally the prefix-count can be checked for a remote peer IP like this:
my @cmd = ("/routing/bgp/peer/print","=status=","?remote-address=". $ng->get('peer'),"=.proplist=prefix-count");
regards
hk
pincio
Mon Aug 08, 2016 2:05 pm
Thx hk for your contribute,
i have update the code with SSL and prefix count value output.
hknet
Mon Aug 08, 2016 3:07 pm
Dear Pincio,
thank you for updating your code, maybe you'd like to put this together in one command request like this:
my @cmd = ("/routing/bgp/peer/print","=status=","?remote-address=". $ng->get('peer'),"=.proplist=prefix-count,state");
this way you can simply check the results like this:
result: =prefix-count=XYZ
result: =state=STATUS
result: !done
and you make only one api call.
Finally I'd vote for some optional values like expected prefixes and/or an upper and lower limit, this way one could get notified if either a fixed value is wrong or if a lower or upper limit is reached (lower might mean something is wrong with this peer and higher usually means you have to raise your max-prefix-limit or maybe change your filters).
regards
hk
pincio
Mon Aug 08, 2016 5:32 pm
Dear Pincio,
result: !done
Yes, of course. Now i use your command and clean the code from useless cicle
I have add -T argument in the format min:MAX
pe1chl
Mon Aug 08, 2016 6:35 pm
When I installed MiktoTik Dude I hoped that there would be a way to show the peer prefix-count in a map just
like it can show the current link bitrate. But although Dude can use the same API, it does not appear that it
can do this.
(I would like to see the prefix counts in each direction along a link, and maybe when hovering it show a top-n
list of largest prefixed routed along that link)
hknet
Mon Aug 08, 2016 7:03 pm
Hi pe1chl,
I bet you, you don't want this hovering-feature on bgp peers transmitting a full v4 (or even v6) table as this would simply take quite long :)
Regards,
hk
Cha0s
Mon Aug 08, 2016 7:14 pm
Hi pe1chl,
Regards,
hk
I've done something similar but instead of counting the prefixes on routeros, I established a bgp session with a quagga instance and count the prefixes from there which is way faster.
pe1chl
Mon Aug 08, 2016 7:19 pm
Hi pe1chl,
This is for an isolated network using BGP and it has only slightly above 100 prefixes. And I also mentioned I would like to see the top-n
prefixes (sorted downward by size), maybe top-25 or so.
pe1chl
Mon Aug 08, 2016 7:22 pm
But that means you need to establish a peer relation from your monitoring system to all the routers, right?
And then you use some config trick so there will be no routes via that system?
Is it possible, using a peer connection, to query all links of the remote router?
(It would need to collect a table of all prefix counts and actual prefixes of all links on all routers of the system)
hknet
Mon Aug 08, 2016 7:35 pm
Sounds in the end you'd monitor your routereflectors :-)
*scnr*
Cha0s
Mon Aug 08, 2016 9:20 pm
Since your network only has ~100 prefixes then the quagga approach is a bit overkill.
Prior to quagga I used SSH to fetch all received (active and inactive) for each link.
Maybe this project might help you better to extract BGP stats from your network.
https://github.com/Cha0sgr/BGP-Looking-Glass-NG
This is a BGP looking glass that can connect to MikroTik via SSH and fetch all BGP routes and present them in quagga/cisco format (sh ip bgp).
https://github.com/Cha0sgr/Live-BGP-Statistics
Then using this system you can collect all BGP prefixes and AS Paths from all your routers (registered on the looking glass above) and show them in a friendly/searchable format.
From the github page:
Features:
-Show each detected AS' BGP Peers in an easy to read list
-Full BGP Prefixes List with filters by AS Number and Prefix
-BGP Prepends detection with filters by AS Number
-Full BGP Peers list with filters by AS Number
-BGP Event Log with all events (New/Updated/Deleted Peers/Prefixes/Prepends, plus other events) with filters by AS Number and Prefix
-Invalid Prefix Advertisments list with all the ASes that advertised unssigned or invalid prefixes to the network. This relies heavily on WiND's database to work
-Live BGP Map with all the ASes and their peers
The Live BGP Map requires the WiND Project to work.
https://github.com/wind-project/wind
An alternative to adding all your routers to the Looking glass above (by allowing ssh access to them from the looking glass server) would be to set up a Quagga instance and set up a BGP peer with all your routers.
All your routers will send all prefixes to quagga and quagga will not send anything to any router (so quagga will not route anything to anyone).
Then you add the quagga instance to the Looking glass and it will get all routes from all routers which Live BGP Statistics will then process.
