weldred
VPLS Tunnel not working - L2MTU on bridge wrong
Sun Nov 24, 2013 12:22 am
Hi gurus,
I had a wireless bridge that is working fine. I wanted to add a 2nd station, so I changed to AP-Bridge
and copied the settings on the station to a new one (with the appropriate IPs changed).
R0 (AP-BRIDGE)
VPLS1: ip=172.16.0.1
ETHER1: ip=192.168.0.18
WLAN1: ssid="wrcbridge"
BRIDGE: ports=ETHER1, VPLS1
R1 (station)
VPLS1: ip=172.16.0.2
ETHER1: ip=192.168.0.17
R2 (station)
VPLS1: ip=172.16.0.3
ETHER1: ip=192.168.0.19
Current state:
- Original bridge works fine (R0<->R1)
- New bridge (R0<->R2) - I can ping the VPLS address from the AP-Bridge, but I cannot ping the static IP on the Ethernet interface.
In reading some other posts, I see mention to ensure that the bridge l2mtu is less than wlan/vpls l2mtus.
In looking at my working station (R1), I see:
[admin@MikroTik] > /interface print
 #     NAME        TYPE             MTU   L2MTU
 0  R  ether1        ether            1500  1526
 1  R  bridge1        bridge           1500  1500
 2  R  wlan1        wlan             1500  2290
 3  X  wlan2        wlan             1500
 4  R  vpls1        vpls             1500  1500
In looking at the non-working station (R2), I see:
 #     NAME                                                              TYPE               MTU L2MTU  MAX-L2MTU
 0  R  ether1                                                            ether             1500  1526       1526
 1  R  wlan1                                                             wlan              1500  2290
 2  X  wlan2                                                             wlan              1500
 3  R  bridge1                                                           bridge            1500  1526
 4     vpls1                                                             vpls              1500  1500
I see 2 issues:
- Bridge1 L2MTU is 1526. I believe I need that to be 1500.
- VPLS1 is not running
How do I reset the l2mtu on Bridge1 on R2 ? I assume that's why VPLS1 is not happy.
Thanks for any pointers !
Ward
Inssomniak
Re: VPLS Tunnel not working - L2MTU on bridge wrong
Mon Nov 25, 2013 3:12 am
The bridge interface inherits the lowest supported MTU so 1500 is right.
Also if you have the ethernet interface that mpls/VPLS is running on in a bridge I don't think this works.
Looks like you have 3 devices all trying to be a part of the same VPLS tunnel?
I've never tried having a VPLS tunnel with 3 end points ? Didn't think it was possible
weldred
Thu Dec 05, 2013 4:38 pm
Thanks Inssomniak for the pointer !
Solution: I added a 2nd VPLS for R0<->R2, added it to the bridge on R0 and everything is behaving appropriately.
Users browsing this forum: No registered users and 25 guests