One caveat is that quagga will only receive active prefixes from each router and not the alternative routes/paths each router might have to some destinations.
pe1chl
Mon Aug 08, 2016 9:52 pm
What I currently use is SNMP to query the route tables from the routers. This shows me the currently
active routes. It is sufficient to look at a single router at a time. However, it would be neat to have a "map"
in Dude or a similar tool to have some kind of overview of the link situation and browse some detail.
It is a pity that Dude does not offer this as standard, it only shows bitrate but no insight in what traffic
that may be. As I use some communities and local-pref values to direct the traffic, it could be useful to
have this capability.
nz_monkey
Tue Aug 09, 2016 1:14 am
BGP4-MIB is whawhat is needed!
Oh and fixing the routing crash that happens when you SNMP poll a router
hknet
Tue Aug 09, 2016 1:16 am
well, snmp by the standard would of course be fine, but the current RC promises to have a snmp to script interface which should allow for some interesting private OIDs :)
pe1chl
Tue Aug 09, 2016 10:35 am
Ah has that been implemented? That was a feature I once requested...
Will certainly have a look into that! However, currently I am not able to check for new RC version, maybe it has been taken down due to discovering a serious error?
hknet
Tue Aug 09, 2016 11:13 pm
releasenote for 6.37rc10 says: snmp - added script table which executes script and returns it's output on get request;
cheers,
hk
pe1chl
Wed Aug 10, 2016 10:50 am
Very interesting! But I wonder how to set that... I have 6.37rc11 on a test system and I don't see anything in WebFig under SNMP or Scripts.
It would be nice to poll the BGP Peer status via SNMP, and also for other purposes like receiving counts of routes, ARP entries, etc.
It is still not possible to check the uptodate status of release candidate... funny.
leviton
Wed Aug 17, 2016 9:01 pm
Thanks all!
pe1chl
Sat Aug 20, 2016 6:00 pm
Unfortunately I still have not been able to locate that script table... where is it?
bajodel
Long time Member
Long time Member
Tue Aug 23, 2016 8:14 pm
Me too, where is it?
zentavr
Tue Jul 03, 2018 2:43 am
I have implemented the code in Python 2.7.13 which fetch the BGP Counters via API.
SSL and plain API connections are supported. The code is available on Github or Bitbucket
The next BGP counters are being monitored:
* Remote AS
* Prefix Count
* Administrative status of the peer: enabled/disabled
* Peer connection uptime
* Peer connection state
* Comment :)
* Updates Sent
* Updates Received
* Withdrawn Sent
* Withdrawn Received
The next triggers are defined:
* (Info) BGP Remote AS Number had been changed
* (High) Peer is down
* (Warning) Peer lost 10% of its prefixes
* (Average) Peer lost 20% of its prefixes
* (High) Peer lost 30% of its prefixes
* (Warning) BGP Session was restarted
* (Disaster) No prefixes had been received
The next charts had been added:
* Accepted Prefixes
* Established Time
* BGP Updates per sec
* BGP Withdraws per sec
You are welcome to fork and pull requests.
raminmalek
Thu Jul 12, 2018 5:27 pm
Have any solution For monitor Bgp session by cacti ???
maznu
Thu Jul 12, 2018 5:36 pm
For those of you using https://prometheus.io for monitoring, there are two options:
* https://gitea.faelix.net/FAELIX/ros2prom (requires Python, pipenv)
* https://github.com/nshttpd/mikrotik-exporter (which does not calculate bits-per-second on ports, for example)
raminmalek
Fri Jul 13, 2018 2:35 pm
Thx but i have Cacti and prtg and observium server
schadom
Sat Jul 14, 2018 12:45 am
four years later and BGP4 MIBs are still missing in ROS :-(
schadom
Mon Sep 17, 2018 1:55 pm
Thread created at Wed May 22, 2013 7:14 am
bump
StubArea51
Trainer
Trainer
Fri Sep 28, 2018 11:47 pm
This would be really nice to have ;-)
schadom
Mon Oct 22, 2018 4:14 pm
Any update on BGP4 SNMP MIBs?
patrick7
Mon Oct 22, 2018 4:32 pm
They are aware but they don't care :lol:
schadom
Mon Oct 22, 2018 4:55 pm
According to their job listings page they are still looking for C/C++ and embedded systems devlopers in Latvia for over six months now! Frankly, to me it seems their development team is fully occupied with other stuff (ARM/NV2-mess, w60g, etc.) and they urgently need more manpower to be able to focus on the relevant stuff again (such as ROS core, the routing engine, BGP, OSPF and everything related).
patrick7
Mon Oct 22, 2018 10:18 pm
Yea, the job offer is in Latvian, no word of english. They also require applicants to speak Latvian.
They probably think all good programmers are fluent in Latvian...
xhomanx
BGP Configuration between MikroTik & Cisco router
Mon Oct 22, 2018 10:26 pm
I need to know how to configure BGP between my MikroTik cloud core Router and Cisco
before I did BGP configuration on my Cyberoam 2500ing but now it's not established with my ISP so I want to try MikroTik to do BGP with my ISP.
here are the details of my ISP BGP they did in their cisco and need same configuration on mikrotik
neighbor 10.23.36.25 remote-as 12345
neighbor 10.23.36.25 description stream
neighbor 10.23.36.25 ebgp-multihop 6
neighbor 10.23.36.25 update-source Loopback51
neighbor 10.23.36.25 activate
neighbor 10.23.36.25 soft-reconfiguration inbound
neighbor 10.23.36.25 route-map STOPUPDATES out
so please help me in this and I seek for your help.
And type the commands or send me the screenshots in xhomanx@gmail.com
pe1chl
Tue Oct 23, 2018 10:57 am
Also, please do not invade in a topic which is disccussing a specific issue and post your generic need for help. Start a new topic for that!
Jacentyd
Sun Nov 04, 2018 6:52 pm
Is it possible to implement monitoring BGP sessions via SNMP? according to RFC ????
mutinsa
Wed May 15, 2019 3:25 pm
+1.
madman22
Sat May 18, 2019 1:13 am
I've used
https://github.com/rhicks/bgp-dashboard
for monitoring bgp, it works great!
pwuk
Tue Jan 28, 2020 1:34 pm
Normally you can monitor BGP via SNMP walking 1.3.6.1.2.1.15.3.1.2, which returns the state (other oids are available)
Mikrotik doesn't implement this, which seems crazy. I typically peer mikrotik-cisco or mikrotik-juniper and monitor on the cisco/juniper end, which does work.
If you're peering mikrotik-mikrotik, you can sort of hack round it by monitoring for a specific known route
For example on this router
I have 172.30.249.0/24 advertised from 172.29.253.2
I have 172.29.120.0/24 advertised from 172.26.184.185
SNMP shows up as
ipCidrRouteProto.172.29.120.0.255.255.255.0.0.172.26.184.185 = INTEGER: bgp(14)
ipCidrRouteProto.172.30.249.0.255.255.255.0.0.172.29.253.2 = INTEGER: bgp(14)
If the peer drops between 172.29.253.2 and my router, that second line won't show up
However there's clearly other issues - if the route stops being advertised for whatever reason, or is advertised an alternate way, it will also fail.
The other option would be to write an SSH check, which would run something like
"ssh 172.26.127.21 routing bgp peer print terse"
And parse the output. I'm unaware of any nagios-style plugins that do that out of the box.
pe1chl
Tue Jan 28, 2020 1:49 pm
You can run a scheduled script on the router (found elsewhere on this forum) that monitors the configured BGP peers and sends an e-mail on state changes.
I run it every 15 minutes which is often enough for me to be alerted about links being down without being alerted for every router reboot or similar.
Still, SNMP monitoring of BGP parameters (peer up, number of prefixes received, number of active routes to that peer) would be welcome, e.g. for graphing.
StubArea51
Trainer
Trainer
Tue Jan 28, 2020 1:58 pm
I agree, I've been dying to get SNMP monitoring of BGP peers for a long time.
mada3k
Long time Member
Long time Member
Tue Jan 28, 2020 9:31 pm
We monitor BGP and OSPF status with NetXMS built in and SSH commands. We know that we always should have at a number of peers so we set a threshold for it.
/routing bgp peer print count-only where established
/routing ospf neighbor print count-only
AlexS
Mon May 25, 2020 2:49 pm
Wow still waiting on this !
method
Wed Mar 17, 2021 11:42 am
Show me where observium shows peer state with snmp data from mikrotik ?
VincentL
Wed May 19, 2021 3:52 pm
In 2021, 2016' Pincio's script is still working (https://github.com/pincioc/check_bgp_mikrotik_nagios)
But, with recent version of firmware, you have to use this API (https://github.com/candlerb/MikroTikPer ... b/newlogin) instead of those described (https://github.com/efaden/MikroTikPerl)
Vincent
raminmalek
Thu May 27, 2021 6:55 pm
For See ip Route Count and bgp update and bgp session status any idea for cacti??? or other program prtg ?? for monitor bgp session on mikrotik ?
raminmalek
Thu May 27, 2021 6:56 pm
Observium Donnot suppport mikrotik For bgp
Users browsing this forum: clambert, DeLL and 25 guests
